I have a UV sensor attached to my WMR200 connected to meteohub (version 4.7d). On the WMR console I get a reading from the sensor but in the clientraw.txt it has no value.
Valuenumber 79 (in the clientrax.txt) should have a value from the UV sensor but it has a "-" as a value. WD Live does not display a value either. When I alter it manually is WD Live displays the entered value.
Can someone tell what I can do so that the clientraw.txt contains the correct value for the uv sensor?
Regards,
Wouter.
UVI has no value in clientraw.txt (and WDL)
- YJB
Re: UVI has no value in clientraw.txt (and WDL)
Did you select the UV sensor in the WD Live setup page?
- wdlive.jpg (30.23 KiB) Viewed 3088 times
Yes I did. I configured a uv0 sensor connected the the sensor type meteohub displayed by itself. When I check the sensors page in the meteohub admin pages I get a reading from the sensor. Also, meteohub generates a graph from the UV sensor.
Looking again at the reply from YJB I checked the setting again and for some reason, must be me ;-), the setting was gone.
@ YJB ; Thanks for the hint. Hope the sun will shine again so I can see that it works.
