Davis VP2 Envoy supported?
cavantage
Post by cavantage »
Is the Vantage Pro2 Envoy (USB - 6316) officially supported by MeteoBridge?
Things appear to be working on my new WeatherBridge, but there are problems with the display at Weather Underground - things aren't quite right. In the WeatherBridge startup messages (below), the last two concern me. Do they indicate a problem? It seems otherwise that things are working, but for some display issues at WU - I have a help request in them for it.
Thank you for your help!
wnetd (18.01.2014 16:34:57): process started.
logger (18.01.2014 16:34:58): Historical data loaded (15 records).
logger (18.01.2014 16:34:58): data logger (version 4.9w, build 3148) started.
logger (18.01.2014 16:34:59): connect station 0 (Vantage via USB serial).
logger (18.01.2014 16:35:00): station 0 (Vantage), wakeup sent.
logger (18.01.2014 16:35:00): station 0 (Vantage), internal logger activated.
logger (18.01.2014 16:35:00): station 0 (Vantage), syncing.
logger (18.01.2014 16:35:10): station 0 (Vantage), gettime request sent.
logger (18.01.2014 16:35:10): station 0 (Vantage), time offset of Vantage: -16 minutes
logger (18.01.2014 16:35:10): station 0 (Vantage), eeprom request sent.
logger (18.01.2014 16:35:10): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (18.01.2014 16:35:10): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (18.01.2014 16:35:10): station 0 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (18.01.2014 16:35:10): station 0 (Vantage), firmware version request sent.
logger (18.01.2014 16:35:26): station 0 (Vantage), no firmware version returned.
logger (18.01.2014 16:35:26): station 0 (Vantage), no reading of Vantage's internal logger.
Re: Davis VP2 Envoy supported?
Yes, Envoy is just a Vantage console without a display. From a prototcol point of view the devices are identical.
Log file does look ok. What are your WU problems in detail?
cavantage
Post by cavantage »
It looks like everything's OK now - must have been at their end when I changed things. Thanks for confirming that the Envoy is valid! Sure is nice to have one less computer running!
