Meteobridge pro automatic reboot
ruzzi.f@gmail.com
Post by ruzzi.f@gmail.com »
I am having issues with one of my meteobridge pro. It is never available because it continuously reboots automatically, despitethe signal is very strong and the option “no reboot if data lack....” is selected.
Can anybody help please?
Fabio
ruzzi.f@gmail.com
Re: Meteobridge pro automatic reboot
signal is around 62db
sensitivity was 80, I changed it into 95 but it is even worse
anyway I do not understand why it restarts: in the lot it says “restart meteostick (350 no valid rf signal)”
Does it reboot or does it just restart the logging process?
You can check on "system - Information" tab by reading the uptime. Uptime is reset on each reboot but not when logging gets restarted.
ruzzi.f@gmail.com
sometimes it is only logger restart. the problem is that it restart it lose connection and i cannot see it anymore (it is remote).
but I cannot understand why. I put sensitivity at 75 and seemed working better but after 2 hours again....
ruzzi.f@gmail.com
why does it restart if I flag the “no restart when data lack...”?
Please provide screen dumps of "Live Data - Raw Data" and station settings. RF sensitivity needs to match signal strength.
How far away are the sensors?
ruzzi.f@gmail.com
the station is 20 mt away. usually signal was 80 db.
I changed the battery and signal is now 60-65 db. I reduced sensitivity from 95 to 75 db.
I am afraid to put less because if the signal is not received I will loose connection with the remote unit.
This has changed vs the past. in the past when you do not get the signal you could anyhow connect with the unit, not it restart continuously....sometimes losing connection for hours. what has changed?
ruzzi.f@gmail.com
I am trying to post the screenshot but it says that the file is too big. how can I post a screenshot?
ruzzi.f@gmail.com
this is the raw data
raw data
raw data
ruzzi.f@gmail.com
station setting and log
ruzzi.f@gmail.com
today I checked also another meteobridge pro and I realized that there is a similar issue (even if it is happeneng much less frequently).
Looking at the log I realized that the meteobridge restarted during the night many times because “no valid rf signal”.
Can you please help solving the issue?
ruzzi.f@gmail.com
Upload StatusRaw Sensor DataMin/Max Data
Live Data
# Sensor Signal Metric Data Imperial Data
0 Outdoor 4s -83db 23.5°C 65% (dew 16.5°C, heat 23.5°C) 74.3°F 65% (dew 61.7°F, heat 74.3°F)
0 Wind 1s -83db 2.4m/s (avg 2.9m/s) 334° NNW 5.4mph (avg 6.5mph) 334° NNW
0 Rain 1s -83db rate 0.0mm/h rate 0.00in/h
0 Indoor 34s 71.4% 47.4°C 18% 1021.6hPa (1021.6hPa) 117.3°F 18% 30.17inHg (30.17inHg)
9 Data #10 27 sec 10% system load 10% system load
9 Data #11 27 sec 47.2h uptime 47.2h uptime
9 Data #12 27 sec 7% data store usage 7% data store usage
9 Data #13 27 sec 69% RAM usage 69% RAM usage
9 Data #15 27 sec 50 processes 50 processes
9 Data #16 27 sec 2sec since last data 2sec since last data
9 Data #14 27 sec 1.93W power 1.93W power
9 Data #17 27 sec 5.47V voltage 5.47V voltage
9 Data #18 27 sec 0.35A current 0.35A current
9 Data #19 27 sec 25.2MB tx data 25.2MB tx data
9 Data #20 27 sec 26.1MB rx data 26.1MB rx data
9 System #9 27 sec 53.6°C 13% 1021.9hPa (1021.9hPa) 128.5°F 13% 30.18inHg (30.18inHg)
ruzzi.f@gmail.com
database (31.08.2021 13:05:50): process terminated normally.
database (31.08.2021 13:05:51): process started.
system (31.08.2021 13:05:51): stop of logging process initiated.
system (31.08.2021 13:05:59): start of logging process initiated.
logger (31.08.2021 13:06:00): databases connected. Update interval 3600 seconds.
logger (31.08.2021 13:06:00): data logger (version 5.2, build 14529) started.
logger (31.08.2021 13:06:02): connect station 0 (Meteostick Vantage via USB serial).
logger (31.08.2021 13:06:02): connect station 9 (System Data via Plug-in).
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), transmitter 3 registered as ISS
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), Meteostick Version 2.4
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), debug off
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), verbose off
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), filter on
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), rx threshold set to -90db
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), listening to transmitter 3
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), bandwidth narrow
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), chip authentication ok: 14
logger (31.08.2021 13:06:02): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (31.08.2021 13:06:05): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (31.08.2021 13:06:05): services paused.
logger (31.08.2021 13:06:05): error while doing write on socket 5551 (9): Bad file descriptor
database (31.08.2021 13:06:36): database sync done (61 tables, 145/1822 writes).
logger (31.08.2021 13:07:03): sensors are now providing data.
logger (31.08.2021 13:07:03): services started.
logger (31.08.2021 22:51:16): station 0 (Meteostick Vantage), restart meteostick (350 secs no valid rf signal)
logger (31.08.2021 23:01:18): station 0 (Meteostick Vantage), restart meteostick (340 secs no valid rf signal)
logger (01.09.2021 01:51:23): message above repeats 1 time.
logger (01.09.2021 04:16:27): station 0 (Meteostick Vantage), restart meteostick (310 secs no valid rf signal)
logger (01.09.2021 04:21:29): station 0 (Meteostick Vantage), restart meteostick (300 secs no valid rf signal)
logger (01.09.2021 04:41:36): message above repeats 4 times.
logger (01.09.2021 05:05:37): station 0 (Meteostick Vantage), restart meteostick (350 secs no valid rf signal)
logger (01.09.2021 05:10:39): station 0 (Meteostick Vantage), restart meteostick (300 secs no valid rf signal)
logger (01.09.2021 05:28:41): station 0 (Meteostick Vantage), restart meteostick (350 secs no valid rf signal)
logger (01.09.2021 05:33:42): station 0 (Meteostick Vantage), restart meteostick (300 secs no valid rf signal)
logger (01.09.2021 06:11:45): station 0 (Meteostick Vantage), restart meteostick (330 secs no valid rf signal)
logger (01.09.2021 07:56:48): station 0 (Meteostick Vantage), restart meteostick (300 secs no valid rf signal)
What's the distance from the MBPro to the ISS?
ruzzi.f@gmail.com
the distance is about 20 meters
