Battery Backup
david.delano
Battery Backup
Post by david.delano »
I have a TP-Link running Meteobridge (from Ambient Weather, if I remember right).
I've recently gone through a power outage and lost data. I can see from other posts that other people have had the same issue recently.
The TP-Link draws power off of USB. Has anyone tried/would it be possible to put one of the USB power packs in line to keep the Meteobridge running when the power goes down? This would mean finding a power pack that charges off of USB, and is capable of being charged and discharged at the same time.
David
Re: Battery Backup
Using a TL-MR3040 will give you some headroom, as it has a battery included.
Your license can be moved to that unit. Buy one, flash it, try out and drop me
a mail when you want your license transferred. The MR3040 is about as cheap
as the MR3020, but one LED is missing, so it boots partly in "dark mode".
josecmorales
Re: Battery Backup
Post by josecmorales »
But on thing, i have my MR3020 on LAN conection, i have an ISS Davis Pro2 with envoy and weatherlinkIP, is would works with this MR3040? or the data will be miss too?
@climaguayana
Re: Battery Backup
ye, MR3040 can do all things a MR3020 can do. In case of power outage,
WLIP will of course not benefit from MR3040 internal battery, so
readings will be lost when WLIP does no longer deliver data because it
is unpowered. In case of USB Davis logger it will continue to work.
assenzuid
Re: Battery Backup
Post by assenzuid »
Interesting device, is it possible to migrate the existing data and configuration in one time to a new device (year, monthly results....)?
Is for this device an extra hub needed to connect an Davis Envoy?
jmontamat
Re: Battery Backup
Post by jmontamat »
I use a battery backup mobile
JM.
Re: Battery Backup
assenzuid wrote:Interesting device, is it possible to migrate the existing data and configuration in one time to a new device (year, monthly results....)?
1) Existing historical data will be lost when moving to a new device. License can be switched over.
2) You still need the hub when using the Davis USB data logger.
assenzuid
Re: Battery Backup
Post by assenzuid »
Thanks for answering.
LAWx
Re: Battery Backup
Post by LAWx »
Unless you already have a USB power pack to use, you can pick up a small UPS for around $50 and use it to power your TP-Link and Davis Console. They draw so little power that even the tiniest UPS will outlast most power outages. With batteries in the Davis console you're unlikely to loose data even if and when a power outage exceed the capacity of your UPS.
