Update 4.9u
What's hot...
skyewright
Re: Update 4.9u
Post by skyewright »
VP2 isssue on "proxy" meteohub
I have Meteohub running on 2 ALIX-1D machines.
Most ofthe weather stations are attached to the first meteohub (I call it meteohub-b), with the second (which I call meteohub-c) accessing the weather stations via meteohub-b (e.g. 192.168.0.78:5502)
I upgraded both to 4.9u at around 1200 GMT on 2013-04-23.
meteohub-b was fine.
On meteohub-c all was fine except that the VP2 station reported no data on any sensors. meteohub log reported a problem with "buffer full" then disconnected. Here's a log extract edited down for just the relevant lines:
logger (23.04.2013 13:24:32): connect station 5 (Vantage via TCP/IP Meteohub).
logger (23.04.2013 13:24:32): station 5 (Vantage), syncing.
logger (23.04.2013 13:24:32): station 5 (Vantage), rain collector size 0.2 mm per tick.
logger (23.04.2013 13:24:32): station 5 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (23.04.2013 13:24:32): station 5 (Vantage), version request sent.
logger (23.04.2013 13:27:53): station 5 (Vantage), buffer full.
logger (23.04.2013 13:27:53): disconnect station 5 (Vantage).
l
I have reverted meteohub-c to 4.9t and it is now functioning normally.
Boris: The access details you have are for meteohub-b. I can provide alternatives for meteohub-c if you wish.
Re: Update 4.9u
David, thanks for digging into this. Looks like you are one of the few using meteohubs in a daisy chain. ;-)
Just released 4.9u hot-fix should have the problem solved.
skyewright
Re: Update 4.9u
admin wrote:David, thanks for digging into this. Looks like you are one of the few using meteohubs in a daisy chain. ;-)
Always the awkward one. ;)
admin wrote:Just released 4.9u hot-fix should have the problem solved.
Build 6942 now installed on both meteohubs. VP2 working fine on both.
Thank you. :)
awekas
Re: Update 4.9u
Post by awekas »
Hi !
Since 6942 my Davis connection is broken! Look at post : viewtopic.php?f=8&t=9260&p=13315#p13315
othmar
wfpost
Re: Update 4.9u
Post by wfpost »
since 4.9u there´s something wrong with the virtual sensor failovermaster-slave function.
it always showing 0.0°C as value and not the correct one of the master and slave sensors :roll:
Re: Update 4.9u
newest hot-fix just uploaded should fix the probems with vantage envoys.
Manhart
Re: Update 4.9u
Post by Manhart »
How do i get the last release of 4.9u ? Only download and manual update or direct update in Meteohub ?
My VP2 does not show Pressure data since update to 4.9u.
Matthias
skyewright
Re: Update 4.9u
Manhart wrote:How do i get the last release of 4.9u ? Only download and manual update or direct update in Meteohub ?
Maintenance => Check for Updates
will "see" if there is a build on the server more recent than the one you have.
Manhart
Re: Update 4.9u
Post by Manhart »
My Meteohub tells be build 1266. I can check for updates and the device finds an update to 4.9u, but the build stays on 1266. I downloded 4.9u from the website too and made a manual update - still build 1266 and no pressure from my VP2.
Matthias
Re: Update 4.9u
builds are differently for the hw version you use. Discussion above was on the x86 version (alix etc),
NSLU, A10 and Sheeva have distinct build numbers.
Manhart
Re: Update 4.9u
Post by Manhart »
Ok - thanks for the clarification. Pressure is now back with the firmware from the website and the manual installation.
Matthias
Friese111
Re: Update 4.9u
Post by Friese111 »
I would like to update my meteohub. There is enough space left on my usbstick. Everytime I try to update, my nslu is downloading the new file. After some minutes I always got the message: Download update 4.9u failed!. After deleting the new downloaded file and downloading this file again, I `m getting the same message again. At the moment I`m not able to update my system.At the moment I`m still using 4.9s
skyewright
Re: Update 4.9u
Friese111 wrote:After some minutes I always got the message: Download update 4.9u failed!.
Have you considered collecting the update direct from the Meteohub website (http://wiki.meteohub.de/Updates), then using the "Software Update (File)" option to browse for and update from the downloaded file?
Friese111
Re: Update 4.9u
Post by Friese111 »
Yes, I also did that but I got the same mesage.
el-rain
Re: Update 4.9u
Post by el-rain »
Since last 4.9u I have the following problems.
Davis VP2 with Envoy
during Night I get the error that humidity is out of range but when check the collected data and Sensors tab and the console all looking OK.
logger (11.06.2013 00:14:28): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (11.06.2013 00:14:54): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
20130611001311 th0 118 80 0085
20130611001415 th0 118 80 0085
20130611001505 th0 117 80 0084
on my iConnect I run 4.9u build 1375 when check for update it is always load again 4.9u, when install it and check afterward I still have build 1375.
and again a check update show that there is a "newer" 4.9u and I can update but again this would build 1375 ...
Bye
El
