Rpi problem history
norvegese
Re: Meteobridge supports Raspberry Pi 3B, 3B+, 4B
Post by norvegese »
I just changed the device and now I have put a raspberry and I have already moved the license but I can not modify the historical data min / max
why ?
Do you have a supported microSD card? Do you see the "History" and "Graphs" tab?
norvegese
Post by norvegese »
yes the card is supported! it is more or less three hours that it is in operation
norvegese
Post by norvegese »
with history this writing comes out:
The proxy server received an invalid response from an upstream server.
norvegese wrote: Sat Nov 28, 2020 2:21 pm with history this writing comes out:
proxy server? are you trying to access it remotely?
As your English is hard to understand (at least for me), can you please provide screen dumps? I am really guessing what your issue might be.
norvegese
Post by norvegese »
sorry i was out for work what screens do you need?
norvegese
Post by norvegese »
if I click on history this page comes out with this writing:
Bad Gateway
and even if I click on the weather data to change them
norvegese
Post by norvegese »
but no one can help me?
norvegese
Rpi problem history
Post by norvegese »
I have a problem with the raspberry pi 4 the history does not work and I can not update min and max this message comes out:
Bad Gateway
Re: Rpi problem history
norvegese wrote: Mon Nov 30, 2020 2:23 pm I have a problem with the raspberry pi 4 the history does not work and I can not update min and max this message comes out:
Bad Gateway
As asked before mak a screen-shot of the system tab
and
Make a screen-shot of what shows on the minute tab.
See an example I attached of my raspberry
norvegese
Post by norvegese »
norvegese
Post by norvegese »
norvegese wrote: Mon Nov 30, 2020 4:33 pm
Well I almost sure that you need a larger SLC card to get the / minute data.
viewtopic.php?p=35823#p35823
The trigger to make this new feature was based on the availability of affordable 8 or 16 Gb SLC cards
Your SLC card would wear out in less than 1 year if /minute data would be stored.
I am also not sure if this is already available or that you need to apply for a beta-version first.
But it is unexplained why your / hour data does not work.
That should always work on any raspberry. See screenshot
What happens when you click on the "Edit Hour Data" tab? (Strangly it is the only one untranslated also.)
Can you make a screenshot what happens when you click that?
norvegese
Post by norvegese »
This happens ad son as press
