ftp problem
belidi
ftp problem
Post by belidi »
hello
hello
I want to change server, "skynet.be" to server "ovh.com." lorsaue I put in the necessary information Meteohub I get this:
"Error on call system: / usr / bin / ncftpput-S.-V-u tmp" beltxmvf "-p 'XXXXXX' P-21 ftp.bel1.eu / Weather / home / Meteohub / Meteohub upload.test-2> & 1
Error: The file test "Meteohub-upload.test" has not been sent (returned code 1280: Unknown Error). "
with fiezella or "total commander", there is no connection problem
the / meteo is chmod 705
What is my problem?
cgn
Re: ftp problem
Post by cgn »
The folder name ("Dossier Répertoire") should be included in slashes: /meteo/
belidi
Re: ftp problem
Post by belidi »
Sorry
but the error is always the same. exept the code 258
thank you for your help
wfpost
Re: ftp problem
Post by wfpost »
I do not use slashes at all and it works!
belidi
Re: ftp problem
Post by belidi »
no changes :( :evil:
YJB
Re: ftp problem
Post by YJB »
Have you tried to do this from the commandline, using the exact same command?
Testing directly from the commandline gives you the option to add "-d", this will give you full debugging information.
I've seen a similair occurrence before, and it turned out that the ftp server was not allowing file renames. From what I recall ncftpput 1st uploads into a temporary file and then renames to the targetfile. Most likely removing the "-S" option will allow the upload to succeed.
belidi
Re: ftp problem
Post by belidi »
How can I do this command? :?
Re: ftp problem
Please don't use special characters in path or password. Meteohub does not handle that in all cases correctly.
belidi
Re: ftp problem
Post by belidi »
no special characters, only uppercase and lowercase like this: CvBNdfg
belidi
Re: ftp problem
Post by belidi »
My system is iconnect and using "putty" in windows, I can not connect via telnet and enter the command line.
YJB
Re: ftp problem
Post by YJB »
You will need to use ssh to connect to Meteohub. You can use putty for this.
belidi
Re: ftp problem
Post by belidi »
Here is what I get as a response:
meteohub:/usr/bin# ncftpput -S .tmp -V -u "YYyyYY11" -p 'XXxxXXX' -P 21 ftp.bel1.eu /meteo/ /home/meteohub/meteohub-upload.test 2>&1
ncftpput: Could not change to directory /meteo/: server said: Can't change directory to meteo: No such file or directory
meteohub:/usr/bin# ncftpput -S .tmp -V -u "YYyyYYY11" -p 'XXxxXXxx' -P 21 ftp.bel1.eu /meteo /home/meteohub/meteohub-upload.test 2>&1
ncftpput: Could not change to directory /meteo: server said: Can't change directory to meteo: No such file or directory
I if I create another folder like "foo", the answer is even.
after having tried on the new server, I wanted to return to that worked and this is what I get now!!
Error on system call: /usr/bin/ncftpput -S .tmp -V -u "YYYYYYYYY" -p 'XXXxx1111' -P 21 users.skynet.be /meteo/ /home/meteohub/meteohub-upload.test 2>&1
Erreur : Le fichier test "meteohub-upload.test" n'a pas été envoyé (Code retourné 1280: Unknown Error).
YJB
Re: ftp problem
Post by YJB »
It looks like there is no /meteo directory on the ftp server.
Not sure how to debug this server, I could try this myself, but then you will need to create a -temporary- account and password for me. Not sure if that is ossible and if you are able/willing to do so.
This is what I've just tried on my own server using a file that does always exist on MH:
ncftpput -S .tmp -d -V -u username -p secret asterix /tmp /home/meteohub/meteohub.conf
belidi
Re: ftp problem
Post by belidi »
:P Ok, thank you for the time you spent to help me. Force but try to understand, via commands, I found my mistake.
The directory of my hosting provider is not "/ weather /" but www / Weather /.
I was wrong, because my old hoster the directory / Weather / worked.
Again my apologies for any inconvenience :oops:
YJB
Re: ftp problem
Post by YJB »
No problem, always happy to help.
The main thing is that you've figured out the problem!
