Problem with rain total.
lorenz1982
Post by lorenz1982 »
Hello.
After today's update I have a problem with rain.
Today 4.2mm precipitated but only 0.4mm is shown.
Raspberry Pi 3 Model B+
Meteobridge 6.0 (Aug 14 2024, build 3285), FW 1.3
Sorry for my English.
MeteoBorgo: www.meteoborgo.it
lorenz1982
Re: Problem with rain total
EDIT:
After a few hours the rain total became right.
What happens?
Thanks for spotting this. I am on travel and will look at it on Sunday.
oncletom17
Post by oncletom17 »
Hi, it seems I get the same problem.
I thought that was because of my website meteotemplate. It seems to happen when full hours pass
An example on my website this morning :
graph_meteobridge_morning
The graph on meteobridge was OK;
meteotemplate
meteotemplate
But I've just noticed that this problem is due to my meteobridge.
meteobridge_rain:total
The graph is OK:
graph_meteobridge_afternoon
Here the hour data (sum = 12.4)
hour_data
hour_data
oncletom17
I can see on my website that the problem happened at 16h00
meteotemplate_afternoon
lorenz1982
Today
Re: Problem with rain total.
Should be solved with just released update.
lorenz1982
Re: Problem with rain total. **solved**
Thanks. With the latest update and today's rain it works fine.
JWR
Post by JWR »
Just I have the same problem since a few days. I reboot the system, so I get the newest version, but still the problem exists...
bug Meteobridge.jpg (11.19 KiB) Viewed 5167 times
When you send me remote login credentials "info(at)meteobridge.com", I can check. On my system it all looks fine.
JWR
Post by JWR »
I have just send! Thank you!
oncletom17
Re: Problem with rain total (again?)
It seems there is still problems with the rain total calculation.
everything is consistent on meteobridge but my personal website recorded additional rainfall, jumping back at 01:00 am. is it possible that meteobridge deleted rainfall to solve the above problem, which was resolved in August?
It seems strange to me that meteotemplate has invented these additional precipitations...
Could you check please?
Which SW version are you using? Which platform?
oncletom17
admin wrote: Thu Oct 03, 2024 4:18 pm Which SW version are you using? Which platform?
Capture d’écran 2024-10-03 164633.png (32.41 KiB) Viewed 4359 times
oncletom17
And again today...
Capture d’écran 2024-10-08 065331.png (25.66 KiB) Viewed 4071 times
this case makes me understand the problem: apparently, meteobridge divides by 2 the amount of rain that falls between 00:00 and 01:00 when it's 01:00
Today: 2.4 mm => 1.2 mm
2nd October => 12.8 => 6.4 mm
