No FTP Uploads / Push Services working in vers 2.4 **solved*
WeatherPilot
Post by WeatherPilot »
Been using Meteobridge for some time now - about 5 months without any problems. My site is hosted at Godaddy.com
My Meteobridge rebooted and picked up the 2.4 software release last Saturday 1/3/15. Since that update my ftp push for my Saratoga template website times out. Also, when I try to reload the template for MBtags.php the reload fails. Additionally the FTP upload for wundercam is timing out. Seems like all the FTP transfers are not working anymore since the 2.4 update. Like I said - prior to the 2.4 update everything worked fine. Wondering if anyone else has had any problems?
My configuration:
TP-Link MR-3020 with Meteobridge 2.4
Davis Vantage Vue wireless
DHCP LAN connection (not using wifi)
Any suggestions would be appreciated.
Greg "WeatherPilot"
http://www.tuscawilla-weather.net
KWVCHARL10 on Wunderground
C9485 Madis
Thanks!!
Re: No FTP Uploads or Push Services working since 2.4 update
Could you please provide a screen dump of your "push services" tab?
In 2.4 the way how to specify push services has changed significantly.
I have some code in 2.4 that should migrate old settings automatically,
but may be that did not work 100% OK in your case.
WeatherPilot
Attached screen capture as requested.
Greg.
WeatherPilot wrote:Been using Meteobridge for some time now - about 5 months without any problems. My site is hosted at Godaddy.com
My configuration:
Greg "WeatherPilot"
C9485 Madis
Thanks!!
At the moment 12:10 Tuesday, 6 January 2015 (GMT-5) the updates came in at the correct time .
Saratoga header info displays: Updated: 01/06/2015 12:07:13
But than uploading of MBtags stops at least until 12:23. So definitly not every 5 minutes.
But how comes that the upload was succesfull at 12:06 and then stopped?
The realtime data is coming frequently, so they probably are within the 10 seconds interval.
Checked a few times, no frequent 5 minute uploads just every 30 minutes or so a fresh MBtags is uploaded or shown/returned by the webserver.
Now it just uploaded:
Meteobridge FTP Current 0:01:17 Tue, 06-Jan-2015 1:36pm EST
Again realtime HTTP upload seems to be functioning normally every time, but FTP is not coming in every 5 minutes.
Is this a MB problem or a webserver / hosting company problem?
WeatherPilot
Not sure if it is problem with ISP. All I know is that things were working OK until the 2.4 update.
Greg, if you like you can give me access rights as outlined here:
viewtopic.php?f=57&t=9885
I could login and reasons for upload problems are:
1) WUCAM
It looks like wucam is getting rather slow for receiving data right now. Debugging the FTP upload shows that it takes over 10 seconds to have a cam picture placed at WUs ftp server in good moments. Upload speed itself does not seem to be a problem, but until it starts can take rather long. In bad moments it takes more than 20 seconds. Timeout is set to 20 seconds, I will increase that to 30 seconds with next update. But as this blocks other uploads on your Meteobridge, I wouldn't make the time out longer.
2015-01-10 04:33:12  Connected to webcam.wunderground.com.
2015-01-10 04:33:12  Cmd: USER PeaNutCamCAM2
2015-01-10 04:33:13  331: User PeaNutCamCAM2 OK. Password required
2015-01-10 04:33:13  Cmd: PASS xxxxxxxx
2015-01-10 04:33:13  230: OK. Current directory is /
2015-01-10 04:33:13  Cmd: PWD
2015-01-10 04:33:13  257: "/" is your current location
2015-01-10 04:33:13  Logged in to webcam.wunderground.com as PeaNutCamCAM2.
2015-01-10 04:33:13  Cmd: FEAT
2015-01-10 04:33:13  211: Extensions supported:
2015-01-10 04:33:13        EPRT
2015-01-10 04:33:13        IDLE
2015-01-10 04:33:13        MDTM
2015-01-10 04:33:13        SIZE
2015-01-10 04:33:13        MFMT
2015-01-10 04:33:13        REST STREAM
2015-01-10 04:33:13        MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
2015-01-10 04:33:13        MLSD
2015-01-10 04:33:13        TVFS
2015-01-10 04:33:13        ESTA
2015-01-10 04:33:13        PASV
2015-01-10 04:33:13        EPSV
2015-01-10 04:33:13        SPSV
2015-01-10 04:33:13        ESTP
2015-01-10 04:33:13       End.
2015-01-10 04:33:13  Cmd: HELP SITE
2015-01-10 04:33:13  214: The following SITE commands are recognized
2015-01-10 04:33:13        CHMOD
2015-01-10 04:33:13        UTIME
2015-01-10 04:33:13       Pure-FTPd - http://pureftpd.org/
2015-01-10 04:33:13  Cmd: CLNT NcFTPPut 3.2.5 linux-x86_64-glibc2.12
2015-01-10 04:33:13  500: Unknown command
2015-01-10 04:33:13  Cmd: TYPE I
2015-01-10 04:33:13  200: TYPE is now 8-bit binary
2015-01-10 04:33:13  Cmd: PASV
2015-01-10 04:33:13  227: Entering Passive Mode (38,102,137,106,22,168)
2015-01-10 04:33:14  Cmd: STOR wucam.jpg
2015-01-10 04:33:14  150: Accepted data connection
2015-01-10 04:33:26  226: File successfully transferred
2015-01-10 04:33:26       0.269 seconds (measured here), 108.99 Kbytes per second
2015-01-10 04:33:26  Cmd: MFMT 20150110093044 wucam.jpg
2015-01-10 04:33:26  213: UTIME OK
2015-01-10 04:33:26  Cmd: QUIT
2015-01-10 04:33:26  221: Goodbye. You uploaded 30 and downloaded 0 kbytes.
2015-01-10 04:33:26       Logout.
To avoid this WU performance bottleneck, you might consider to upload the picture to the Meteobridge server and to give WU just the URL where to grab the picture from.
2) FTP upload to your weather network tuscawilla:
Here sometime the first connection attempt is totally ignored from the FTP server (4:54:00 - 4:54:15). No idea why.
2015-01-10 04:54:00  LibNcFTP 3.2.5 (January 17, 2011) compiled for linux-x86_64-glibc2.12
2015-01-10 04:54:00  Uname: Linux|MeteoBridge|3.3.8|#16 Sat Mar 22 22:51:17 CET 2014|mips
2015-01-10 04:54:15  Could not connect to ftp.tuscawilla-weather.net -- try again later: Connection timed out.
2015-01-10 04:54:15  Sleeping 5 seconds.
2015-01-10 04:54:20  Retry Number: 1
2015-01-10 04:54:20  220: --------- Welcome to Pure-FTPd [privsep] [TLS] ----------
2015-01-10 04:54:20       You are user number 3 of 500 allowed.
2015-01-10 04:54:20       Local time is now 02:54. Server port: 21.
2015-01-10 04:54:20       This is a private system - No anonymous login
2015-01-10 04:54:20       You will be disconnected after 15 minutes of inactivity.
2015-01-10 04:54:20  Connected to ftp.tuscawilla-weather.net.
2015-01-10 04:54:20  Cmd: USER meteobridge@tuscawilla-weather.net
2015-01-10 04:54:21  331: User meteobridge@tuscawilla-weather.net OK. Password required
2015-01-10 04:54:21  Cmd: PASS xxxxxxxx
2015-01-10 04:54:21  230: OK. Current restricted directory is /
2015-01-10 04:54:21  Cmd: PWD
2015-01-10 04:54:21  257: "/" is your current location
2015-01-10 04:54:21  Logged in to ftp.tuscawilla-weather.net as meteobridge@tuscawilla-weather.net.
2015-01-10 04:54:21  Cmd: FEAT
2015-01-10 04:54:21  211: Extensions supported:
2015-01-10 04:54:21        EPRT
2015-01-10 04:54:21        IDLE
2015-01-10 04:54:21        MDTM
2015-01-10 04:54:21        SIZE
2015-01-10 04:54:21        MFMT
2015-01-10 04:54:21        REST STREAM
2015-01-10 04:54:21        MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
2015-01-10 04:54:21        MLSD
2015-01-10 04:54:21        AUTH TLS
2015-01-10 04:54:21        PBSZ
2015-01-10 04:54:21        PROT
2015-01-10 04:54:21        TVFS
2015-01-10 04:54:21        ESTA
2015-01-10 04:54:21        PASV
2015-01-10 04:54:21        EPSV
2015-01-10 04:54:21        SPSV
2015-01-10 04:54:21        ESTP
2015-01-10 04:54:21       End.
2015-01-10 04:54:21  Cmd: HELP SITE
2015-01-10 04:54:21  214: The following SITE commands are recognized
2015-01-10 04:54:21        ALIAS
2015-01-10 04:54:21        CHMOD
2015-01-10 04:54:21        UTIME
2015-01-10 04:54:21       Pure-FTPd - http://pureftpd.org/
2015-01-10 04:54:21  Cmd: CLNT NcFTPPut 3.2.5 linux-x86_64-glibc2.12
2015-01-10 04:54:21  500: Unknown command
2015-01-10 04:54:21  Cmd: TYPE I
2015-01-10 04:54:21  200: TYPE is now 8-bit binary
2015-01-10 04:54:21  Cmd: PASV
2015-01-10 04:54:21  227: Entering Passive Mode (23,229,151,160,196,242)
2015-01-10 04:54:21  Cmd: STOR mb_MBtags.php
2015-01-10 04:54:22  150: Accepted data connection
2015-01-10 04:54:22  226: File successfully transferred
2015-01-10 04:54:22       0.176 seconds (measured here), 215.22 Kbytes per second
2015-01-10 04:54:22  Cmd: RNFR mb_MBtags.php
2015-01-10 04:54:22  350: RNFR accepted - file exists, ready for destination
2015-01-10 04:54:22  Cmd: RNTO MBtags.php
2015-01-10 04:54:22  250: File successfully renamed or moved
2015-01-10 04:54:22  Cmd: MFMT 20150110095224 MBtags.php
2015-01-10 04:54:22  213: UTIME OK
2015-01-10 04:54:22  Cmd: QUIT
2015-01-10 04:54:22  221: Goodbye. You uploaded 38 and downloaded 0 kbytes.
2015-01-10 04:54:22       Logout.
Consecutive uploads work very fast, but sometime the first attempt is stalled completely. Looks like a server problem to me. Timeout is 15 seconds, which looks reasonable to me.
I also tried to send the commands to "tuscawilla" from my Meteobridge and this always works fine.
Therefore, it looks like some routing problems within your providers network. Just guessing,
but it works flawlessly (apart from wucam) here on my 2.4 Meteobridge.
WeatherPilot
This is a very odd situation. And I think it is a GoDaddy (hosting provider) issue. Starting earlier today - everything started working fine. Uploads went up, down loads came down. Website updates to my Saratoga templates worked without any problems and consistently. I am VERY puzzled. Thanks SOOOO much for looking into this. I appreciate your help. I will be talking with GoDaddy but not sure if they will be of any help.
Thanks again,
Greg.
