PRO2 Display
Mitch56338
- Senior Boarder
PRO2 Display
The display shifts down or up after the PRO2 is running for a few hours to a few days. Any idea's on how to correct?
- PRO2 Display.png (358.4 KiB) Viewed 2577 times
Re: PRO2 Display
Let me test with my PRO2. Which display template are you using? Which display interval is defined?
Mitch56338
- Senior Boarder
Re: PRO2 Display
Doesn't seem to matter what template I use. Even my home made ones have the same issue. I am currently using the built in one BIG-scrolll-IMP.dsp
- Template.PNG (7.23 KiB) Viewed 2556 times
- Version.PNG (40.75 KiB) Viewed 2556 times
Re: PRO2 Display
Do the following two browser requests bring it back in sync?
wait 2 seconds...
http://ip-of-your-meteobridge/cgi-bin/system.cgi?rcoled%20stopCode: Select all
http://ip-of-your-meteobridge/cgi-bin/system.cgi?rcoled%20start-
Mitch56338
- Senior Boarder
Re: PRO2 Display
That worked. Can this be automated so I don't have to manually do this through the browser?
Re: PRO2 Display
Just released update does a screen initialization on every "clear screen" command, which is issued a lot. That way it should keep in sync. Please reboot and give it a try.
Re: PRO2 Display
Mitch56338
- Senior Boarder
Re: PRO2 Display
After rebooting the PRO2 now just a small area of unreadable text at the very bottom. Stop and start from the browser and still no readable display. Seems like it starts to display but the auto reset cuts it off before the display can draw the screen.
- PRO2.png (327.43 KiB) Viewed 2526 times
Mitch56338
- Senior Boarder
Re: PRO2 Display
This started also. Tabs refreshing very slowly.
- Screenshot at 2024-02-28 12-04-45.png (75.48 KiB) Viewed 2522 times
Re: PRO2 Display
The intended fix seems to have some side effects. Please reboot to have the old version running again. It will need some more testing on my side.
Mitch56338
- Senior Boarder
Re: PRO2 Display
PRO2 returned to normal. Thank you.
Re: PRO2 Display
Just released update should have it fixed. It might need two reboots.
Mitch56338
- Senior Boarder
Re: PRO2 Display
While downloading the database backup file from the SD card to the computer for safe keeping the display shows mostly unreadable. After the download completed the display shows upside down. Doing the display stop start does correct it. I purchased a new MBPRO2* which doesn't have this display issue. Could a component be getting weak causing this issue?
- During Download
- PRO2_DWN.png (320.69 KiB) Viewed 2470 times
- After Download
- PRO2_DWN_AFT.png (422.68 KiB) Viewed 2470 times
