[year1_rain0_days] - 2 rain days on the 1st january 2012 ?
Manhart
Post by Manhart »
i use the variable [year1_rain0_days] and today (1st january 2012) Meteohub shows 2 rain days. Why ?
Matthias
http://www.beathis.ch/meteo/
EmjayNet
Re: [year1_rain0_days] - 2 rain days on the 1st january 2012
Post by EmjayNet »
I use [year1_rain0_days] but I don't see the same issue, mine reports 1 of 1!
But I do see an issue with [year1_rain0_total_mm:0] lagging well behind [day1_rain0_total_mm:0], even after 6 hours.
I guess it will catch up tomorrow!
My system is a vantage and alix, don't know if having different hardware creates this issue in your case!
Hopefully the issue will correct itself tomorrow!
All the best
Mark
Manhart
Post by Manhart »
I use: MeteoHub: 4.8f (Build 1169), NSLU2, DAVIS Vantage Pro 2
Matthias
Manhart
Post by Manhart »
Today (2012-01-03) i made the update from 4.8f to 4.8i. After the recalcuation of the data, i got 4 raindays for 2012 ! We had rain on the 1st and 2nd january and this gives 2 raindays !
Matthias
EmjayNet
Post by EmjayNet »
Sorry I can't help here as MH on the Alix report 2 of 3 rain days for the year, which is correct here.
I guessing it must be down to the NSLU2 platform, hopefully someone with a NSLU2 will have a look to confirm if its a bug or just your system that is reporting the wrong amount of days for the year!
Good Luck
Mark
YJB
Post by YJB »
There must be definetely an issue with the calculation, right now (on Jan 3rd) my station reports 4 days:
year1_rain4_days 4
This was also the case as of this morning, but I decided to initiate a full aggregate to make sure that everything was in a sane state.
The recomputation did run without any errors:
wmr928fulleval(03.01.2012 08:25:02): recomputation of weather data started.
wmr928fulleval(03.01.2012 19:13:08): recomputation of weather data finished: 43300570 records processed in 38835 seconds (1114 records per second)
It has been raining on all 3 days, so I'm really looking at an unwanted offset of 1 day.
This is an Alix 1D MH running 4.8i (build 6101)
Ysbrand
Manhart
Post by Manhart »
Correction of my posting yesterday. We had rain on all 3 days (1.-3.1.2012) and i should have now 3 raindays. Meteohub still shows 4 raindays today (4.1.2012).
Matthias
I will need to have access to a system that shows this error. would be great if one of you can grant me access to his rig at the week end. I would need ports 22 and 7777. Please give login details to info(at)meteohub.de.
YJB
Post by YJB »
admin wrote:I will need to have access to a system that shows this error. would be great if one of you can grant me access to his rig at the week end. I would need ports 22 and 7777. Please give login details to info(at)meteohub.de.
Done, Ysbrand
That is the funny thing with programming, there always is one more bug ;-)
However, finally I found the one which impacts rain days and temp day types. The bug only appears if you are on a timezone that differs from GMT. The fix will be part of the next update. Doing a recomputation with the new update should heal situations on your Meteohubs. Thanks for giving me access to your rigs.
As I would also like to test the WH-3080 code before releasing the update, it might take until next week.
Manhart
Post by Manhart »
Thanks for your quick help. Regards Matthias
Manhart
Post by Manhart »
Fixed with release 4.9 - thanks. Matthias
