Update 4.9y
What's hot...
Update 4.9y
Update to Meteohub V4.9y (NSLU2, x86, SheevaPlug, iConnect, DC01) brings these features:
  • fixes a bug when sending mails with SSL based protocols on x86 Meteohubs (segfault of sendmail)
  • adds Meteostick as a new weather station. Meteostick comes in the shape of a USB stick and can read RF signals from up to eight Davis weather stations. By that it is not blocking the Davis datalogger in the console and you can run Meteohub without interfering with your traditional Davis PC connectivity. More details about this new Davis connectivity option can be found at http://www.smartbedded.com/meteostick
  • fixes a bug in automated update process introduced with 4.9w and 4.9x
When you are running 4.9w or 4.9x you have to go through the manual update process this time.
Please find more details here: viewtopic.php?f=23&t=9704
Update Link: http://www.meteohub.de/files/update-v4.9y.upd
Update Link for NSLU2: http://www.meteohub.de/files/update-nslu2-v4.9y.upd
The attachment front-800.png is no longer available
HWTest
Re: Update 4.9y
Post by HWTest »
This error viewtopic.php?f=14&t=9567#p14724 is still there.
Edit: Nevermind, my fault ...
dodo-dk
Re: Update 4.9y
Post by dodo-dk »
Hi, with this update i Meteohub can´t send Emails anymore.
With TLS is coming this Problem:
Mail send failed: Invalid peer certificate (error 18)#0 (null)#******@*******.com: 0 (null)
Without TLS:
Mail send failed: 0 (null)#******@*******.com: 554 #******@*******.com#: Relay access denied #
I downgraded to Version 4.9w but the Problem remains.
Please help me.
Dodo
Re: Update 4.9y
which platform?
When you deselect TLS the port will also change, please check with your email provider.
dodo-dk
Re: Update 4.9y
Post by dodo-dk »
Platform is the Virtual System x86 on VirtualBox.
With my iPhone it works with TLS and Port 587 or without TLS with Port 25.
On my Meteohub i have use without TLS (Port 25) for 2 Years without a problem.
But now it don´t work anymore.
Thank you
Re: Update 4.9y
could you please browse to "ip-of-your-meteohub/cgi-bin/help.cgi"?
This might allow me to login and check what the problem is.
dodo-dk
Re: Update 4.9y
Post by dodo-dk »
Ok
open ssh tunnel to meteohub support
done
Danke
Re: Update 4.9y
doesnt work... please update again to 4.9y (cyclic updates are enabled) and then browse to the URL again.
dodo-dk
Re: Update 4.9y
Post by dodo-dk »
Ok, done.
i can open a port (ssh) for you.
Re: Update 4.9y
ok, lets do it that way, please mail credentials to "info(at)meteohub.de". port 22 would be great.
dodo-dk
Re: Update 4.9y
Post by dodo-dk »
Done, thank you.
