Hey everyone,
I have my WMR300A connected to Meteobridge with the USB hub. Everything seems to be working fine except wind chill data. Wind chill is not listed under historical data. Could this be a minor glitch or is it something that is not supported?
WMR300A missing wind chill **solved**
Adam Sullivan
Re: WMR300A missing wind chill
Did you switch off wind chill on "station" tab by accident?
i used one WMR300 for a year I seem to recall it wont kick in(display) until you reach a low temperature i.e 41F and below with a windpseed of 5mph or greater .
Hello
I also have a wmr300 with the same problem, this occurred after upgrading my meteobridge to v3.6 and later.
I have downgraded back to 3.5 (Feb 12 2018, build 11957), and then it works fine
That worked for me! Thanks!Rostock wrote: Mon Nov 12, 2018 5:53 pm Hello
Adam Sullivan
When one of you is granting me remote access to your MB, I might be able to find the root cause and fix it for the future. Being stuck to a certain version might not be so great over time...
Ok for me
Fixed with just released update.
