Hi All,
Open question, have just updated to v4.6c and I am noticing the following.After a short time ( varies ) WU Rapidfire is not updating (5 sec) however normal 5min data is o.k everything else seems to be working o.k. To get WU Rapidfire updating regular (5sec) I have to reboot Meteohub then all is well. Anyone else noticed this, whilst running V4.6b the system was stable - ALIX1D .
Cheers Alan WU ITRAFFOR2
WU Rapidfire
Re:WU Rapidfire
yep, the same scenario with me.
Boris told me he will look again into the reason for rapidfire stopping.
you do not need to restart: with the shell - SSH - type
rcmeteonetd stop
rcmeteonetd start
But the daemon does not work very long, even if rapid-fire isn´t acccessed via an applet it falls back into normal mode.
rcmeteonetd stop
rcmeteonetd start
- VP2
- Fresh Boarder
Re:WU Rapidfire
Thanks Wolfgang, at least I know all is well at this end, hope Boris works it out for next update.
Cheers Alan
Cheers Alan
Re:WU Rapidfire
Found the same thing - I see this in log file
2010.03.30 09:14:29 meteohub: weathernet: weather underground rapid fire: error open pipe /usr/bin/wget -U meteohub -t 2 -q -O /dev/stdout http://rtupdate.wunderground.com/weatherstation/updateweatherstation.php?action=updateraw
- VP2
- Fresh Boarder
Re:WU Rapidfire
Hi David,
That is the same report as in my log file
cheers Alan
cheers Alan
