I have a WS-1090 from AmbientWeather.com and the SheevaPlug. The display shows all sensor data; however, the SheevaPlug does not detect the sensors. It was working fine until 3/9/2013. At that point the sensors could not be detected. I upgraded the firmware to 4.9t. The Weather Station is detected under USB HID. However the error message displays "Warning: Weather station does not have a sensor assigned on "Sensors" page." On the Sensors page the following is shown:
Station 0 (WH-1080/3080): StationName
Type # ID Name Last Signal Sensor Data
Virtual Sensors
New ID Name Trigger Conversion Last Signal Sensor Data
Additional IDs to be evaluated
As you can see, the sensors are not regiistering with the SheevaPlug, but they do register with the display.
What can I do to fix this?
Thank you,
MDuncan
WS542
SheevaPlug Lost Sensors
Re: SheevaPlug Lost Sensors
could you please post your "weather station" page?
The Weather Station page is attached as well as the Sensors page.
- sensors.jpg (159 KiB) Viewed 18988 times
- weatherstation.jpg (182.5 KiB) Viewed 18988 times
weather station page looks ok to me. additional sensor definition does not make sense here, but as no sensor data is displayed, this is not the root cause of the problem.
could you please post, what "meteohub log" on log files page is reporting?
logger (01.04.2013 14:27:50): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 14:33:20): child process received timeout signal (14).
logger (01.04.2013 14:33:20): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 14:33:25): data logger stopped.
logger (01.04.2013 14:33:25): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 14:33:25): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 14:38:55): child process received timeout signal (14).
logger (01.04.2013 14:38:55): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 14:38:59): data logger stopped.
logger (01.04.2013 14:38:59): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 14:38:59): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 14:44:29): child process received timeout signal (14).
logger (01.04.2013 14:44:29): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 14:44:33): data logger stopped.
logger (01.04.2013 14:44:33): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 14:44:34): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 14:50:04): child process received timeout signal (14).
logger (01.04.2013 14:50:04): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 14:50:08): data logger stopped.
logger (01.04.2013 14:50:08): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 14:50:08): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 14:55:38): child process received timeout signal (14).
logger (01.04.2013 14:55:38): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 14:55:45): data logger stopped.
logger (01.04.2013 14:55:45): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 14:55:46): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 15:01:16): child process received timeout signal (14).
logger (01.04.2013 15:01:16): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 15:01:19): data logger stopped.
logger (01.04.2013 15:01:19): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 15:01:20): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 15:06:50): child process received timeout signal (14).
logger (01.04.2013 15:06:50): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 15:06:53): data logger stopped.
logger (01.04.2013 15:06:53): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 15:06:53): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 15:12:23): child process received timeout signal (14).
logger (01.04.2013 15:12:23): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 15:12:27): data logger stopped.
logger (01.04.2013 15:12:27): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 15:12:27): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 15:17:57): child process received timeout signal (14).
logger (01.04.2013 15:17:57): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 15:18:03): data logger stopped.
logger (01.04.2013 15:18:03): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 15:18:03): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 15:23:33): child process received timeout signal (14).
logger (01.04.2013 15:23:33): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 15:23:36): data logger stopped.
logger (01.04.2013 15:23:36): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 15:23:37): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 15:29:07): child process received timeout signal (14).
logger (01.04.2013 15:29:07): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 15:29:10): data logger stopped.
logger (01.04.2013 15:29:10): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 15:29:11): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 15:34:41): child process received timeout signal (14).
logger (01.04.2013 15:34:41): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 15:34:46): data logger stopped.
logger (01.04.2013 15:34:46): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 15:34:47): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 15:40:17): child process received timeout signal (14).
logger (01.04.2013 15:40:17): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 15:40:20): data logger stopped.
logger (01.04.2013 15:40:20): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 15:40:20): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 15:45:50): child process received timeout signal (14).
logger (01.04.2013 15:45:50): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 15:45:53): data logger stopped.
logger (01.04.2013 15:45:53): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 15:45:54): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 15:51:24): child process received timeout signal (14).
logger (01.04.2013 15:51:24): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 15:51:26): data logger stopped.
logger (01.04.2013 15:51:26): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 15:51:27): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 15:56:57): child process received timeout signal (14).
logger (01.04.2013 15:56:57): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 15:57:00): data logger stopped.
logger (01.04.2013 15:57:00): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 15:57:00): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 16:02:30): child process received timeout signal (14).
logger (01.04.2013 16:02:31): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 16:02:34): data logger stopped.
logger (01.04.2013 16:02:34): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 16:02:34): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 16:08:04): child process received timeout signal (14).
logger (01.04.2013 16:08:04): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 16:08:07): data logger stopped.
logger (01.04.2013 16:08:07): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 16:08:08): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 16:13:38): child process received timeout signal (14).
logger (01.04.2013 16:13:38): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 16:13:41): data logger stopped.
logger (01.04.2013 16:13:41): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 16:13:41): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 16:19:11): child process received timeout signal (14).
logger (01.04.2013 16:19:11): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 16:19:14): data logger stopped.
logger (01.04.2013 16:19:14): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 16:19:15): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 16:24:45): child process received timeout signal (14).
logger (01.04.2013 16:24:45): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 16:24:48): data logger stopped.
logger (01.04.2013 16:24:48): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 16:24:48): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 16:30:18): child process received timeout signal (14).
logger (01.04.2013 16:30:18): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 16:30:22): data logger stopped.
logger (01.04.2013 16:30:22): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 16:30:22): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 16:35:52): child process received timeout signal (14).
logger (01.04.2013 16:35:52): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 16:35:55): data logger stopped.
logger (01.04.2013 16:35:55): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 16:35:56): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 16:41:26): child process received timeout signal (14).
logger (01.04.2013 16:41:26): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 16:41:28): data logger stopped.
logger (01.04.2013 16:41:28): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 16:41:29): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 16:46:59): child process received timeout signal (14).
logger (01.04.2013 16:46:59): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 16:47:01): data logger stopped.
logger (01.04.2013 16:47:01): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 16:47:02): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 16:52:32): child process received timeout signal (14).
logger (01.04.2013 16:52:32): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 16:52:35): data logger stopped.
logger (01.04.2013 16:52:35): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 16:52:35): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 16:58:05): child process received timeout signal (14).
logger (01.04.2013 16:58:05): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 16:58:08): data logger stopped.
logger (01.04.2013 16:58:08): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 16:58:09): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 17:03:39): child process received timeout signal (14).
logger (01.04.2013 17:03:39): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 17:03:42): data logger stopped.
logger (01.04.2013 17:03:42): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 17:03:42): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 17:09:12): child process received timeout signal (14).
logger (01.04.2013 17:09:12): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 17:09:15): data logger stopped.
logger (01.04.2013 17:09:15): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 17:09:15): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 17:14:45): child process received timeout signal (14).
logger (01.04.2013 17:14:45): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 17:14:48): data logger stopped.
logger (01.04.2013 17:14:48): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 17:14:48): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 17:20:18): child process received timeout signal (14).
logger (01.04.2013 17:20:18): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 17:20:21): data logger stopped.
logger (01.04.2013 17:20:21): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 17:20:22): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 17:25:52): child process received timeout signal (14).
logger (01.04.2013 17:25:52): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 17:25:54): data logger stopped.
logger (01.04.2013 17:25:54): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 17:25:55): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 17:31:25): child process received timeout signal (14).
logger (01.04.2013 17:31:25): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 17:31:27): data logger stopped.
logger (01.04.2013 17:31:27): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 17:31:28): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 17:36:58): child process received timeout signal (14).
logger (01.04.2013 17:36:58): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 17:37:00): data logger stopped.
logger (01.04.2013 17:37:00): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 17:37:01): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 17:42:31): child process received timeout signal (14).
logger (01.04.2013 17:42:31): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 17:42:34): data logger stopped.
logger (01.04.2013 17:42:34): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 17:42:34): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 17:48:04): child process received timeout signal (14).
logger (01.04.2013 17:48:04): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 17:48:07): data logger stopped.
logger (01.04.2013 17:48:07): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 17:48:07): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 17:53:37): child process received timeout signal (14).
logger (01.04.2013 17:53:37): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 17:53:40): data logger stopped.
logger (01.04.2013 17:53:40): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 17:53:41): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 17:59:11): child process received timeout signal (14).
logger (01.04.2013 17:59:11): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 17:59:13): data logger stopped.
logger (01.04.2013 17:59:13): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 17:59:14): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 18:04:44): child process received timeout signal (14).
logger (01.04.2013 18:04:44): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 18:04:47): data logger stopped.
logger (01.04.2013 18:04:47): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 18:04:48): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 18:10:18): child process received timeout signal (14).
logger (01.04.2013 18:10:18): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 18:10:21): data logger stopped.
logger (01.04.2013 18:10:21): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 18:10:21): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 18:15:51): child process received timeout signal (14).
logger (01.04.2013 18:15:51): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 18:15:54): data logger stopped.
logger (01.04.2013 18:15:54): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 18:15:54): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 18:21:24): child process received timeout signal (14).
logger (01.04.2013 18:21:24): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 18:21:27): data logger stopped.
logger (01.04.2013 18:21:27): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 18:21:28): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 18:26:58): child process received timeout signal (14).
logger (01.04.2013 18:26:58): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 18:27:01): data logger stopped.
logger (01.04.2013 18:27:01): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 18:27:01): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 18:32:31): child process received timeout signal (14).
logger (01.04.2013 18:32:31): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 18:32:34): data logger stopped.
logger (01.04.2013 18:32:34): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 18:32:34): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 18:38:04): child process received timeout signal (14).
logger (01.04.2013 18:38:04): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 18:38:07): data logger stopped.
logger (01.04.2013 18:38:07): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 18:38:08): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 18:43:38): child process received timeout signal (14).
logger (01.04.2013 18:43:38): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 18:43:40): data logger stopped.
logger (01.04.2013 18:43:40): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 18:43:41): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 18:49:11): child process received timeout signal (14).
logger (01.04.2013 18:49:11): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 18:49:13): data logger stopped.
logger (01.04.2013 18:49:14): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 18:49:14): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 18:54:44): child process received timeout signal (14).
logger (01.04.2013 18:54:44): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 18:54:47): data logger stopped.
logger (01.04.2013 18:54:47): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 18:54:47): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 19:00:17): child process received timeout signal (14).
logger (01.04.2013 19:00:17): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 19:00:20): data logger stopped.
logger (01.04.2013 19:00:20): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 19:00:21): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 19:05:51): child process received timeout signal (14).
logger (01.04.2013 19:05:51): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 19:05:54): data logger stopped.
logger (01.04.2013 19:05:54): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 19:05:54): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 19:11:24): child process received timeout signal (14).
logger (01.04.2013 19:11:24): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 19:11:27): data logger stopped.
logger (01.04.2013 19:11:27): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 19:11:28): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 19:16:58): child process received timeout signal (14).
logger (01.04.2013 19:16:58): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 19:17:01): data logger stopped.
logger (01.04.2013 19:17:01): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 19:17:01): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 19:22:31): child process received timeout signal (14).
logger (01.04.2013 19:22:31): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 19:22:34): data logger stopped.
logger (01.04.2013 19:22:34): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 19:22:34): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 19:28:04): child process received timeout signal (14).
logger (01.04.2013 19:28:04): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 19:28:07): data logger stopped.
logger (01.04.2013 19:28:07): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 19:28:07): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 19:33:37): child process received timeout signal (14).
logger (01.04.2013 19:33:37): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 19:33:40): data logger stopped.
logger (01.04.2013 19:33:40): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 19:33:40): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 19:39:10): child process received timeout signal (14).
logger (01.04.2013 19:39:10): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 19:39:13): data logger stopped.
logger (01.04.2013 19:39:13): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 19:39:14): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 19:44:44): child process received timeout signal (14).
logger (01.04.2013 19:44:44): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 19:44:46): data logger stopped.
logger (01.04.2013 19:44:46): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 19:44:47): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 19:50:17): child process received timeout signal (14).
logger (01.04.2013 19:50:17): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 19:50:21): data logger stopped.
logger (01.04.2013 19:50:21): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 19:50:22): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 19:55:52): child process received timeout signal (14).
logger (01.04.2013 19:55:52): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 19:55:55): data logger stopped.
logger (01.04.2013 19:55:55): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 19:55:55): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 20:01:25): child process received timeout signal (14).
logger (01.04.2013 20:01:25): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 20:01:28): data logger stopped.
logger (01.04.2013 20:01:28): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 20:01:28): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 20:06:58): child process received timeout signal (14).
logger (01.04.2013 20:06:58): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 20:07:01): data logger stopped.
logger (01.04.2013 20:07:01): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 20:07:02): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 20:12:32): child process received timeout signal (14).
logger (01.04.2013 20:12:32): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 20:12:34): data logger stopped.
logger (01.04.2013 20:12:34): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 20:12:35): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 20:18:05): child process received timeout signal (14).
logger (01.04.2013 20:18:05): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 20:18:08): data logger stopped.
logger (01.04.2013 20:18:08): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 20:18:08): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 20:23:38): child process received timeout signal (14).
logger (01.04.2013 20:23:38): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 20:23:41): data logger stopped.
logger (01.04.2013 20:23:41): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 20:23:41): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 20:29:11): child process received timeout signal (14).
logger (01.04.2013 20:29:11): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 20:29:14): data logger stopped.
logger (01.04.2013 20:29:14): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 20:29:15): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 20:34:45): child process received timeout signal (14).
logger (01.04.2013 20:34:45): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 20:34:48): data logger stopped.
logger (01.04.2013 20:34:48): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 20:34:48): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 20:40:18): child process received timeout signal (14).
logger (01.04.2013 20:40:18): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 20:40:21): data logger stopped.
logger (01.04.2013 20:40:21): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 20:40:22): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 20:45:52): child process received timeout signal (14).
logger (01.04.2013 20:45:52): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 20:45:55): data logger stopped.
logger (01.04.2013 20:45:55): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 20:45:55): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 20:51:25): child process received timeout signal (14).
logger (01.04.2013 20:51:25): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 20:51:27): data logger stopped.
logger (01.04.2013 20:51:27): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 20:51:28): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 20:56:58): child process received timeout signal (14).
logger (01.04.2013 20:56:58): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 20:57:01): data logger stopped.
logger (01.04.2013 20:57:01): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 20:57:01): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 21:02:31): child process received timeout signal (14).
logger (01.04.2013 21:02:31): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 21:02:34): data logger stopped.
logger (01.04.2013 21:02:34): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 21:02:34): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 21:08:04): child process received timeout signal (14).
logger (01.04.2013 21:08:04): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 21:08:07): data logger stopped.
logger (01.04.2013 21:08:07): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 21:08:08): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 21:13:38): child process received timeout signal (14).
logger (01.04.2013 21:13:38): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 21:13:40): data logger stopped.
logger (01.04.2013 21:13:40): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 21:13:41): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 21:19:11): child process received timeout signal (14).
logger (01.04.2013 21:19:11): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 21:19:14): data logger stopped.
logger (01.04.2013 21:19:14): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 21:19:14): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 21:24:44): child process received timeout signal (14).
logger (01.04.2013 21:24:44): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 21:24:47): data logger stopped.
logger (01.04.2013 21:24:47): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 21:24:48): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 21:30:18): child process received timeout signal (14).
logger (01.04.2013 21:30:18): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 21:30:21): data logger stopped.
logger (01.04.2013 21:30:21): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 21:30:22): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 21:35:52): child process received timeout signal (14).
logger (01.04.2013 21:35:52): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 21:35:54): data logger stopped.
logger (01.04.2013 21:35:54): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 21:35:55): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 21:41:25): child process received timeout signal (14).
logger (01.04.2013 21:41:25): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 21:41:28): data logger stopped.
logger (01.04.2013 21:41:28): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 21:41:28): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 21:46:58): child process received timeout signal (14).
logger (01.04.2013 21:46:58): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 21:47:04): data logger stopped.
logger (01.04.2013 21:47:04): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 21:47:05): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 21:52:35): child process received timeout signal (14).
logger (01.04.2013 21:52:35): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 21:52:39): data logger stopped.
logger (01.04.2013 21:52:39): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 21:52:39): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 21:58:09): child process received timeout signal (14).
logger (01.04.2013 21:58:09): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 21:58:12): data logger stopped.
logger (01.04.2013 21:58:12): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 21:58:12): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 22:03:42): child process received timeout signal (14).
logger (01.04.2013 22:03:42): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 22:03:45): data logger stopped.
logger (01.04.2013 22:03:45): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 22:03:46): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 22:09:16): child process received timeout signal (14).
logger (01.04.2013 22:09:16): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 22:09:18): data logger stopped.
logger (01.04.2013 22:09:18): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 22:09:19): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 22:14:49): child process received timeout signal (14).
logger (01.04.2013 22:14:49): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 22:14:51): data logger stopped.
logger (01.04.2013 22:14:51): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 22:14:52): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 22:20:22): child process received timeout signal (14).
logger (01.04.2013 22:20:22): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 22:20:24): data logger stopped.
logger (01.04.2013 22:20:24): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 22:20:24): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 22:25:54): child process received timeout signal (14).
logger (01.04.2013 22:25:55): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 22:25:58): data logger stopped.
logger (01.04.2013 22:25:58): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 22:25:58): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 22:31:28): child process received timeout signal (14).
logger (01.04.2013 22:31:28): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 22:31:31): data logger stopped.
logger (01.04.2013 22:31:31): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 22:31:31): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 22:37:01): child process received timeout signal (14).
logger (01.04.2013 22:37:01): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 22:37:04): data logger stopped.
logger (01.04.2013 22:37:04): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 22:37:04): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 22:42:34): child process received timeout signal (14).
logger (01.04.2013 22:42:34): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 22:42:37): data logger stopped.
logger (01.04.2013 22:42:37): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 22:42:37): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 22:48:07): child process received timeout signal (14).
logger (01.04.2013 22:48:07): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 22:48:10): data logger stopped.
logger (01.04.2013 22:48:10): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 22:48:11): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 22:53:41): child process received timeout signal (14).
logger (01.04.2013 22:53:41): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 22:53:44): data logger stopped.
logger (01.04.2013 22:53:44): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 22:53:44): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 22:59:14): child process received timeout signal (14).
logger (01.04.2013 22:59:14): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 22:59:17): data logger stopped.
logger (01.04.2013 22:59:17): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 22:59:17): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 23:04:47): child process received timeout signal (14).
logger (01.04.2013 23:04:47): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 23:04:50): data logger stopped.
logger (01.04.2013 23:04:50): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 23:04:51): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 23:10:21): child process received timeout signal (14).
logger (01.04.2013 23:10:21): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 23:10:24): data logger stopped.
logger (01.04.2013 23:10:24): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 23:10:24): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 23:15:54): child process received timeout signal (14).
logger (01.04.2013 23:15:54): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 23:15:57): data logger stopped.
logger (01.04.2013 23:15:57): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 23:15:57): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 23:21:27): child process received timeout signal (14).
logger (01.04.2013 23:21:28): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 23:21:31): data logger stopped.
logger (01.04.2013 23:21:31): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 23:21:31): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 23:27:01): child process received timeout signal (14).
logger (01.04.2013 23:27:01): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 23:27:04): data logger stopped.
logger (01.04.2013 23:27:04): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 23:27:04): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 23:32:34): child process received timeout signal (14).
logger (01.04.2013 23:32:34): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 23:32:37): data logger stopped.
logger (01.04.2013 23:32:37): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 23:32:38): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 23:38:08): child process received timeout signal (14).
logger (01.04.2013 23:38:08): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 23:38:11): data logger stopped.
logger (01.04.2013 23:38:11): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 23:38:12): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 23:43:42): child process received timeout signal (14).
logger (01.04.2013 23:43:42): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 23:43:46): data logger stopped.
logger (01.04.2013 23:43:46): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 23:43:46): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 23:49:16): child process received timeout signal (14).
logger (01.04.2013 23:49:16): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 23:49:19): data logger stopped.
logger (01.04.2013 23:49:19): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 23:49:20): connect station 0 (WH-1080/3080 via USB HID).
logger (01.04.2013 23:54:50): child process received timeout signal (14).
logger (01.04.2013 23:54:50): disconnect station 0 (WH-1080/3080).
logger (01.04.2013 23:54:52): data logger stopped.
logger (01.04.2013 23:54:52): data logger (version 4.9t, build 1216) started.
logger (01.04.2013 23:54:53): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 00:00:23): child process received timeout signal (14).
logger (02.04.2013 00:00:23): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 00:00:25): data logger stopped.
logger (02.04.2013 00:00:25): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 00:00:26): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 00:05:56): child process received timeout signal (14).
logger (02.04.2013 00:05:56): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 00:05:59): data logger stopped.
logger (02.04.2013 00:05:59): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 00:05:59): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 00:11:29): child process received timeout signal (14).
logger (02.04.2013 00:11:29): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 00:11:32): data logger stopped.
logger (02.04.2013 00:11:32): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 00:11:33): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 00:17:03): child process received timeout signal (14).
logger (02.04.2013 00:17:05): data logger stopped.
logger (02.04.2013 00:17:05): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 00:17:06): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 00:22:36): child process received timeout signal (14).
logger (02.04.2013 00:22:36): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 00:22:39): data logger stopped.
logger (02.04.2013 00:22:39): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 00:22:39): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 00:28:09): child process received timeout signal (14).
logger (02.04.2013 00:28:09): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 00:28:12): data logger stopped.
logger (02.04.2013 00:28:12): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 00:28:13): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 00:33:43): child process received timeout signal (14).
logger (02.04.2013 00:33:43): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 00:33:45): data logger stopped.
logger (02.04.2013 00:33:45): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 00:33:46): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 00:39:16): child process received timeout signal (14).
logger (02.04.2013 00:39:16): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 00:39:19): data logger stopped.
logger (02.04.2013 00:39:19): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 00:39:19): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 00:44:49): child process received timeout signal (14).
logger (02.04.2013 00:44:49): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 00:44:52): data logger stopped.
logger (02.04.2013 00:44:52): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 00:44:53): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 00:50:23): child process received timeout signal (14).
logger (02.04.2013 00:50:23): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 00:50:25): data logger stopped.
logger (02.04.2013 00:50:25): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 00:50:26): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 00:55:56): child process received timeout signal (14).
logger (02.04.2013 00:55:56): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 00:55:59): data logger stopped.
logger (02.04.2013 00:55:59): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 00:55:59): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 01:01:29): child process received timeout signal (14).
logger (02.04.2013 01:01:29): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 01:01:32): data logger stopped.
logger (02.04.2013 01:01:32): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 01:01:33): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 01:07:03): child process received timeout signal (14).
logger (02.04.2013 01:07:03): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 01:07:05): data logger stopped.
logger (02.04.2013 01:07:05): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 01:07:06): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 01:12:36): child process received timeout signal (14).
logger (02.04.2013 01:12:36): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 01:12:38): data logger stopped.
logger (02.04.2013 01:12:39): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 01:12:39): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 01:18:09): child process received timeout signal (14).
logger (02.04.2013 01:18:09): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 01:18:12): data logger stopped.
logger (02.04.2013 01:18:12): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 01:18:12): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 01:23:42): child process received timeout signal (14).
logger (02.04.2013 01:23:42): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 01:23:45): data logger stopped.
logger (02.04.2013 01:23:45): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 01:23:46): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 01:29:16): child process received timeout signal (14).
logger (02.04.2013 01:29:16): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 01:29:18): data logger stopped.
logger (02.04.2013 01:29:18): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 01:29:19): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 01:34:49): child process received timeout signal (14).
logger (02.04.2013 01:34:49): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 01:34:52): data logger stopped.
logger (02.04.2013 01:34:52): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 01:34:53): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 01:40:23): child process received timeout signal (14).
logger (02.04.2013 01:40:23): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 01:40:25): data logger stopped.
logger (02.04.2013 01:40:25): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 01:40:26): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 01:45:56): child process received timeout signal (14).
logger (02.04.2013 01:45:56): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 01:45:58): data logger stopped.
logger (02.04.2013 01:45:58): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 01:45:59): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 01:51:29): child process received timeout signal (14).
logger (02.04.2013 01:51:29): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 01:51:31): data logger stopped.
logger (02.04.2013 01:51:32): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 01:51:32): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 01:57:02): child process received timeout signal (14).
logger (02.04.2013 01:57:02): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 01:57:05): data logger stopped.
logger (02.04.2013 01:57:05): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 01:57:06): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 02:02:36): child process received timeout signal (14).
logger (02.04.2013 02:02:36): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 02:02:38): data logger stopped.
logger (02.04.2013 02:02:38): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 02:02:39): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 02:08:09): child process received timeout signal (14).
logger (02.04.2013 02:08:09): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 02:08:12): data logger stopped.
logger (02.04.2013 02:08:12): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 02:08:13): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 02:13:43): child process received timeout signal (14).
logger (02.04.2013 02:13:43): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 02:13:45): data logger stopped.
logger (02.04.2013 02:13:45): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 02:13:46): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 02:19:16): child process received timeout signal (14).
logger (02.04.2013 02:19:16): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 02:19:18): data logger stopped.
logger (02.04.2013 02:19:18): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 02:19:19): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 02:24:49): child process received timeout signal (14).
logger (02.04.2013 02:24:49): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 02:24:51): data logger stopped.
logger (02.04.2013 02:24:51): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 02:24:52): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 02:30:22): child process received timeout signal (14).
logger (02.04.2013 02:30:22): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 02:30:25): data logger stopped.
logger (02.04.2013 02:30:25): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 02:30:25): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 02:35:55): child process received timeout signal (14).
logger (02.04.2013 02:35:56): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 02:35:58): data logger stopped.
logger (02.04.2013 02:35:58): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 02:35:58): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 02:41:28): child process received timeout signal (14).
logger (02.04.2013 02:41:28): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 02:41:31): data logger stopped.
logger (02.04.2013 02:41:31): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 02:41:32): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 02:47:02): child process received timeout signal (14).
logger (02.04.2013 02:47:02): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 02:47:04): data logger stopped.
logger (02.04.2013 02:47:04): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 02:47:05): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 02:52:35): child process received timeout signal (14).
logger (02.04.2013 02:52:35): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 02:52:38): data logger stopped.
logger (02.04.2013 02:52:38): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 02:52:38): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 02:58:08): child process received timeout signal (14).
logger (02.04.2013 02:58:08): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 02:58:11): data logger stopped.
logger (02.04.2013 02:58:11): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 02:58:12): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 03:03:42): child process received timeout signal (14).
logger (02.04.2013 03:03:42): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 03:03:45): data logger stopped.
logger (02.04.2013 03:03:45): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 03:03:45): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 03:09:15): child process received timeout signal (14).
logger (02.04.2013 03:09:15): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 03:09:18): data logger stopped.
logger (02.04.2013 03:09:18): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 03:09:18): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 03:14:48): child process received timeout signal (14).
logger (02.04.2013 03:14:48): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 03:14:52): data logger stopped.
logger (02.04.2013 03:14:52): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 03:14:52): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 03:20:22): child process received timeout signal (14).
logger (02.04.2013 03:20:22): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 03:20:25): data logger stopped.
logger (02.04.2013 03:20:25): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 03:20:25): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 03:25:55): child process received timeout signal (14).
logger (02.04.2013 03:25:55): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 03:25:58): data logger stopped.
logger (02.04.2013 03:25:58): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 03:25:59): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 03:31:29): child process received timeout signal (14).
logger (02.04.2013 03:31:29): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 03:31:31): data logger stopped.
logger (02.04.2013 03:31:31): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 03:31:32): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 03:37:02): child process received timeout signal (14).
logger (02.04.2013 03:37:02): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 03:37:05): data logger stopped.
logger (02.04.2013 03:37:05): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 03:37:05): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 03:42:35): child process received timeout signal (14).
logger (02.04.2013 03:42:35): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 03:42:38): data logger stopped.
logger (02.04.2013 03:42:38): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 03:42:38): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 03:48:08): child process received timeout signal (14).
logger (02.04.2013 03:48:08): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 03:48:11): data logger stopped.
logger (02.04.2013 03:48:11): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 03:48:12): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 03:53:42): child process received timeout signal (14).
logger (02.04.2013 03:53:42): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 03:53:44): data logger stopped.
logger (02.04.2013 03:53:44): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 03:53:45): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 03:59:15): child process received timeout signal (14).
logger (02.04.2013 03:59:15): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 03:59:19): data logger stopped.
logger (02.04.2013 03:59:19): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 03:59:20): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 04:04:50): child process received timeout signal (14).
logger (02.04.2013 04:04:50): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 04:04:52): data logger stopped.
logger (02.04.2013 04:04:53): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 04:04:53): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 04:10:23): child process received timeout signal (14).
logger (02.04.2013 04:10:23): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 04:10:27): data logger stopped.
logger (02.04.2013 04:10:27): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 04:10:27): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 04:15:57): child process received timeout signal (14).
logger (02.04.2013 04:15:57): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 04:16:00): data logger stopped.
logger (02.04.2013 04:16:00): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 04:16:01): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 04:21:31): child process received timeout signal (14).
logger (02.04.2013 04:21:31): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 04:21:34): data logger stopped.
logger (02.04.2013 04:21:34): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 04:21:34): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 04:27:04): child process received timeout signal (14).
logger (02.04.2013 04:27:04): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 04:27:07): data logger stopped.
logger (02.04.2013 04:27:07): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 04:27:08): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 04:32:38): child process received timeout signal (14).
logger (02.04.2013 04:32:38): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 04:32:41): data logger stopped.
logger (02.04.2013 04:32:41): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 04:32:41): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 04:38:11): child process received timeout signal (14).
logger (02.04.2013 04:38:11): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 04:38:14): data logger stopped.
logger (02.04.2013 04:38:14): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 04:38:15): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 04:43:45): child process received timeout signal (14).
logger (02.04.2013 04:43:45): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 04:43:48): data logger stopped.
logger (02.04.2013 04:43:48): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 04:43:48): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 04:49:18): child process received timeout signal (14).
logger (02.04.2013 04:49:18): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 04:49:21): data logger stopped.
logger (02.04.2013 04:49:21): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 04:49:22): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 04:54:52): child process received timeout signal (14).
logger (02.04.2013 04:54:52): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 04:54:54): data logger stopped.
logger (02.04.2013 04:54:54): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 04:54:55): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 05:00:25): child process received timeout signal (14).
logger (02.04.2013 05:00:25): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 05:00:28): data logger stopped.
logger (02.04.2013 05:00:28): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 05:00:28): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 05:05:58): child process received timeout signal (14).
logger (02.04.2013 05:05:58): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 05:06:01): data logger stopped.
logger (02.04.2013 05:06:01): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 05:06:02): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 05:11:32): child process received timeout signal (14).
logger (02.04.2013 05:11:32): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 05:11:35): data logger stopped.
logger (02.04.2013 05:11:35): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 05:11:35): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 05:17:05): child process received timeout signal (14).
logger (02.04.2013 05:17:05): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 05:17:08): data logger stopped.
logger (02.04.2013 05:17:08): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 05:17:09): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 05:22:39): child process received timeout signal (14).
logger (02.04.2013 05:22:39): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 05:22:41): data logger stopped.
logger (02.04.2013 05:22:41): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 05:22:42): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 05:28:12): child process received timeout signal (14).
logger (02.04.2013 05:28:12): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 05:28:14): data logger stopped.
logger (02.04.2013 05:28:14): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 05:28:15): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 05:33:45): child process received timeout signal (14).
logger (02.04.2013 05:33:45): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 05:33:47): data logger stopped.
logger (02.04.2013 05:33:47): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 05:33:48): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 05:39:18): child process received timeout signal (14).
logger (02.04.2013 05:39:18): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 05:39:21): data logger stopped.
logger (02.04.2013 05:39:21): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 05:39:22): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 05:44:52): child process received timeout signal (14).
logger (02.04.2013 05:44:52): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 05:44:54): data logger stopped.
logger (02.04.2013 05:44:54): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 05:44:55): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 05:50:25): child process received timeout signal (14).
logger (02.04.2013 05:50:25): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 05:50:28): data logger stopped.
logger (02.04.2013 05:50:28): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 05:50:28): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 05:55:58): child process received timeout signal (14).
logger (02.04.2013 05:55:58): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 05:56:01): data logger stopped.
logger (02.04.2013 05:56:01): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 05:56:02): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 06:01:32): child process received timeout signal (14).
logger (02.04.2013 06:01:32): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 06:01:35): data logger stopped.
logger (02.04.2013 06:01:35): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 06:01:35): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 06:07:05): child process received timeout signal (14).
logger (02.04.2013 06:07:05): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 06:07:08): data logger stopped.
logger (02.04.2013 06:07:08): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 06:07:09): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 06:12:39): child process received timeout signal (14).
logger (02.04.2013 06:12:39): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 06:12:41): data logger stopped.
logger (02.04.2013 06:12:41): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 06:12:42): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 06:18:12): child process received timeout signal (14).
logger (02.04.2013 06:18:12): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 06:18:15): data logger stopped.
logger (02.04.2013 06:18:15): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 06:18:15): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 06:23:45): child process received timeout signal (14).
logger (02.04.2013 06:23:45): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 06:23:48): data logger stopped.
logger (02.04.2013 06:23:48): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 06:23:49): connect station 0 (WH-1080/3080 via USB HID).
logger (02.04.2013 06:29:19): child process received timeout signal (14).
logger (02.04.2013 06:29:19): disconnect station 0 (WH-1080/3080).
logger (02.04.2013 06:29:22): data logger stopped.
logger (02.04.2013 06:29:22): data logger (version 4.9t, build 1216) started.
logger (02.04.2013 06:29:22): connect station 0 (WH-1080/3080 via USB HID
Re: SheevaPlug Lost Sensors
strange, your station simply does not report any data.
Please reset the station by making it powerless, disconnect
from weather hub, even pull out batteries and wait a bit.
These stations can hang up on certain conditions.
GREAT JOB!
The weather station display showed readings. The weather station was detected on the SheevaPlug. However, the sensors could not be seen. I thought the problem was in the SheevaPlug or the software, while it was in the weather station receiver all along.
Thanks for your awesome help. We are now online at http://www.wunderground.com/wundermap/ as KVAFTEUS2.
Keep up the great work!
MDuncan
WS542
MDuncan
WS542
The SheevaPlug has lost the sensors again and now the username and password do not work. I am on v4.9p. Please help.
I would recommend to go to 4.9u, which has some additional fixes.
When you lost your login credentials, please follow this recipe:
viewtopic.php?f=23&t=5335
System is up now thanks.
MDuncan
WS542
MDuncan
WS542
