3G with eBox 3300
Align
3G with eBox 3300
Post by Align »
In the Meteohub interface it shows under Networks a Modem option I'm assuming for a USB 3G dongle. If I'm correct should it "plug & play" and if not what do I need to do to get it working.
I've completed the fields with info required but it doesn't work.
Thanks in advance for any help.
Re:3G with eBox 3300
That feature is experimental and has been discontinued as it brought tons of trouble. If it works for you, then fine. If not, forget about it.
Align
Post by Align »
Thanks for the feedback. i'll give it a miss thanks.
Regards to all.
