Yearly Graph Problem **SOLVED**
Luca
Post by Luca »
Dear all, I need you expert knowledge!
I open a new topic, since I have a small problem with my Meteohub software.
Short history: I installed my Davis VP last year (1 Feb 2013) and Meteohub run correctly during the whole 2013 and till january 2014. Last month, I noted that the software was no more able to plot the data of last year (see attacched images). Firstly I though that the data has been deleted from the archive, but when I export them, I can retrieve the data since 1. feb. 2013.
Someone could provide some inputs, please?
Thank you very much,
Luca
YJB
Re: Yearly Graph Problem
Post by YJB »
Since the graphs are using aggregated data, the 1st thing I would try is to run a "recompute" (on the maintenance tab). Once that process is finished try it again.
If not, please list the settings that you are using to generate the graph (aka the definition).
Ysbrand
Luca
Post by Luca »
Dear Ysbrand,
I going to try to follow your advices and see if I can solve the problem.
I'll let you know.
Thank you very much and have a nice day,
Luca
Luca
Re: Yearly Graph Problem **SOLVED**
Post by Luca »
Hi Ysbrand,
actually after the recomputation the plots are visualized correctly. I suspect, that the problem was an interrupted recalculation that did last month.
Thank you very much for the suggestion,
Luca
Example monthly rain since feb. 2013:
