WMR300A missing wind chill **solved**
asull85
Post by asull85 »
Hey everyone,
I have my WMR300A connected to Meteobridge with the USB hub. Everything seems to be working fine except wind chill data. Wind chill is not listed under historical data. Could this be a minor glitch or is it something that is not supported?
Adam Sullivan
Re: WMR300A missing wind chill
Did you switch off wind chill on "station" tab by accident?
asull85
Post by asull85 »
I’ve tried with it on and and off, no luck.
Adam Sullivan
i used one WMR300 for a year I seem to recall it wont kick in(display) until you reach a low temperature i.e 41F and below with a windpseed of 5mph or greater .
Rostock
Post by Rostock »
Hello
I also have a wmr300 with the same problem, this occurred after upgrading my meteobridge to v3.6 and later.
I have downgraded back to 3.5 (Feb 12 2018, build 11957), and then it works fine
asull85
Post by asull85 »
Rostock wrote: Mon Nov 12, 2018 5:53 pm Hello
That worked for me! Thanks!
Adam Sullivan
When one of you is granting me remote access to your MB, I might be able to find the root cause and fix it for the future. Being stuck to a certain version might not be so great over time...
Rostock
Post by Rostock »
Ok for me
Fixed with just released update.
