Problem with rain total.
lorenz1982
- Expert Boarder
Hello.
After today's update I have a problem with rain.
Today 4.2mm precipitated but only 0.4mm is shown.
Raspberry Pi 3 Model B+
Meteobridge 6.0 (Aug 14 2024, build 3285), FW 1.3
Sorry for my English.
lorenz1982
- Expert Boarder
Re: Problem with rain total
EDIT:
After a few hours the rain total became right.
What happens?
What happens?
Thanks for spotting this. I am on travel and will look at it on Sunday.
oncletom17
- Junior Boarder
Hi, it seems I get the same problem.
I thought that was because of my website meteotemplate. It seems to happen when full hours pass
An example on my website this morning : The graph on meteobridge was OK; But I've just noticed that this problem is due to my meteobridge. The graph is OK: Here the hour data (sum = 12.4)
oncletom17
- Junior Boarder
I can see on my website that the problem happened at 16h00
lorenz1982
- Expert Boarder
Re: Problem with rain total.
Should be solved with just released update.
lorenz1982
- Expert Boarder
Re: Problem with rain total. **solved**
Thanks. With the latest update and today's rain it works fine.
Just I have the same problem since a few days. I reboot the system, so I get the newest version, but still the problem exists...
When you send me remote login credentials "info(at)meteobridge.com", I can check. On my system it all looks fine.
I have just send! Thank you!
oncletom17
- Junior Boarder
Re: Problem with rain total (again?)
It seems there is still problems with the rain total calculation.
everything is consistent on meteobridge but my personal website recorded additional rainfall, jumping back at 01:00 am. is it possible that meteobridge deleted rainfall to solve the above problem, which was resolved in August?
It seems strange to me that meteotemplate has invented these additional precipitations...
Could you check please?
Which SW version are you using? Which platform?
oncletom17
- Junior Boarder
oncletom17
- Junior Boarder
And again today...
this case makes me understand the problem: apparently, meteobridge divides by 2 the amount of rain that falls between 00:00 and 01:00 when it's 01:00
Today: 2.4 mm => 1.2 mm
2nd October => 12.8 => 6.4 mm
