Cannot Connect to Meteobridge Remote Access **solved**
mthiessen
Re: Cannot Connect to Meteobridge Remote Access
Post by mthiessen »
Thanks for you reply Bushman. I can only speak for myself and that I have been able to remotely connect daily since I installed it a month ago. Once I installed an update by reboot and it worked fine. But the only time I couldn't connect was after yesterday's update. As long as it's still posting weather data I'm happy.
Clément
Post by Clément »
This isn't random problem.
This appears on last build because some of my meteobridges are not available anymore since their reboot.
crazyace
Post by crazyace »
I just fell back to version 2.5 and can now connect. I then switched back to 2.6 and cannot connect. Lastly, I fell back to version 2.5 again and was able to remotely connect again. From my point of view it looks like there may be an issue with the new version 2.6 and remote connectivity. With all the comments regarding similar issues with 2.6 can the software developer(s) please look into this for us? I am willing to volunteer to help in any way possible that I can with troubleshooting. I really do like Meteobridge but would appreciate some further investigation with this problem if possible.
Seems to be related to connections getting stalled on reboots on Meteobridge clients.
Did some changes on the server side. Please try again and report.
Nice to see how many do really rely on this feature. We 'll try to get it
working more reliable. But as said before, it is rather complex and it has
a reason that it is unmatched by other weather server solutions ;-)
SpiderKnight
Post by SpiderKnight »
After I change to newest built and restart, the error message is:
Just released an update for Meteobridges that makes use of yesterdays server side adaptions. Please reboot your Meteobridge again to have that applied and I hope that this solves most of the issues.
SpiderKnight
Its works, fine!
sv2bzq
Post by sv2bzq »
Do I restart from " ssh " connection ?
George.
sv2bzq wrote:Do I restart from " ssh " connection ?
Just power-cycle...
sv2bzq
Post by sv2bzq »
Just power-cycle...
Sorry but I am away from my home .
It may otherwise I restart ?
crazyace
Post by crazyace »
I updated to Meteobridge 2.6 (Nov 13 2015, build 7641), FW 1.3 and I am now able to connect remotely again! Thank you admins for looking into and correcting this issue. I appreciate the support.
mthiessen
Re: Cannot Connect to Meteobridge Remote Access **solved**
Post by mthiessen »
Remote access now works again. Thank you very much. :D
acma
Post by acma »
Very great support. It now works fine. Thanks a lot!
gillhog
Post by gillhog »
Solved? I have not been able to get into it for over a week.
Do a reboot. When no cure it most probably something on your or your providers side.
