Update 4.8g
What's hot...
Update 4.8g
Update to Meteohub V4.8g (NSLU2, x86, SheevaPlug, DreamPlug) brings these features:
  • added rxxx and pxxx fields to ARPS records (incl. CWOP)
  • added support for low cost USB sound level meter SL-814
  • added predicate "precision" for determining number of decimals of a resolved Meteohub variable in HTML template mode
Update Link: http://www.meteohub.de/files/update-v4.8g.upd
rovinj
Re: Update 4.8g
Post by rovinj »
After upgrade and changing some variables I got following errors:
Error file open: /home/meteohub/wmr928fulleval.conf: Read-only file system
Error file open: /home/meteohub/wmr928eval.conf: Read-only file system
Job scheduled for recalculation of weather data
Error file open: /home/meteohub/logger.conf: Read-only file system
Data Logging restarted
Error file open /home/meteohub/meteohub.conf
but after restart everything seems OK.
Re: Update 4.8g
File system drops into read-only mode when it reaches a certain degree of disruption. Booting again might temporarily make the problem disappear, but your storage madia is for sure seriously damaged. Looks very much like a NSLU2 with a worn out USB stick. You should immediately change that.
These kind of problems have noting to do with the update itself. But the update changes quite some data onto the storage media so that errors being already there but not being discovered become obvious.
