TP-LINK TL-MR3020 - unable reset to defaults
jgehrts
Post by jgehrts »
I'm having a problem with a TP-LINK TL-MR3020. I need to do a reset on the device, but it never goes into fast-blink mode. I've installed 19 other weather stations, each using its own MR3020, and have not had a problem with any of the MR3020s (including resetting as needed) except for this one.
Thanks for the assistance.
Re: TP-LINK TL-MR3020 - unable reset to defaults
May be you have not flashed this one at all and it is still on TP-Link FW?
Just a guess, but when would have to do 20 flashes in sequence, I am sure I would drop one accidentially anyhow ;-)
jgehrts
Post by jgehrts »
They all came from Ambient Weather and came "pre-flashed" (so to speak :) )
Does it stay in slow blink or steady on?
jgehrts
Post by jgehrts »
The larger light/button that has the slow/fast blink functionality doesn't even begin to do a slow blink unless I press it. It will then slow blink for a few minutes, then turn back off. It doesn't proceed to a fast blink or solid.
Looks like a faulty system/flash, please contact ambient for a replacement, I am out of ideas.
