Meteobridge PRO / Impossible to edit hour or minute data
oncletom17
Post by oncletom17 »
I need to edit my rain data due to a bug (25.6 mm saved but 0.0 mm in the reality).
But editing the hour data is impossible. When I click on the valur, nothing happens...
How can I edit this?
Capture d’écran 2024-06-17 161534.png (47.58 KiB) Viewed 3587 times
davidmc36
Re: Meteobridge PRO / Impossible to edit hour or minute data
Post by davidmc36 »
Is there an issue with blocked pop-ups maybe on your browser?
To edit value, a remote window pops up when I click on the value.
davidmc36
Post by davidmc36 »
Like this:
oncletom17
Hi davidmc36,
I checked the pop-up parameters and tried on my phone and with 2 different browsers.
But I see you have a local/IP connection.
I was trying tio edit the data by remote access (I'm actually not at home).
Is this the reason why?
oncletom17
Now I'm at home... editing with IP access doesn't work
javascript needs to be enabled in your browser.
oncletom17
admin wrote: Mon Jun 17, 2024 6:44 pm javascript needs to be enabled in your browser.
javascript is enabled
Are you using most current Meteobridge version?
oncletom17
I'm on the version 5.7
EDIT: I've just updated to version 6.0, but the problem persists.
As it works for all other users it must be something with your browser.
When you give me remote access, I can try myself. "info(at)meteobridge.com"
Thanks for providing me a login. Issue was that the French translation contained an unquoted ' which confuses the JavaScript where it is embedded into. I fixed that in just released update.
BTW: Translation makes the first menu line too long, which looks odd. Could you provide shorter tab names so that I can adapt?
oncletom17
thanks for solving the problem!
to shorten menu names, you could write: "Editer données d'heure" "Editer données de minutes" but you'd only lose a few characters
oncletom17 wrote: Tue Jun 18, 2024 9:48 am to shorten menu names, you could write: "Editer données d'heure" "Editer données de minutes" but you'd only lose a few characters
First line is giving me headaches, because it runs away from the frame at the left. Any suggestions there?
oncletom17
admin wrote: Tue Jun 18, 2024 12:26 pm
Sorry, I didn't answer to you. Which line do you talk about?
