Weather Data Recomputation:waiting for several days now
efiten
Post by efiten »
I'm using Rpi 1 with build 5.0f
My system worked well for several months, but due to a power failure, it's rebooted, after that, the recompuntation of weather data is stuck, it's still 'waiting', as you can see in the attachment.
Meteohub status
Meteohub status
It was like this for several days, then I tried to reboot again (from the GUI), but again, it's 'waiting' for more then 10 hrs now.
anything I can do, without loosing data?
Is the incoming data still logged, or is this all lost?
Erwin
Re: Weather Data Recomputation:waiting for several days now
I would recommend doing an update to 5.0p on "maintenance" page with "update (auto)" function.
I hope this also cures your stall problem. If that does not work some semaphore files need to be
purged. To do so, I would need access on ssh level to your Meteohub.
Please send login details to "info(at)meteohub.de", I will need access to port 22 (SSH).
efiten
Post by efiten »
Update Failed
Update Failed
2016-05-06 11_33_11-Settings.png (32.57 KiB) Viewed 6504 times
Tried to do that, but it failed...
So i looked at some log files, and saw this :
May  6 11:15:46 meteohub-rpi exim[13692]: 2016-05-06 11:15:46 1aybrO-0003Yq-BO Failed to create spool file /var/spool/exim4/input//1aybrO-0003Yq-BO-D: No space left on device
This is strange, because I have some room left, even on the rootfs :
root@meteohub-rpi:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
rootfs          1.7G  1.3G  251M  84% /
/dev/root       1.7G  1.3G  251M  84% /
devtmpfs        214M     0  214M   0% /dev
tmpfs            44M  1.9M   42M   5% /run
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           113M     0  113M   0% /run/shm
/dev/mmcblk0p1   50M   24M   26M  48% /boot
/dev/mmcblk0p4   13G  142M   13G   2% /data
tmpfs            32M  652K   32M   2% /var/log
to bad the rootfs is that small, my data-part is 13Gb with almost no usage.
Anything I can do to fix that ?
Erwin
efiten
Post by efiten »
I just mailed the SSH login info to that mail address.
Erwin
Root file system is defective. I guess you need a new SD card and set it up again.
You find help in migrating to a new SD card here:
viewtopic.php?f=23&t=5415
