Meteobridge PRO / Impossible to edit hour or minute data
oncletom17
- Junior Boarder
I need to edit my rain data due to a bug (25.6 mm saved but 0.0 mm in the reality).
But editing the hour data is impossible. When I click on the valur, nothing happens...
How can I edit this?
- Capture d’écran 2024-06-17 161534.png (47.58 KiB) Viewed 3597 times
Re: Meteobridge PRO / Impossible to edit hour or minute data
Is there an issue with blocked pop-ups maybe on your browser?
To edit value, a remote window pops up when I click on the value.
oncletom17
- Junior Boarder
Hi davidmc36,
I checked the pop-up parameters and tried on my phone and with 2 different browsers.
But I see you have a local/IP connection.
I was trying tio edit the data by remote access (I'm actually not at home).
Is this the reason why?
oncletom17
- Junior Boarder
Now I'm at home... editing with IP access doesn't work
javascript needs to be enabled in your browser.
oncletom17
- Junior Boarder
javascript is enabled
- Capture3.JPG (24.97 KiB) Viewed 3569 times
Are you using most current Meteobridge version?
oncletom17
- Junior Boarder
I'm on the version 5.7
EDIT: I've just updated to version 6.0, but the problem persists.
As it works for all other users it must be something with your browser.
When you give me remote access, I can try myself. "info(at)meteobridge.com"
Thanks for providing me a login. Issue was that the French translation contained an unquoted ' which confuses the JavaScript where it is embedded into. I fixed that in just released update.
BTW: Translation makes the first menu line too long, which looks odd. Could you provide shorter tab names so that I can adapt?
oncletom17
- Junior Boarder
thanks for solving the problem!
to shorten menu names, you could write: "Editer données d'heure" "Editer données de minutes" but you'd only lose a few characters
First line is giving me headaches, because it runs away from the frame at the left. Any suggestions there?oncletom17 wrote: Tue Jun 18, 2024 9:48 am to shorten menu names, you could write: "Editer données d'heure" "Editer données de minutes" but you'd only lose a few characters
oncletom17
- Junior Boarder
Sorry, I didn't answer to you. Which line do you talk about?admin wrote: Tue Jun 18, 2024 12:26 pmFirst line is giving me headaches, because it runs away from the frame at the left. Any suggestions there?oncletom17 wrote: Tue Jun 18, 2024 9:48 am to shorten menu names, you could write: "Editer données d'heure" "Editer données de minutes" but you'd only lose a few characters
