AKITIO USB Problems
Manisflight
AKITIO USB Problems
Post by Manisflight »
I installed meteohub on new AKITIO with new license. I connect now USB OAK Baro and ISS. OAK Baro is sucessfully recognized but after some hours Sensor was missing.
logger (08.07.2014 08:17:43): connect station 0 (OAK Baro via USB HID).
logger (08.07.2014 08:17:43): station 1 (ISS direct), can't set attributes of device x: Invalid argument
logger (08.07.2014 08:17:43): error while waiting for data from weather stations
logger (08.07.2014 08:17:43): disconnect station 0 (OAK Baro): wrap-up
logger (08.07.2014 08:17:44): data logger stopped.
Direct Connection kit was also not recognized on USB Port, error is also on log file. I try to restart, shutdown and restart, but allways same Problems.
What can i do now, anybody have a solution?
Thank you!
Re: AKITIO USB Problems
DC01 needs USB hub.
Manisflight
Thank for your answer, i try with USB Hub 2.0 but ISS with your direct Interface doesent work.
My ISS Direct Interface is from wetherboxx, i now upgrade to DC01, i think it also must work with DC01?
Logfile:
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Start USB clocks
oxnas-ehci oxnas-ehci.0: OXNAS EHCI Host Controller
oxnas-ehci oxnas-ehci.0: new USB bus registered, assigned bus number 1
oxnas-ehci oxnas-ehci.0: irq 39, io mem 0x00000000
oxnas-ehci oxnas-ehci.0: USB 0.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usb 1-1: new high speed USB device using oxnas-ehci and address 2
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usb 1-1.4: new full speed USB device using oxnas-ehci and address 3
usb 1-1.4: configuration #1 chosen from 1 choice
generic-usb 0003:1B67:0002.0001: claimed by neither input, hiddev nor hidraw
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
watchdog_timer_action() possible CSUM error, tx_timeout_count = 0
CSUM Watchdog triggered
GMAC:reset 1405001185
USB:
Bus 001 Device 003: ID 1b67:0002
Bus 001 Device 002: ID 1a40:0101 TERMINUS TECHNOLOGY INC. USB-2.0 4-Port HUB
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Looking in more detail onto your first mail, it looks like you failed to configure "ISS direct" as "USB serial" and giving it a proper device name like "/dev/ttyUSB0" or so. Please send screen dump of "weather station" page.
Manisflight
i cant choice device name like "/dev/ttyUSB0" or so
Then ISS direct adapter is not recongized by your Meteohub system. Can be a defective adapter, or a defective DC01, or a missing driver.
