remove decimal beaufort value
AenG
Post by AenG »
Is it possible to remove the decimal from the beaufort value?
Official decimal beaufort values don't exist.
gr Geert
www.hetweerinboskamp.nl
YJB
Re: remove decimal beaufort value
Post by YJB »
Hi Geert,
The request makes sense to me, but it's not a matter of just removing the decimal (our rounding), instead the conversion should be done according to the following table:
Bft	<- m/s
0	<- 0–0.2
1	<- 0.3–1.5
2	<- 1.6–3.3
3	<- 3.4–5.4
4	<- 5.5–7.9
5	<- 8.0–10.7
6	<- 10.8–13.8
7	<- 13.9–17.1
8	<- 17.2–20.7
9	<- 20.8–24.4
10	<- 24.5–28.4
11	<- 28.5–32.6
12	<- 32.7+
Regards,
Ysbrand
AenG
Post by AenG »
Ysbrand,
Thats a good solution for the ajaxscripts.
But how can i use that with the values from the meteohub? (allsensors.txt)
On my webpage i use both!
YJB
Post by YJB »
Hi Geert,
Your request is something that Boris will need to implement.
The main reason for listing the table is to make sure that the request is properly documented. My experience has learned that it is more likely that Boris is willing to implement something when the request is as complete as possible. Also, it's very frustrating for him if it turns out that the change is not living up to the expectations.
Ysbrand
Thanks for taking care of my time. YJB's table will be part of the next update. Integer values will be reported by variables ending with "bftint" in addition to the "bft" ones already there.
AenG
Post by AenG »
Thats good news!
Geert
