http://192.168.1.77 No Response - Blank Screen
doublecheese
Post by doublecheese »
When I type http://192.168.1.77 on my browser, I normally get connected to my meteohub set up page.
However, today I only get a Blank Page instead, I know that Meteohub is working as it's updating all the values on Wunderground and Weather Display Live.
Can somebody tell me why I'm getting a BLANK PAGE rather than my usual MeteoHUB Set Up page ?
I have rebooted the MeteoHub a several times by unplugging it off electricity and replugging it.
vecerapl
Re:http://192.168.1.77 No Response - Blank Screen
Post by vecerapl »
ROUTER you using? If so, try and 192.168.1.1. or 192.168.1.10x (where x is a number from 0 to 5)
doublecheese
I'm using Linksys Cisco WAG160N
Nothing helped , but then I went to my web browser history and used the following adress than it worked .
http://192.168.1.77/cgi-bin/meteohub.cgi
Before I was using only the numbers, but now it works only with above adreess. I don't know why.
But it works and I'm happy ...
skogvaktare
Post by skogvaktare »
doublecheese wrote:When I type http://192.168.1.77 on my browser, I normally get connected to my meteohub set up page.
Hi!
I´ve got a similar problem. The MeteoPlug is not reachable. Network is tested and ok (the little orange LED at the Plug´s ethernet plug is also blinking)
Router prefs didn´t change. But there´s no contact to the plug.
Neither the adress "http://192.168.0.99/cgi-bin/meteohub.cgi" nor the adres "http://192.168.0.99" bring me to the data.
Did anyone know a solution?
Christian
what IP does in blink to you during boot?
skogvaktare
Hi!
I already send you an email at this moment.
I don´t know. How do I see this. I have to study the manual for the code first
skogvaktare
Everything i fine again!
There was a problem concerning the boot-process. After flashing the Plug again, the Meteoplug is running with the old SD-Card´s system! Unfortunately the meteohub doesn´t read out the VP2´s logger, so there´s a little lack in the datas.
Thank you for the help, Boris!
doublecheese
Re: http://192.168.1.77 No Response - Blank Screen
Hı Borıs and others
I can not see my meteohub page agaın !!! I did not change anything at all, all settings are the same but when I type in the meteohub address I can not conncet to my meteohub. I always get a blank screen
What can I do ?
