davis vue help connect with WeatherLink IP meteohub *solved*
somiedo
Post by somiedo »
Hello, good evening. I need help please.
I have a vue davis meteorological station and WeatherLink IP, also I have meteohub with Alix 3D3. Is there any way to connect my davis vue with meteohub Alix 3D3? I've tried everything. But I do not get it to work.
What I have tried is to connect my Alix 3D3 meteohub the internet router and one of these ports also connect the WeatherLink Ip davis vue. When I set my meteohub in the meteorological station, I put the IP that has davis vue in my router, but I can not be connected. What am I doing wrong? I need help, thank you very much.
Best regards from Spain.
somiedo
Re: davis vue help connect with WeatherLink IP meteohub
please provide a screen dump of your Meteohub's "weather station" page.
Sounds like a rather simple configuration error.
somiedo
Post by somiedo »
ok, tomorrow I'll make a screenshot of the error and posting in forum. thank you very much
somiedo
Post by somiedo »
This is the screenshot of the settings to meteohub davis vue:
The ipa 192.168.1.35 is the IP that my router gives the weather station davis vue. What is wrong?
somiedo
Post by somiedo »
this is the capture
somiedo
Post by somiedo »
this is .
captura 1 meteohub peq.jpg (164.75 KiB) Viewed 10285 times
wrong setting "TCP/IP Meteohub", correct for WLIP is "TCP/IP".
somiedo
Post by somiedo »
hello, thank you very much for the instructions. I changed the ip settings, but still can not connect. I made a screenshot of the error message that comes out ..
captura meteohub 2.gif (155.28 KiB) Viewed 10258 times
somiedo
Post by somiedo »
other capture..
captura meteohub 3.gif (241.56 KiB) Viewed 10257 times
Meteohub log indicates that you still have "TCP/IP Meteohub" selected.
As said, that won't work. Please change that.
What is the port your WLIP is listening to? 22222?
somiedo
Post by somiedo »
Hello, good morning administrator. Knocked the weatherstation and I went back to add, this time with the setup tcp / Ip, I added the ip manually with the same access port that weather link (22222) 192.168.1.38:22222. And it all works perfectly!!! Administrator thank you very much for your help and your time spent on this problem. I am very grateful.
best regards
Antonio Segura
capture final ok.gif (200.21 KiB) Viewed 10232 times
