In my History the temperature data shows in ºF. How can I change this?
Imperial Data in History **solved**
meteosantasusanna
- Fresh Boarder
Re: Imperial Data in History
in Station Tab ?
- A1F1EB6D-17A2-41D4-A585-432BC030F196.jpeg (452.56 KiB) Viewed 1714 times
meteosantasusanna
- Fresh Boarder
Thank You. I made this now but still shows the temperature in F (Imperial)
meteosantasusanna
- Fresh Boarder
Although it shows ºC, the values of over 40 degrees are probably not correct at all!
The exported data to weather networks are correct. Even when creating the graphics.
Why does it show values over 40 in history?
- Screenshot 2022-10-01 at 12-52-34 Meteobridge.png (90.8 KiB) Viewed 1686 times
There is a switch on "system - administration" tab to change between Celsius and Fahrenheit.
Regarding t9temp, this is the Meteobridge system temperature (presumably an RPI) where 50°C looks pretty reasonable.
