Cannot Connect to Meteobridge Remote Access **solved**
Re: Cannot Connect to Meteobridge Remote Access
Thanks for you reply Bushman. I can only speak for myself and that I have been able to remotely connect daily since I installed it a month ago. Once I installed an update by reboot and it worked fine. But the only time I couldn't connect was after yesterday's update. As long as it's still posting weather data I'm happy.
This isn't random problem.
This appears on last build because some of my meteobridges are not available anymore since their reboot.
I just fell back to version 2.5 and can now connect. I then switched back to 2.6 and cannot connect. Lastly, I fell back to version 2.5 again and was able to remotely connect again. From my point of view it looks like there may be an issue with the new version 2.6 and remote connectivity. With all the comments regarding similar issues with 2.6 can the software developer(s) please look into this for us? I am willing to volunteer to help in any way possible that I can with troubleshooting. I really do like Meteobridge but would appreciate some further investigation with this problem if possible.
Seems to be related to connections getting stalled on reboots on Meteobridge clients.
Did some changes on the server side. Please try again and report.
Nice to see how many do really rely on this feature. We 'll try to get it
working more reliable. But as said before, it is rather complex and it has
a reason that it is unmatched by other weather server solutions
SpiderKnight
- Fresh Boarder
After I change to newest built and restart, the error message is:
- meteobridge2.PNG (13.5 KiB) Viewed 9702 times
Just released an update for Meteobridges that makes use of yesterdays server side adaptions. Please reboot your Meteobridge again to have that applied and I hope that this solves most of the issues.
SpiderKnight
- Fresh Boarder
Its works, fine!
Do I restart from " ssh " connection ?
George.
George.
Just power-cycle...sv2bzq wrote:Do I restart from " ssh " connection ?
Sorry but I am away from my home .admin wrote:Just power-cycle...sv2bzq wrote:Do I restart from " ssh " connection ?
It may otherwise I restart ?
I updated to Meteobridge 2.6 (Nov 13 2015, build 7641), FW 1.3 and I am now able to connect remotely again! Thank you admins for looking into and correcting this issue. I appreciate the support.
Re: Cannot Connect to Meteobridge Remote Access **solved**
Remote access now works again. Thank you very much.
Very great support. It now works fine. Thanks a lot!
Solved? I have not been able to get into it for over a week.
Do a reboot. When no cure it most probably something on your or your providers side.
