Post
by junkycosmos » Fri May 15, 2009 12:45 am
SYSTEM LOG
May 14 17:34:06 (none) syslog.info syslogd started: BusyBox v1.2.1
May 14 17:34:06 (none) user.notice kernel: klogd started: BusyBox v1.2.1 (2007.12.25-11:17+0000)
May 14 17:34:06 (none) user.notice kernel: Linux version 2.6.21.7 (slug@otto) (gcc version 4.1.2) #1 PREEMPT Mon Dec 24 23:12:24 UTC 2007
May 14 17:34:06 (none) user.warn kernel: CPU: XScale-IXP42x Family [690541f1] revision 1 (ARMv5TE), cr=000039ff
May 14 17:34:06 (none) user.warn kernel: Machine: Linksys NSLU2
May 14 17:34:06 (none) user.warn kernel: Memory policy: ECC disabled, Data cache writeback
May 14 17:34:06 (none) user.debug kernel: On node 0 totalpages: 8192
May 14 17:34:06 (none) user.debug kernel: DMA zone: 64 pages used for memmap
May 14 17:34:06 (none) user.debug kernel: DMA zone: 0 pages reserved
May 14 17:34:06 (none) user.debug kernel: DMA zone: 8128 pages, LIFO batch:0
May 14 17:34:06 (none) user.debug kernel: Normal zone: 0 pages used for memmap
May 14 17:34:06 (none) user.warn kernel: CPU0: D VIVT undefined 5 cache
May 14 17:34:06 (none) user.warn kernel: CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
May 14 17:34:06 (none) user.warn kernel: CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
May 14 17:34:06 (none) user.warn kernel: Built 1 zonelists. Total pages: 8128
May 14 17:34:06 (none) user.notice kernel: Kernel command line: rtc-x1205.probe=0,0x6f console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=jffs2 rw init=/linuxrc noirqdebug
May 14 17:34:06 (none) user.info kernel: IRQ lockup detection disabled
May 14 17:34:06 (none) user.warn kernel: PID hash table entries: 128 (order: 7, 512 bytes)
May 14 17:34:06 (none) user.warn kernel: Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
May 14 17:34:06 (none) user.warn kernel: Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
May 14 17:34:06 (none) user.info kernel: Memory: 32MB = 32MB total
May 14 17:34:06 (none) user.notice kernel: Memory: 30292KB available (1912K code, 153K data, 84K init)
May 14 17:34:06 (none) user.debug kernel: Calibrating delay loop... 132.71 BogoMIPS (lpj=663552)
May 14 17:34:06 (none) user.warn kernel: Mount-cache hash table entries: 512
May 14 17:34:06 (none) user.info kernel: CPU: Testing write buffer coherency: ok
May 14 17:34:06 (none) user.info kernel: NET: Registered protocol family 16
May 14 17:34:06 (none) user.warn kernel: IXP4xx: Using 16MiB expansion bus window size
May 14 17:34:06 (none) user.warn kernel: PCI: IXP4xx is host
May 14 17:34:06 (none) user.warn kernel: PCI: IXP4xx Using direct access for memory space
May 14 17:34:06 (none) user.info kernel: PCI: bus0: Fast back to back transfers disabled
May 14 17:34:06 (none) user.info kernel: dmabounce: registered device 0000:00:01.0 on pci bus
May 14 17:34:06 (none) user.info kernel: dmabounce: registered device 0000:00:01.1 on pci bus
May 14 17:34:06 (none) user.info kernel: dmabounce: registered device 0000:00:01.2 on pci bus
May 14 17:34:06 (none) user.notice kernel: SCSI subsystem initialized
May 14 17:34:06 (none) user.info kernel: usbcore: registered new interface driver usbfs
May 14 17:34:06 (none) user.info kernel: usbcore: registered new interface driver hub
May 14 17:34:06 (none) user.info kernel: usbcore: registered new device driver usb
May 14 17:34:06 (none) user.info kernel: Time: OSTS clocksource has been installed.
May 14 17:34:06 (none) user.info kernel: NET: Registered protocol family 2
May 14 17:34:06 (none) user.warn kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
May 14 17:34:06 (none) user.warn kernel: TCP established hash table entries: 1024 (order: 1, 8192 bytes)
May 14 17:34:06 (none) user.warn kernel: TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
May 14 17:34:06 (none) user.info kernel: TCP: Hash tables configured (established 1024 bind 1024)
May 14 17:34:06 (none) user.info kernel: TCP reno registered
May 14 17:34:06 (none) user.warn kernel: NetWinder Floating Point Emulator V0.97 (double precision)
May 14 17:34:06 (none) user.info kernel: JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
May 14 17:34:06 (none) user.info kernel: io scheduler noop registered
May 14 17:34:06 (none) user.info kernel: io scheduler deadline registered (default)
May 14 17:34:06 (none) user.info kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
May 14 17:34:06 (none) user.info kernel: serial8250.0: ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
May 14 17:34:06 (none) user.info kernel: serial8250.0: ttyS1 at MMIO 0xc8001000 (irq = 13) is a XScale
May 14 17:34:06 (none) user.warn kernel: RAMDISK driver initialized: 4 RAM disks of 10240K size 1024 blocksize
May 14 17:34:06 (none) user.info kernel: IXP4XX NPE driver Version 0.3.0 initialized
May 14 17:34:06 (none) user.info kernel: NFTL driver: nftlcore.c $Revision: 1.98 $, nftlmount.c $Revision: 1.41 $
May 14 17:34:06 (none) user.info kernel: IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
May 14 17:34:06 (none) user.debug kernel: IXP4XX-Flash.0: Found an alias at 0x800000 for the chip at 0x0
May 14 17:34:06 (none) user.warn kernel: Intel/Sharp Extended Query Table at 0x0031
May 14 17:34:06 (none) user.info kernel: Using buffer write method
May 14 17:34:06 (none) user.notice kernel: cfi_cmdset_0001: Erase suspend on write enabled
May 14 17:34:06 (none) user.debug kernel: erase region 0: offset=0x0,size=0x20000,blocks=64
May 14 17:34:06 (none) user.notice kernel: Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0x7e0000
May 14 17:34:06 (none) user.notice kernel: 6 RedBoot partitions found on MTD device IXP4XX-Flash.0
May 14 17:34:06 (none) user.notice kernel: Creating 6 MTD partitions on "IXP4XX-Flash.0":
May 14 17:34:06 (none) user.notice kernel: 0x00000000-0x00040000 : "RedBoot"
May 14 17:34:06 (none) user.info kernel: nslu2 mac: 00:0f:66:7b:fa:a0
May 14 17:34:06 (none) user.notice kernel: 0x00040000-0x00060000 : "SysConf"
May 14 17:34:06 (none) user.notice kernel: 0x00060000-0x00080000 : "Loader"
May 14 17:34:06 (none) user.notice kernel: 0x00080000-0x00180000 : "Kernel"
May 14 17:34:06 (none) user.notice kernel: 0x00180000-0x007e0000 : "Flashdisk"
May 14 17:34:06 (none) user.notice kernel: 0x007e0000-0x00800000 : "FIS directory"
May 14 17:34:06 (none) user.warn kernel: npe: searching for firmware...
May 14 17:34:06 (none) user.info kernel: npe: found at 0x1c010, IXP425/NPE-B func: 00, rev: 2.1, size: 11964, id: 01000201
May 14 17:34:06 (none) user.info kernel: Image loaded to NPE-B Func:0, Rel: 2:1, Status: 82c00000
May 14 17:34:06 (none) user.info kernel: Initializing USB Mass Storage driver...
May 14 17:34:06 (none) user.info kernel: usbcore: registered new interface driver usb-storage
May 14 17:34:06 (none) user.info kernel: USB Mass Storage support registered.
May 14 17:34:06 (none) user.info kernel: input: ixp4xx beeper as /class/input/input0
May 14 17:34:06 (none) user.info kernel: i2c /dev entries driver
May 14 17:34:06 (none) user.info kernel: x1205 0-006f: chip found, driver version 1.0.7
May 14 17:34:06 (none) user.info kernel: x1205 0-006f: rtc core: registered x1205 as rtc0
May 14 17:34:06 (none) user.info kernel: Registered led device: ready
May 14 17:34:06 (none) user.info kernel: Registered led device: status
May 14 17:34:06 (none) user.info kernel: Registered led device: disk-1
May 14 17:34:06 (none) user.info kernel: >Registered led device: disk-2
May 14 17:34:06 (none) user.info kernel: TCP cubic registered
May 14 17:34:06 (none) user.info kernel: NET: Registered protocol family 17
May 14 17:34:06 (none) user.info kernel: XScale DSP coprocessor detected.
May 14 17:34:06 (none) user.info kernel: x1205 0-006f: setting the system clock to 2009-05-14 17:33:26 (1242322406)
May 14 17:34:06 (none) user.warn kernel: VFS: Mounted root (jffs2 filesystem).
May 14 17:34:06 (none) user.info kernel: Freeing init memory: 84K
May 14 17:34:06 (none) user.warn kernel: PCI: enabling device 0000:00:01.2 (0140 -> 0142)
May 14 17:34:06 (none) user.info kernel: ehci_hcd 0000:00:01.2: EHCI Host Controller
May 14 17:34:06 (none) user.info kernel: ehci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
May 14 17:34:06 (none) user.info kernel: ehci_hcd 0000:00:01.2: irq 26, io mem 0x48002000
May 14 17:34:06 (none) user.info kernel: ehci_hcd 0000:00:01.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
May 14 17:34:06 (none) user.info kernel: usb usb1: configuration #1 chosen from 1 choice
May 14 17:34:06 (none) user.info kernel: hub 1-0:1.0: USB hub found
May 14 17:34:06 (none) user.info kernel: hub 1-0:1.0: 5 ports detected
May 14 17:34:06 (none) user.debug kernel: ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
May 14 17:34:06 (none) user.warn kernel: PCI: enabling device 0000:00:01.0 (0140 -> 0142)
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.0: OHCI Host Controller
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.0: new USB bus registered, assigned bus number 2
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.0: irq 28, io mem 0x48000000
May 14 17:34:06 (none) user.info kernel: usb usb2: configuration #1 chosen from 1 choice
May 14 17:34:06 (none) user.info kernel: hub 2-0:1.0: USB hub found
May 14 17:34:06 (none) user.info kernel: hub 2-0:1.0: 3 ports detected
May 14 17:34:06 (none) user.warn kernel: PCI: enabling device 0000:00:01.1 (0140 -> 0142)
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.1: OHCI Host Controller
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.1: new USB bus registered, assigned bus number 3
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.1: irq 27, io mem 0x48001000
May 14 17:34:06 (none) user.info kernel: usb usb3: configuration #1 chosen from 1 choice
May 14 17:34:06 (none) user.info kernel: hub 3-0:1.0: USB hub found
May 14 17:34:06 (none) user.info kernel: hub 3-0:1.0: 2 ports detected
May 14 17:34:06 (none) user.info kernel: usb 1-2: new high speed USB device using ehci_hcd and address 3
May 14 17:34:06 (none) user.info kernel: usb 1-2: configuration #1 chosen from 1 choice
May 14 17:34:06 (none) user.info kernel: scsi0 : SCSI emulation for USB Mass Storage devices
May 14 17:34:06 (none) user.debug kernel: usb-storage: device found at 3
May 14 17:34:06 (none) user.debug kernel: usb-storage: waiting for device to settle before scanning
May 14 17:34:06 (none) user.info kernel: usb 2-1: new low speed USB device using ohci_hcd and address 2
May 14 17:34:06 (none) user.info kernel: usb 2-1: configuration #1 chosen from 1 choice
May 14 17:34:06 (none) user.notice kernel: scsi 0:0:0:0: Direct-Access Kingmax USB2.0 FlashDisk 0.00 PQ: 0 ANSI: 2
May 14 17:34:06 (none) user.notice kernel: SCSI device sda: 3948543 512-byte hdwr sectors (2022 MB)
May 14 17:34:06 (none) user.notice kernel: sda: Write Protect is off
May 14 17:34:06 (none) user.debug kernel: sda: Mode Sense: 00 00 00 00
May 14 17:34:06 (none) user.err kernel: sda: assuming drive cache: write through
May 14 17:34:06 (none) user.info kernel: sda: sda1 sda2 sda3
May 14 17:34:06 (none) user.notice kernel: sd 0:0:0:0: Attached scsi removable disk sda
May 14 17:34:06 (none) user.debug kernel: usb-storage: device scan complete
May 14 17:34:06 (none) user.info kernel: kjournald starting. Commit interval 5 seconds
May 14 17:34:06 (none) user.warn kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
May 14 17:34:06 (none) user.info kernel: EXT3 FS on sda1, internal journal
May 14 17:34:06 (none) user.info kernel: EXT3-fs: recovery complete.
May 14 17:34:07 (none) user.info kernel: EXT3-fs: mounted filesystem with ordered data mode.
May 14 17:34:07 (none) user.info kernel: usbcore: registered new interface driver hiddev
May 14 17:34:07 (none) user.info kernel: hiddev96: USB HID v1.10 Device [Universal Bridge] on usb-0000:00:01.0-1
May 14 17:34:07 (none) user.info kernel: usbcore: registered new interface driver usbhid
May 14 17:34:07 (none) user.info kernel: drivers/usb/input/hid-core.c: v2.6:USB HID core driver
May 14 17:34:07 (none) user.info kernel: IXP4XX Q Manager 0.2.1 initialized.
May 14 17:34:07 (none) user.info kernel: ixp4xx_mac driver 0.3.1: eth0 on NPE-B with PHY[1] initialized
May 14 17:34:07 (none) user.info kernel: kjournald starting. Commit interval 5 seconds
May 14 17:34:07 (none) user.warn kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
May 14 17:34:07 (none) user.info kernel: EXT3 FS on sda3, internal journal
May 14 17:34:07 (none) user.info kernel: EXT3-fs: recovery complete.
May 14 17:34:07 (none) user.info kernel: Adding 131064k swap on /dev/sda2. Priority:-1 extents:1 across:131064k
May 14 17:34:08 (none) user.info kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
May 14 17:34:08 (none) user.debug kernel: Link of eth0 is full-duplex
May 14 17:34:10 (none) user.warn kernel: IXP4xx Watchdog Timer: heartbeat 60 sec
May 14 17:34:11 (none) user.info kernel: usbcore: registered new interface driver usbserial
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
May 14 17:34:11 (none) user.info kernel: usbcore: registered new interface driver usbserial_generic
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial Driver core
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for pl2303
May 14 17:34:11 (none) user.info kernel: usbcore: registered new interface driver pl2303
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for cp2101
May 14 17:34:11 (none) user.info kernel: usbcore: registered new interface driver cp2101
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/cp2101.c: Silicon Labs CP2101/CP2102 RS232 serial adaptor driver v0.07
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
May 14 17:34:11 (none) user.info kernel: usbcore: registered new interface driver ftdi_sio
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
May 14 17:34:12 (none) user.notice root: restart with recomputation of data (spontaneous reboot, reboot after shutdown, reboot after update).
May 14 17:34:12 (none) daemon.info init: Entering runlevel: 3
May 14 17:34:13 (none) auth.info sshd[1013]: Server listening on 0.0.0.0 port 22.
May 14 17:34:18 (none) daemon.crit thttpd[1087]: socket :: - Address family not supported by protocol
May 14 17:34:18 (none) daemon.notice thttpd[1087]: thttpd/2.25b 29dec2003 starting on port 80
May 14 17:34:18 (none) daemon.warn thttpd[1087]: started as root without requesting chroot(), warning only
May 14 17:34:18 (none) daemon.crit thttpdbackup[1093]: socket :: - Address family not supported by protocol
May 14 17:34:18 (none) daemon.notice thttpdbackup[1093]: thttpd/2.25b 29dec2003 starting on port 7777
May 14 17:34:18 (none) daemon.warn thttpdbackup[1093]: started as root without requesting chroot(), warning only
May 14 17:34:19 (none) user.info kernel: sd 0:0:0:0: SCSI error: return code = 0x08000002
May 14 17:34:19 (none) user.info kernel: sda: Current: sense key=0x7
May 14 17:34:19 (none) user.info kernel: ASC=0x27 ASCQ=0x0
May 14 17:34:19 (none) user.warn kernel: end_request: I/O error, dev sda, sector 1904872
May 14 17:34:19 (none) user.err kernel: Buffer I/O error on device sda3, logical block 98845
May 14 17:34:19 (none) user.warn kernel: lost page write due to I/O error on sda3
May 14 17:34:19 (none) user.info kernel: sd 0:0:0:0: Device not ready: <6>: Current: sense key=0x2
May 14 17:34:19 (none) user.info kernel: ASC=0x3a ASCQ=0x0
May 14 17:34:19 (none) user.warn kernel: end_request: I/O error, dev sda, sector 1936280
May 14 17:34:19 (none) user.err kernel: Buffer I/O error on device sda3, logical block 102771
May 14 17:34:19 (none) user.err kernel: Aborting journal on device sda3.
May 14 17:34:19 (none) user.warn kernel: __journal_remove_journal_head: freeing b_committed_data
May 14 17:34:19 (none) daemon.notice ntpd[1105]: ntpd 4.2.2p3@1.1577 Sat Feb 9 23:00:06 UTC 2008 (1)
May 14 17:34:19 (none) daemon.info ntpd[1106]: precision = 13.000 usec
May 14 17:34:19 (none) daemon.debug ntpd[1106]: ntp_io: estimated max descriptors: 1024, initial socket boundary: 16
May 14 17:34:19 (none) daemon.info ntpd[1106]: Listening on interface wildcard, 0.0.0.0#123 Disabled
May 14 17:34:19 (none) daemon.info ntpd[1106]: Listening on interface lo, 127.0.0.1#123 Enabled
May 14 17:34:19 (none) daemon.info ntpd[1106]: Listening on interface eth0, 192.168.1.78#123 Enabled
May 14 17:34:19 (none) daemon.info ntpd[1106]: Listening on interface eth0:0, 192.168.1.77#123 Enabled
May 14 17:34:20 (none) daemon.info ntpd[1106]: kernel time sync status 0040
May 14 17:34:20 (none) user.crit kernel: ext3_abort called.
May 14 17:34:20 (none) user.crit kernel: Remounting filesystem read-only
May 14 17:34:20 (none) cron.info /usr/sbin/cron[1121]: (CRON) STARTUP (fork ok)
May 14 17:34:20 (none) cron.info /usr/sbin/cron[1121]: (root.new) ORPHAN (no passwd entry)
May 14 17:34:20 (none) cron.info /usr/sbin/cron[1121]: (root.boot) ORPHAN (no passwd entry)
May 14 17:34:30 (none) user.info kernel: sd 0:0:0:0: Device not ready: <6>: Current: sense key=0x2
May 14 17:34:30 (none) user.info kernel: ASC=0x3a ASCQ=0x0
May 14 17:34:30 (none) user.warn kernel: end_request: I/O error, dev sda, sector 1900560
May 14 17:34:30 (none) user.err kernel: Buffer I/O error on device sda3, logical block 98306
May 14 17:34:30 (none) user.warn kernel: lost page write due to I/O error on sda3
May 14 17:34:30 (none) user.err kernel: Buffer I/O error on device sda3, logical block 98307
May 14 17:34:30 (none) user.err kernel: Buffer I/O error on device sda3, logical block 98308
May 14 17:34:30 (none) user.warn kernel: end_request: I/O error, dev sda, sector 2113536
May 14 17:34:30 (none) user.err kernel: Buffer I/O error on device sda3, logical block 124928
May 14 17:35:00 (none) cron.info /USR/SBIN/CRON[1155]: (root) CMD (/home/meteohub/wmr928fullevalwrapper >/dev/null 2>>/data/log/messages)
May 14 17:35:00 (none) cron.info /USR/SBIN/CRON[1157]: (root) CMD (/bin/pidof histeval1 || /usr/bin/nice /home/meteohub/histeval1)
May 14 17:35:00 (none) cron.info /USR/SBIN/CRON[1159]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
May 14 17:35:00 (none) cron.info CRON[1154]: (root) MAIL (mailed 65 bytes of output but got status 0x0001 )
May 14 17:36:00 (none) daemon.info thttpd[1087]: spawned CGI process 1210 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:00 (none) cron.info /USR/SBIN/CRON[1235]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
May 14 17:36:00 (none) cron.info /USR/SBIN/CRON[1234]: (root) CMD (/bin/pidof wswinimport || /usr/bin/nice /home/meteohub/wswinimport 2>>/data/log/messages)
May 14 17:36:13 (none) daemon.info thttpd[1087]: spawned CGI process 1249 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:18 (none) daemon.info thttpd[1087]: spawned CGI process 1270 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:38 (none) daemon.info thttpd[1087]: spawned CGI process 1296 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:53 (none) daemon.info thttpd[1087]: spawned CGI process 1331 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:55 (none) daemon.info thttpd[1087]: spawned CGI process 1351 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:55 (none) daemon.info thttpd[1087]: spawned CGI process 1371 for file 'cgi-bin/meteohub.cgi'
May 14 17:37:00 (none) cron.info /USR/SBIN/CRON[1392]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
May 14 17:38:00 (none) cron.info /USR/SBIN/CRON[1397]: (root) CMD (/usr/bin/nice /home/meteohub/wmr928eval -x -c min1 -t -3600 -w /data/weather/ -s /home/meteohub/wmr928eval.conf -e /home/meteohub/wswin.conf -E /home/meteohub/wd.conf)
May 14 17:38:00 (none) cron.info /USR/SBIN/CRON[1399]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
May 14 17:38:10 (none) daemon.info thttpd[1087]: spawned CGI process 1403 for file 'cgi-bin/meteohub.cgi'
May 14 17:38:14 (none) daemon.info thttpd[1087]: spawned CGI process 1426 for file 'cgi-bin/meteohub.cgi'
May 14 17:38:17 (none) daemon.info thttpd[1087]: spawned CGI process 1448 for file 'cgi-bin/meteohub.cgi'
May 14 17:38:21 (none) daemon.info thttpd[1087]: spawned CGI process 1470 for file 'cgi-bin/meteohub.cgi'
May 14 17:39:24 (none) daemon.info thttpd[1087]: spawned CGI process 1493 for file 'cgi-bin/meteohub.cgi'
May 14 17:39:26 (none) daemon.info thttpd[1087]: spawned CGI process 1515 for file 'cgi-bin/meteohub.cgi'
METOHUB LOG
empty
ALARM LOG
empty
SMB SERVER LOG
[2009/05/14 17:34:16, 0] smbd/server.c:main(881)
standard input is not a socket, assuming -D option
[2009/05/14 17:34:18, 1] lib/account_pol.c:account_policy_get(329)
account_policy_get: tdb_fetch_uint32 failed for field 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 10 (refuse machine password change), returning 0
