Sensors are no longer reporting any value
lcoulon
Post by lcoulon »
My Meteohub v4.6o working with NSLU is no longer acquiring values from my Oregon WMR200 station.
All was working perfectly until last days, for now i get that screen : ( please see attached screen capture )
error connect socket 127.0.0.1:5555 :Connection refused
Warning: Data logging has been halted.
Manage Graph section has also lost all my configuration ( please see attached screen capture )
Error file directory: /data/graphs/: No such file or directory
Would you please help and tell me what is wrong ? :shock:
Many thanks,
Manage Graphs section.jpg (46.74 KiB) Viewed 4479 times
sensor section.jpg (80.06 KiB) Viewed 4479 times
Re: Sensors are no longer reporting any value
Post by skyewright »
lcoulon wrote:All was working perfectly until last days, for now i get that screen : ( please see attached screen capture )
The most likely thing is that the USB stick has failed... :(
could you please post what "meteohub log" is telling on log file page?
ukpete
Post by ukpete »
I have been having very similar problems to this and the solution is to change the NSLU2 power supply. It would appear the Linksys supplies degrade over time and since these power the USB ports directly all manner of strange things could happen. Check this site http://www.nslu2-linux.org/wiki/Info/Po ... gSchematic
At the moment I have a working Meteohub using a 5V/1200mA supply and if I swap back to the original Linksys I get the same errors - if I can get the NSLU2 to boot at all.
