Meteohub stops collecting data from weatherlink
Hathor27
Post by Hathor27 »
Hi there,
my weatherstation runs since about one month. Up to now meteohub collected data from weatherlink perfectly. But since a few days meteohub stops collecting data from weatherlink after a few hours of working.
I restart meteohub every day at 5am automatically. Other data collecting works fine, just weatherlink seems to struggle...any idea?
Link to my systemdata + weatherdata see http://untersiggenthal.meteo.selfip.inf ... ?show=data
Best Regards
Hathor27
http://untersiggenthal.meteodata.ch
d_l
Re: Meteohub stops collecting data from weatherlink
Post by d_l »
Which version of the weatherlink logger are you using, e.g., serial, USB or IP?
Hathor27
Post by Hathor27 »
It's the USB version attached to a Weather-Envoy.
Additionally I run a Console standalone - so I know ISS is transfering data perfectly
Best Regards
Hathor27
what meteohub version are you using?
Hathor27
Post by Hathor27 »
I'm using 4.7g (Build 5302), but it already happened with 4.7f.
I remembered that there was a problem once with Meteoplug-Server configuration (german, see http://www.wetterforum.info/weatherboxx ... hilfe.html):
  • I set the Upload-Interval then to 24h - this worked fine so far.
As I remembered these days, I reduced the Upload-Intervalto 6h, and now it seems to work again with Weatherlink... :?:
...which dependency is there on that? May there be a buffer- or temp-data-overflow, if Meteoplug-Data won't be sent?
And again: Why can't I set Meteoplug-ServerUpload-Interval to none, if I do not use Meteoplug?
Best Regards
Hathor27
You can set Meteoplug upload to "none", at least that works with my rigs.
Hathor27
Post by Hathor27 »
Shit, I still have problems collecting data from weatherlink.
I think it doesn't depend on upload-time none, 24h, or ...
But I recognized that it happens more often if System-Load is above 1.00.
And that occurs pretty often by now.
Also data-aggregation doesn't work fine then (don't bother having a look at http://untersiggenthal.meteo.selfip.inf ... ?show=data for actual data)
How can I find the cause of this high System-Load?
Best Regards
Hathor27
Hathor27
Post by Hathor27 »
H E L P - my system still struggles :cry:
  • I stopped the two additionally defined WeatherStation plugins.
  • I updated to 4.7i
  • Now only run my Vantage (with USB-Weatherlink-Interface) as Station 0 and System Data as Station 1
  • System seems to work at high system load, is still around 1.00 (after recalculating)
  • System stops collecting data from Weatherlink after a few hours, even if I restart meteohub daily
  • and its getting worse every day
My System: Linux Kernel 2.6.24 997 BogoMIPS, 248 MB RAM, ALIX.1D (500 MHz)
What can I do to get my system working well again? :?: :?: :?:
Please, can anybody support me?...
Best Regards
Hathor27
Could you please send me login details to "info(at)meteohub.de". I need access to ports 22 and 7777.
Hathor27
Post by Hathor27 »
Thank you very much Boris.
It seems to work fine again, even with the USB-Extender
Best Regards
Hathor27
Hathor27
Post by Hathor27 »
Hathor27 wrote:It seems to work fine again, even with the USB-Extender
I got new troubles against giving the all-clear :(
But then I found that the archive interval of my Vantage/Envoy was set to 1 minute - I increased it to 5 minutes.
Does anybody know if that causes troubles in communication? What is the mechanism of the archive interval ?
Best Regards
Hathor27
