good morning Richard see above post 26th Jan update fixes that ..atlantic21 wrote: Tue Jan 26, 2021 10:24 pm Brian with the latest update the max wind is now not showing any value for me
before update
after
https://www.ilfracombeweather.net/console/index.php
have used the backup before update 20:55 to restore
Regards atlantic21
atlantic21
- Junior Boarder
Good morning Jason such dramatic words "bow"
I simply have not had the time to do any updates with MK1 I will sooner or later just need to find the time to sit down .
To be honest I cant remember what issues there were(feel free to list them and if its too many yes I will park it ON THE HARD SHOULDER on the M25 and wait for someone to tow it away
Im at a point of I just want to put out one good stable release and take a break from it as Im making so many mistakes frequently Im beginning to question my ability to do this . One metric is a distant dream and design life would so easier in terms of weather templates ..
- jasonmfarrow
I think, considering you don't want to make more work for yourself, that MK1 just needs the fixes to align with the very latest version of the API.
Retrofitting all the advances in MK2 to Mk1 is not why you created, and now focus on, Aurora Mk2.
Looking at my Mk1 I can see only one bug and that is the winddmaxtime. All the charts are working and nothing else is obviously wrong.
I think calling it a stable release and parking it (which is what the M25 is really for) is the right thing. We all want a healthy and happy Brian, who continues to develop a marvellous template for us all to use; not one who's might pack it all in 'cause we're too demanding...
Hi
I'm updating via Git with:
sudo git pull
Now I get some errors. Any ideas what why?
Gert
sudo git pull
Gert
- Git.jpg (121.3 KiB) Viewed 4997 times
Done! Now it's working fine!! But now I realized that I've got a problem with the "Record Max" and "Record Min" temps. It shows 54.7ºC on 15 nov 2019, but I've checked the excel at /weather34charts/2019.csv and it shows 41.6º. I've checked everything, included the 2019 folder with de csv's of November, but I don't understand where is reading this numbers.weatherist34 wrote: Tue Jan 26, 2021 9:33 pm just pm your setup password which you can change at anytime or read this post viewtopic.php?p=37625#p37625
The same happen with the Record min.
Do you know what I need to check/change so it shows the "real" records? I don't care if I have to put it manually.
Thank you so much
alexeysailman
- Expert Boarder
Hi, Brian!
Despite the fact that you somehow answered me: "sorry alex i cant help you .im more inclined to drop mmHg its obviously not working and im having great trouble following what your asking or highlighting and there is a quite long period between your responses often a week or weeks . to be honest i cant even remember your last issue .so my sincere apologies but I will remove mmHG in forthcoming update. unless you can provide some form of code i understand then ill quite happily help."
I want to say that a lot of work has been done to introduce a new unit of pressure measurement (mmHg), even for a very small number of people. And it will be frankly a pity if it is removed in future updates. In the update for 27.01.21, everything looks perfect, well, there is simply nothing to find fault with except in the charts on the "extra info" button and in the charts for the current day, the vertical scale in hectopascals.
I don't even know if it's possible to come up with something else?
Alex try update 28th...
these values are stored in your meteobridge hardware . you need to edit the values in meteobridge itself under history sectioneaf90 wrote: Wed Jan 27, 2021 8:36 pmDone! Now it's working fine!! But now I realized that I've got a problem with the "Record Max" and "Record Min" temps. It shows 54.7ºC on 15 nov 2019, but I've checked the excel at /weather34charts/2019.csv and it shows 41.6º. I've checked everything, included the 2019 folder with de csv's of November, but I don't understand where is reading this numbers.weatherist34 wrote: Tue Jan 26, 2021 9:33 pm just pm your setup password which you can change at anytime or read this post viewtopic.php?p=37625#p37625
Thank you so much
nope this is a GIT issue please refer this to the GITHUB communitygand wrote: Wed Jan 27, 2021 7:57 pm Hi
sudo git pull
Gert
flattering words but MK1 has been taken to the scrap yardjasonmfarrow wrote: Wed Jan 27, 2021 3:21 pm Brian,
@Chuck please find in the GITHUB release a new file for lightning . mb-lightning.php which resides in the mb folder.
this will prepare for a new almanac screen and collection of chart data . see below . please let me know when you have this one file installed and setup .
in your TPLINK/DIR meteobridge hub goto services and add a new service you can run it every 30 seconds or 60 seconds what ever you wish .
at present it won't effect your current lightning display module , I just need you to run this new service so I ensure the output is as expected .
in the service url basically its a short collection of data (only lightning)
in meteobridge services upload every 1 minute(60 seconds)
the url
click save . it should start producing a file with lightning data called weather34-lightning.txt in the mb folder.
it will basically give you a pop up screen , this will also allow to build month year charts but one step at a time .
the chart takes the total strikes for every last 10 minutes so you dont miss anything .
for weatherflow Air module only does not work with other brands of lightning sensors. the string used [lgt0total-sum10.0:--]
the url
https://yourdomain.com/yourfolder/mb-lightning.php?d=[lgt0energy-act:--] [lgt0dist-act:--] [lgt0dist-age:--] [lgt0total-daysum.0:--] [lgt0total-monthsum.0:--] [lgt0total-yearsum.0:--] [lgt0total-sum10.0:--]it will basically give you a pop up screen , this will also allow to build month year charts but one step at a time .
- prestwickwx
Thanks for the info. I setup the https Service (60 sec.) in the TP that is presently sending the WF lightning data. I tried using the full URL code that you listed, but it did not produce the weather34-lightning.txt file. I then tried the abbreviated https://yourdomain.com/yourfolder/mb-lightning.php and it did generate the file (with minimal data).
Hope all is well.
https://myrtleweather.com/console/mbridge/weather34-lightning.txtChuck
thats perfect it tells me
-- -- 78934 0 13 13 --
0 energy (as there is none last 3 hrs)
0 distance (as there is none last 3 hrs)
78934 seconds ago (aprox 21 hours ago)
0 today
13 January
13 2021
0 last ten minutes
https://myrtleweather.com/console/mbrid ... htning.txt
will build it around will update GITHUB sometime this evening
0 today
13 January
13 2021
0 last ten minutes
- prestwickwx
Ok. That sounds good!weatherist34 wrote: Sat Jan 30, 2021 5:51 pm thats perfect it tells me
0 today
13 January
13 2021
0 last ten minutes
