stand alone version was designed/developed to be used as a standalone and has 50% less code.
I never imagined or thought users were going to run both , too me it doesn't make sense for many reasons as the console version is embedded in the NANOSD version so theoretically your basically running the same thing twice.
Unneccesary server load may reveal limitations of some hosting packages as you may start maxing out resources especially low cost server hosting packages where resources are already capped .
However the current "stay at home" gives you plenty of time to accomplish it ..
nice benefit of the Standalone version meteobridge NANO(SD),Pro,Tp link etc is now able to use the template and can't reiterate enough how much smaller the footprint is..
screenshot ...
GTMETRIX 30TH MARCH 2020 //
- Screenshot at Mar 30 14-55-14.png (140.4 KiB) Viewed 6240 times
however results can vary as time of day(WWW load) or per hosting setups .ICDSOFT has the less talked about enhancement enabled brotli compression as most are still using the GZIP method .the differences are negligible but beneficial .
https://medium.com/oyotech/how-brotli-c ... d41e50fee4
so use the "Stay at home" time to learn/study about some of the finer points of hosting templates and remember weather templates are not static like most websites ..
have fun...
