Rpi problem history
Re: Meteobridge supports Raspberry Pi 3B, 3B+, 4B
I just changed the device and now I have put a raspberry and I have already moved the license but I can not modify the historical data min / max
why ?
why ?
Do you have a supported microSD card? Do you see the "History" and "Graphs" tab?
yes the card is supported! it is more or less three hours that it is in operation
with history this writing comes out:
The proxy server received an invalid response from an upstream server.
proxy server? are you trying to access it remotely?norvegese wrote: Sat Nov 28, 2020 2:21 pm with history this writing comes out:
As your English is hard to understand (at least for me), can you please provide screen dumps? I am really guessing what your issue might be.
sorry i was out for work what screens do you need?
if I click on history this page comes out with this writing:
Bad Gateway
and even if I click on the weather data to change them
Bad Gateway
but no one can help me?
Rpi problem history
I have a problem with the raspberry pi 4 the history does not work and I can not update min and max this message comes out:
Bad Gateway
Bad Gateway
Re: Rpi problem history
As asked before mak a screen-shot of the system tabnorvegese wrote: Mon Nov 30, 2020 2:23 pm I have a problem with the raspberry pi 4 the history does not work and I can not update min and max this message comes out:
Bad Gateway
and
Make a screen-shot of what shows on the minute tab.
See an example I attached of my raspberry
- what_shows_there.jpeg (69.27 KiB) Viewed 4672 times
Well I almost sure that you need a larger SLC card to get the / minute data.
viewtopic.php?p=35823#p35823
The trigger to make this new feature was based on the availability of affordable 8 or 16 Gb SLC cards
Your SLC card would wear out in less than 1 year if /minute data would be stored.
I am also not sure if this is already available or that you need to apply for a beta-version first.
But it is unexplained why your / hour data does not work.
That should always work on any raspberry. See screenshot
What happens when you click on the "Edit Hour Data" tab? (Strangly it is the only one untranslated also.)
Can you make a screenshot what happens when you click that?
- history.jpeg (156.39 KiB) Viewed 4645 times
This happens ad son as press
