[solved] can't reach sheeva plug anymore
paraglider
Post by paraglider »
Since some days I can't reach my sheeva plug anymore (when pinging the answer is: "Zielhost nicht erreichbar" - host not reachable).
I use a Sheeva Plug (model 003-SP1001, S/N 0939000558) with preinstalled software from New IT.
It worked fine and without any problems since installation half a year ago.
The LEDs on the meteohub are all on and the yellow and green LEDs at the RJ45 connection are also active.
As I'm not an IT expert I would need some hints to locate the reason for that behaviour!
Thanks and regards,
paraglider
edit [solved]: reason seems to be a damaged network cable. meteohub works fine with another patch cable on another port of the network-hub :-)
Re: [solved] can't reach sheeva plug anymore
puhh, that can be hard to find out.
