Error: wget: unable to resolve host address **solved**
mkmiecik
Post by mkmiecik »
I recently bought my first weather station (Oregon WMR-88) and am about to configure meteobridge on TP-LINK TL-MR3020 (plus USB hub). I successfully configured network, as I'm able to remotely connect meteobridge over Internet (from another network). The connection between weather station and meteobridge via USB hub works well, too, as I can observe correct data in the "Live Data" section. But I'm not able to get my data sent to Weather Underground. On the top of the "Live Data" section it says:
"2014-11-23 17:13:49 Error: wget: unable to resolve host address 'rtupdate.wunderground.com' (no more tries)"
The Weather Network section says (I triple-checked all inserted data):
An then, there is the bit worrying "No Internet Access" in the Network section, which may not be all true as, again, I'm accessing the meteobridge over the Internet.
My setup again is:
Oregon Scientific: WMR-88
Any hints?
Best regards,
Marcin
Re: Error: wget: unable to resolve host address
This looks like DNS an other functions run into a time-out error caused by an extremely
slow Internet connection or one with poor latency. Are you connected via 3G or satellite?
mkmiecik
Post by mkmiecik »
The meteobridge is connected over DSL via a wireless router and there is very good wireless coverage where it's placed. The connection speed in the home network is 20 GBit/s. There is also no lag while accessing meteobridge over Internet.
If you like, you can give me a login option as explained here:
viewtopic.php?f=57&t=9885
Please set password to "needhelp".
mkmiecik
Post by mkmiecik »
It would be great if you could take a look, thank you for your time. I already changed the password, should I paste the URL in this thread as well?
please send url to "info(at)smartbedded.com".
When I login I can check with pings, that DNS resolution is extremely slow. That means
your provider has a massive problem there. Fortunately, you can use google DNS at 8.8.8.8
I switched your IP setup to static, using google DNS and setting IP to 192.168.0.99
Screen Shot 2014-11-23 at 22.03.41.png (20.74 KiB) Viewed 3652 times
Now it works fine again...
mkmiecik
Re: Error: wget: unable to resolve host address **solved**
Post by mkmiecik »
Thank you a lot :). I wouldn't have guessed that for sure.
