Upload to meteotemplate
One of my devices (TP link MR 3020 version 1 ) suddenly stopped uploading to meteotemplate.
I have done a simple reboot without success.
I have also deleted the weather network upload and then re-enabled it without success.
I have contacted Jachym from meteotemplate thinking the problem might be on server side there.
Please see his response in attached screenshot.
Any help please !
Regards,
Leon Rossouw.
Any help please !
Regards,
Leon Rossouw.
- Image 3.png (48.85 KiB) Viewed 5811 times
- Image 2.png (50.81 KiB) Viewed 5811 times
- Image 1.png (37.23 KiB) Viewed 5811 times
Re: Upload to meteotemplate
What version of the MeteoBridge SW are you running? Did you update it recently? Have you tried rolling back to an earlier version?
FWIW, I have meteotemplate running fine on my MR3020v3, using Meteobridge 3.9 (Jan 25 2019, build 1915), FW 1.3.
If nothing else has changed you might try chaning your API update password in meteotemplate and on the meteobridge to see if that makes any difference...
Thank you for your help.
I have tried that...no luck.
If I upload the file to a different url (from one of my other meteotemplate web sites) it actually uploads which make me think there might be something wrong on my hosts side ?
I have now emailed their support as well.
But my web cam etc uploads and update perfectly.
Regards,
Leon.
Regards,
Leon.
Permissions on the template/*.txt files that API.php updates, maybe?
I have stil not been able to sort this out....checked permisions ...
Any help please !
Leon.
Any help please !
Leon.
check password.
I did Boris....
Leon.
Leon.
Are you getting a white error box at the top of the Weather Networks page by any chance?
I've found that passwords with special characters tend not to work with the Meteotemplate upload API.php - maybe3 try a new, simple password?
Thank you,
I have not changed anything....it has been working just fine for6 months.
I can upload to a different url and i can from another meteobridge device upload to this url.
Regards,
Leon.
Regards,
Leon.
Could be an IP block at the provider if that other Meteobridge has another external IP address.Leon wrote: Mon Feb 04, 2019 6:01 am Thank you,
Regards,
Leon.
Try a manual upload to the api.php with your browser from the same home as the Meteobridge
To test with the same router and same external IP-address.
Just to check what the reaction is from the api.php
First without a password, it should give the correct standard error-message
With a correct password and some data it should accept and store the data.
Ever figure this out?
I'm seeing an odd error in MB when uploading to Meteotemplate. It often tells me "Timeout in headers" error.
That is when your server reacts to slow or the Internet connection is slow.
That would be odd since my internet connection is quite fast, and it's only set to upload to MeteoTemplate once every 5 minutes. =/admin wrote: Tue Mar 26, 2019 2:05 am That is when your server reacts to slow or the Internet connection is slow.
Is the wifi strong with your meteobridge? Which signal strength information does it show on "known SSIDs" dropdown?
100% Ch 6.admin wrote: Tue Mar 26, 2019 6:07 pm Is the wifi strong with your meteobridge? Which signal strength information does it show on "known SSIDs" dropdown?
It's not the wifi. It COULD be the hosting provider, but I don't know. How long does it give MT to respond before giving up as a timeout?
