Imperial Data in History **solved**
meteosantasusanna
Post by meteosantasusanna »
In my History the temperature data shows in ºF. How can I change this?
Re: Imperial Data in History
in Station Tab ?
meteosantasusanna
Thank You. I made this now but still shows the temperature in F (Imperial)
meteosantasusanna
Screenshot 2022-10-01 at 12-51-29 Meteobridge.png (54.65 KiB) Viewed 1688 times
Although it shows ºC, the values ​​of over 40 degrees are probably not correct at all!
The exported data to weather networks are correct. Even when creating the graphics.
Why does it show values ​​over 40 in history?
Screenshot 2022-10-01 at 12-52-34 Meteobridge.png (90.8 KiB) Viewed 1688 times
There is a switch on "system - administration" tab to change between Celsius and Fahrenheit.
Regarding t9temp, this is the Meteobridge system temperature (presumably an RPI) where 50°C looks pretty reasonable.
