Hi there,
my Meteohub system info says: Linux Kernel: 2.6.24 997 BogoMIPS, 248 MB RAM, ALIX.1D (500 MHz)
But as I recognize the mechanical dimensions and its case it looks rather than an ALIX.3D...
How can I verify what hardware I run on really? Where gets Meteohub the system info from?
Thanks a lot in advance
Hardware version ALIX.1D vs ALIX.3D
Best Regards
Hathor27
http://untersiggenthal.meteodata.ch
Hathor27
Re: Hardware version ALIX.1D vs ALIX.3D
Meteohub cant distinguish between these two boxes. It can tell a 3D2 from a 1D, but not a 3D3 from a 1D.
If anyone having an Idea how to find out, I would be happy to make use of it in next update.
As a work-around, couldn't you setup a txt-file with version number in it?
If the file exists, you read it, if not, you take the standard response of the unit
Best Regards
Hathor27
Hathor27
- YJB
Just a wild guess, this is from my 1D:
Also, maybe there are additional modules loaded because the HW is slightly different:
So, one might run the same commands on a 3D3 and look for differences.
meteohub:/# cat /proc/devices
Character devices:
1 mem
4 /dev/vc/0
4 tty
4 ttyS
5 /dev/tty
5 /dev/console
5 /dev/ptmx
7 vcs
10 misc
13 input
14 sound
29 fb
116 alsa
128 ptm
136 pts
180 usb
188 ttyUSB
189 usb_device
252 rtc
253 cs5535_gpio
254 usb_endpoint
Block devices:
1 ramdisk
3 ide0
7 loop
254 device-mapperCode: Select all
meteohub:/# lsmod
Module Size Used by
battery 13700 0
cp2101 13188 0
pl2303 19972 0
labjacku3 9476 0
rtc_cmos 7968 0
rtc_core 17432 1 rtc_cmos
rtc_lib 3072 1 rtc_core
ipv6 230372 26
dm_snapshot 16928 0
dm_mirror 20608 0
dm_mod 54724 2 dm_snapshot,dm_mirror
loop 16260 0
evdev 10880 0
parport_pc 26148 0
parport 33352 1 parport_pc
ac 6148 0
button 8464 0
psmouse 36368 0
serio_raw 6660 0
geode_aes 6020 0
blkcipher 6660 1 geode_aes
snd_cs5535audio 14140 0
ftdi_sio 34952 1
snd_ac97_codec 92964 1 snd_cs5535audio
ac97_bus 2176 1 snd_ac97_codec
usbserial 31848 5 cp2101,pl2303,ftdi_sio
snd_pcm 69640 2 snd_cs5535audio,snd_ac97_codec
snd_timer 20868 1 snd_pcm
cs5535_gpio 5208 0
geode_rng 2432 0
snd 47588 4 snd_cs5535audio,snd_ac97_codec,snd_pcm,snd_timer
soundcore 7264 1 snd
snd_page_alloc 10120 2 snd_cs5535audio,snd_pcm
pcspkr 3072 0
rtc 12828 0
ext3 120712 2
jbd 39700 1 ext3
ide_disk 15488 4
ata_generic 7556 0
libata 145136 1 ata_generic
scsi_mod 141836 1 libata
generic 4484 0 [permanent]
ohci_hcd 21892 0
ehci_hcd 32140 0
amd74xx 8848 0 [permanent]
usbcore 126316 8 cp2101,pl2303,labjacku3,ftdi_sio,usbserial,ohci_
hcd,ehci_hcd
ide_core 107224 3 ide_disk,generic,amd74xx
via_rhine 23048 0
mii 5248 1 via_rhine
thermal 16028 0
processor 28720 1 thermal
fan 4868 0Re: Hardware version ALIX.1D vs ALIX.3D
My 3D3 says:
and
Can anybody espy any 3D3- or 1D-specific headword?
meteohub:~# cat /proc/devices
Character devices:
1 mem
4 /dev/vc/0
4 tty
4 ttyS
5 /dev/tty
5 /dev/console
5 /dev/ptmx
7 vcs
10 misc
13 input
14 sound
29 fb
116 alsa
128 ptm
136 pts
180 usb
188 ttyUSB
189 usb_device
252 rtc
253 cs5535_gpio
254 usb_endpoint
Block devices:
1 ramdisk
3 ide0
7 loop
254 device-mapper
meteohub:~# lsmod
Module Size Used by
battery 13700 0
ftdi_sio 34952 0
pl2303 19972 0
labjacku3 9476 0
rtc_cmos 7968 0
ipv6 230372 24
dm_snapshot 16928 0
dm_mirror 20608 0
loop 16260 0
evdev 10880 0
ac 6148 0
button 8464 0
geode_aes 6020 0
cp2101 13188 2
usbserial 31848 7 ftdi_sio,pl2303,cp2101
cs5535_gpio 5208 0
geode_rng 2432 0
pcspkr 3072 0
rtc 12828 0
ext3 120712 2
jbd 39700 1 ext3
ide_disk 15488 4
ata_generic 7556 0
ohci_hcd 21892 0
ehci_hcd 32140 0
usbcore 126316 8 ftdi_sio,pl2303,labjacku3,cp2101,usbserial,ohci_hcd,ehci_hcd
via_rhine 23048 0
thermal 16028 0
fan 4868 0
Best Regards
Hathor27
Hathor27
New approach: Would there be a way to test the amount and function of LED's
Best Regards
Hathor27
Hathor27
and I found something here: They somehow detect ALIX.2 and ALIX.3 systems:
https://dev.openwrt.org/browser/trunk/t ... tton.patch
Is any crack out there knowing to deal with this code?
Best Regards
Hathor27
Hathor27
