I an attempting to reset my ALIX1b to  sets IP to 192.168.1.77
using the command  echo -e "auto eth0\\niface eth0 inet static\\n\\taddress 192.168.1.77\\n\\tnetmask 255.255.255.0" >/etc/network/interfaces
The problem is my keyboard is wrong ie the key don't match what I am typing.
Is there an easy solution to this?
I have tried PS2 and usb with the same problems.
Edit I think this could be a keyboard mapping problem?
						Keyboard problems
Re: Keyboard problems
I have had a look on the net and I think my meteohub is set to use a QWERTZ (German) keyboard rather than my QWERTY (UK/USA) keyboard.
Is there a command I can use to change my meteohub system to accept QWERTY keyboards?
Brett.
German
UK
Brett.
German
UK
- YJB
You can try:
dpkg-reconfigure console-data, this brings up an interactive menu with keyboard layouts.
Ysbrand
Ysbrand
Thanks for that YJB. My keyboard works fine now.
Now my keyboard is working I was able to type the commands in the forum topic below to make my Meteohub visible on my network again.
viewtopic.php?f=22&t=2873
