NSLU2 updated to V4.2 sensors page error connect socket 127.
junkycosmos
Re:NSLU2 updated to V4.2 sensors page error connect socket 1
Post by junkycosmos »
Recieved my NSLU and memory stick back from Ambient Weather today where Ed had reflashed the NSLU and the Memory stick. Then tested on his Vantage pro.
However I am still getting the same issue when I try to use it here.
Have tried recycle and reset of both NSLU and WRM200 that I have it connected to via USB. Sensor page still shows ERROR
Also I noted that on weather stations page the drop down menue for device is grayed out ?? Image
junkycosmos
SYSTEM LOG
May 14 17:34:06 (none) syslog.info syslogd started: BusyBox v1.2.1
May 14 17:34:06 (none) user.notice kernel: klogd started: BusyBox v1.2.1 (2007.12.25-11:17+0000)
May 14 17:34:06 (none) user.notice kernel: Linux version 2.6.21.7 (slug@otto) (gcc version 4.1.2) #1 PREEMPT Mon Dec 24 23:12:24 UTC 2007
May 14 17:34:06 (none) user.warn kernel: CPU: XScale-IXP42x Family [690541f1] revision 1 (ARMv5TE), cr=000039ff
May 14 17:34:06 (none) user.warn kernel: Machine: Linksys NSLU2
May 14 17:34:06 (none) user.warn kernel: Memory policy: ECC disabled, Data cache writeback
May 14 17:34:06 (none) user.debug kernel: On node 0 totalpages: 8192
May 14 17:34:06 (none) user.debug kernel: DMA zone: 64 pages used for memmap
May 14 17:34:06 (none) user.debug kernel: DMA zone: 0 pages reserved
May 14 17:34:06 (none) user.debug kernel: DMA zone: 8128 pages, LIFO batch:0
May 14 17:34:06 (none) user.debug kernel: Normal zone: 0 pages used for memmap
May 14 17:34:06 (none) user.warn kernel: CPU0: D VIVT undefined 5 cache
May 14 17:34:06 (none) user.warn kernel: CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
May 14 17:34:06 (none) user.warn kernel: CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
May 14 17:34:06 (none) user.warn kernel: Built 1 zonelists. Total pages: 8128
May 14 17:34:06 (none) user.notice kernel: Kernel command line: rtc-x1205.probe=0,0x6f console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=jffs2 rw init=/linuxrc noirqdebug
May 14 17:34:06 (none) user.info kernel: IRQ lockup detection disabled
May 14 17:34:06 (none) user.warn kernel: PID hash table entries: 128 (order: 7, 512 bytes)
May 14 17:34:06 (none) user.warn kernel: Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
May 14 17:34:06 (none) user.warn kernel: Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
May 14 17:34:06 (none) user.info kernel: Memory: 32MB = 32MB total
May 14 17:34:06 (none) user.notice kernel: Memory: 30292KB available (1912K code, 153K data, 84K init)
May 14 17:34:06 (none) user.debug kernel: Calibrating delay loop... 132.71 BogoMIPS (lpj=663552)
May 14 17:34:06 (none) user.warn kernel: Mount-cache hash table entries: 512
May 14 17:34:06 (none) user.info kernel: CPU: Testing write buffer coherency: ok
May 14 17:34:06 (none) user.info kernel: NET: Registered protocol family 16
May 14 17:34:06 (none) user.warn kernel: IXP4xx: Using 16MiB expansion bus window size
May 14 17:34:06 (none) user.warn kernel: PCI: IXP4xx is host
May 14 17:34:06 (none) user.warn kernel: PCI: IXP4xx Using direct access for memory space
May 14 17:34:06 (none) user.info kernel: PCI: bus0: Fast back to back transfers disabled
May 14 17:34:06 (none) user.info kernel: dmabounce: registered device 0000:00:01.0 on pci bus
May 14 17:34:06 (none) user.info kernel: dmabounce: registered device 0000:00:01.1 on pci bus
May 14 17:34:06 (none) user.info kernel: dmabounce: registered device 0000:00:01.2 on pci bus
May 14 17:34:06 (none) user.notice kernel: SCSI subsystem initialized
May 14 17:34:06 (none) user.info kernel: usbcore: registered new interface driver usbfs
May 14 17:34:06 (none) user.info kernel: usbcore: registered new interface driver hub
May 14 17:34:06 (none) user.info kernel: usbcore: registered new device driver usb
May 14 17:34:06 (none) user.info kernel: Time: OSTS clocksource has been installed.
May 14 17:34:06 (none) user.info kernel: NET: Registered protocol family 2
May 14 17:34:06 (none) user.warn kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
May 14 17:34:06 (none) user.warn kernel: TCP established hash table entries: 1024 (order: 1, 8192 bytes)
May 14 17:34:06 (none) user.warn kernel: TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
May 14 17:34:06 (none) user.info kernel: TCP: Hash tables configured (established 1024 bind 1024)
May 14 17:34:06 (none) user.info kernel: TCP reno registered
May 14 17:34:06 (none) user.warn kernel: NetWinder Floating Point Emulator V0.97 (double precision)
May 14 17:34:06 (none) user.info kernel: JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
May 14 17:34:06 (none) user.info kernel: io scheduler noop registered
May 14 17:34:06 (none) user.info kernel: io scheduler deadline registered (default)
May 14 17:34:06 (none) user.info kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
May 14 17:34:06 (none) user.info kernel: serial8250.0: ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
May 14 17:34:06 (none) user.info kernel: serial8250.0: ttyS1 at MMIO 0xc8001000 (irq = 13) is a XScale
May 14 17:34:06 (none) user.warn kernel: RAMDISK driver initialized: 4 RAM disks of 10240K size 1024 blocksize
May 14 17:34:06 (none) user.info kernel: IXP4XX NPE driver Version 0.3.0 initialized
May 14 17:34:06 (none) user.info kernel: NFTL driver: nftlcore.c $Revision: 1.98 $, nftlmount.c $Revision: 1.41 $
May 14 17:34:06 (none) user.info kernel: IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
May 14 17:34:06 (none) user.debug kernel: IXP4XX-Flash.0: Found an alias at 0x800000 for the chip at 0x0
May 14 17:34:06 (none) user.warn kernel: Intel/Sharp Extended Query Table at 0x0031
May 14 17:34:06 (none) user.info kernel: Using buffer write method
May 14 17:34:06 (none) user.notice kernel: cfi_cmdset_0001: Erase suspend on write enabled
May 14 17:34:06 (none) user.debug kernel: erase region 0: offset=0x0,size=0x20000,blocks=64
May 14 17:34:06 (none) user.notice kernel: Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0x7e0000
May 14 17:34:06 (none) user.notice kernel: 6 RedBoot partitions found on MTD device IXP4XX-Flash.0
May 14 17:34:06 (none) user.notice kernel: Creating 6 MTD partitions on "IXP4XX-Flash.0":
May 14 17:34:06 (none) user.notice kernel: 0x00000000-0x00040000 : "RedBoot"
May 14 17:34:06 (none) user.info kernel: nslu2 mac: 00:0f:66:7b:fa:a0
May 14 17:34:06 (none) user.notice kernel: 0x00040000-0x00060000 : "SysConf"
May 14 17:34:06 (none) user.notice kernel: 0x00060000-0x00080000 : "Loader"
May 14 17:34:06 (none) user.notice kernel: 0x00080000-0x00180000 : "Kernel"
May 14 17:34:06 (none) user.notice kernel: 0x00180000-0x007e0000 : "Flashdisk"
May 14 17:34:06 (none) user.notice kernel: 0x007e0000-0x00800000 : "FIS directory"
May 14 17:34:06 (none) user.warn kernel: npe: searching for firmware...
May 14 17:34:06 (none) user.info kernel: npe: found at 0x1c010, IXP425/NPE-B func: 00, rev: 2.1, size: 11964, id: 01000201
May 14 17:34:06 (none) user.info kernel: Image loaded to NPE-B Func:0, Rel: 2:1, Status: 82c00000
May 14 17:34:06 (none) user.info kernel: Initializing USB Mass Storage driver...
May 14 17:34:06 (none) user.info kernel: usbcore: registered new interface driver usb-storage
May 14 17:34:06 (none) user.info kernel: USB Mass Storage support registered.
May 14 17:34:06 (none) user.info kernel: input: ixp4xx beeper as /class/input/input0
May 14 17:34:06 (none) user.info kernel: i2c /dev entries driver
May 14 17:34:06 (none) user.info kernel: x1205 0-006f: chip found, driver version 1.0.7
May 14 17:34:06 (none) user.info kernel: x1205 0-006f: rtc core: registered x1205 as rtc0
May 14 17:34:06 (none) user.info kernel: Registered led device: ready
May 14 17:34:06 (none) user.info kernel: Registered led device: status
May 14 17:34:06 (none) user.info kernel: Registered led device: disk-1
May 14 17:34:06 (none) user.info kernel: >Registered led device: disk-2
May 14 17:34:06 (none) user.info kernel: TCP cubic registered
May 14 17:34:06 (none) user.info kernel: NET: Registered protocol family 17
May 14 17:34:06 (none) user.info kernel: XScale DSP coprocessor detected.
May 14 17:34:06 (none) user.info kernel: x1205 0-006f: setting the system clock to 2009-05-14 17:33:26 (1242322406)
May 14 17:34:06 (none) user.warn kernel: VFS: Mounted root (jffs2 filesystem).
May 14 17:34:06 (none) user.info kernel: Freeing init memory: 84K
May 14 17:34:06 (none) user.warn kernel: PCI: enabling device 0000:00:01.2 (0140 -> 0142)
May 14 17:34:06 (none) user.info kernel: ehci_hcd 0000:00:01.2: EHCI Host Controller
May 14 17:34:06 (none) user.info kernel: ehci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
May 14 17:34:06 (none) user.info kernel: ehci_hcd 0000:00:01.2: irq 26, io mem 0x48002000
May 14 17:34:06 (none) user.info kernel: ehci_hcd 0000:00:01.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
May 14 17:34:06 (none) user.info kernel: usb usb1: configuration #1 chosen from 1 choice
May 14 17:34:06 (none) user.info kernel: hub 1-0:1.0: USB hub found
May 14 17:34:06 (none) user.info kernel: hub 1-0:1.0: 5 ports detected
May 14 17:34:06 (none) user.debug kernel: ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
May 14 17:34:06 (none) user.warn kernel: PCI: enabling device 0000:00:01.0 (0140 -> 0142)
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.0: OHCI Host Controller
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.0: new USB bus registered, assigned bus number 2
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.0: irq 28, io mem 0x48000000
May 14 17:34:06 (none) user.info kernel: usb usb2: configuration #1 chosen from 1 choice
May 14 17:34:06 (none) user.info kernel: hub 2-0:1.0: USB hub found
May 14 17:34:06 (none) user.info kernel: hub 2-0:1.0: 3 ports detected
May 14 17:34:06 (none) user.warn kernel: PCI: enabling device 0000:00:01.1 (0140 -> 0142)
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.1: OHCI Host Controller
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.1: new USB bus registered, assigned bus number 3
May 14 17:34:06 (none) user.info kernel: ohci_hcd 0000:00:01.1: irq 27, io mem 0x48001000
May 14 17:34:06 (none) user.info kernel: usb usb3: configuration #1 chosen from 1 choice
May 14 17:34:06 (none) user.info kernel: hub 3-0:1.0: USB hub found
May 14 17:34:06 (none) user.info kernel: hub 3-0:1.0: 2 ports detected
May 14 17:34:06 (none) user.info kernel: usb 1-2: new high speed USB device using ehci_hcd and address 3
May 14 17:34:06 (none) user.info kernel: usb 1-2: configuration #1 chosen from 1 choice
May 14 17:34:06 (none) user.info kernel: scsi0 : SCSI emulation for USB Mass Storage devices
May 14 17:34:06 (none) user.debug kernel: usb-storage: device found at 3
May 14 17:34:06 (none) user.debug kernel: usb-storage: waiting for device to settle before scanning
May 14 17:34:06 (none) user.info kernel: usb 2-1: new low speed USB device using ohci_hcd and address 2
May 14 17:34:06 (none) user.info kernel: usb 2-1: configuration #1 chosen from 1 choice
May 14 17:34:06 (none) user.notice kernel: scsi 0:0:0:0: Direct-Access Kingmax USB2.0 FlashDisk 0.00 PQ: 0 ANSI: 2
May 14 17:34:06 (none) user.notice kernel: SCSI device sda: 3948543 512-byte hdwr sectors (2022 MB)
May 14 17:34:06 (none) user.notice kernel: sda: Write Protect is off
May 14 17:34:06 (none) user.debug kernel: sda: Mode Sense: 00 00 00 00
May 14 17:34:06 (none) user.err kernel: sda: assuming drive cache: write through
May 14 17:34:06 (none) user.info kernel: sda: sda1 sda2 sda3
May 14 17:34:06 (none) user.notice kernel: sd 0:0:0:0: Attached scsi removable disk sda
May 14 17:34:06 (none) user.debug kernel: usb-storage: device scan complete
May 14 17:34:06 (none) user.info kernel: kjournald starting. Commit interval 5 seconds
May 14 17:34:06 (none) user.warn kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
May 14 17:34:06 (none) user.info kernel: EXT3 FS on sda1, internal journal
May 14 17:34:06 (none) user.info kernel: EXT3-fs: recovery complete.
May 14 17:34:07 (none) user.info kernel: EXT3-fs: mounted filesystem with ordered data mode.
May 14 17:34:07 (none) user.info kernel: usbcore: registered new interface driver hiddev
May 14 17:34:07 (none) user.info kernel: hiddev96: USB HID v1.10 Device [Universal Bridge] on usb-0000:00:01.0-1
May 14 17:34:07 (none) user.info kernel: usbcore: registered new interface driver usbhid
May 14 17:34:07 (none) user.info kernel: drivers/usb/input/hid-core.c: v2.6:USB HID core driver
May 14 17:34:07 (none) user.info kernel: IXP4XX Q Manager 0.2.1 initialized.
May 14 17:34:07 (none) user.info kernel: ixp4xx_mac driver 0.3.1: eth0 on NPE-B with PHY[1] initialized
May 14 17:34:07 (none) user.info kernel: kjournald starting. Commit interval 5 seconds
May 14 17:34:07 (none) user.warn kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
May 14 17:34:07 (none) user.info kernel: EXT3 FS on sda3, internal journal
May 14 17:34:07 (none) user.info kernel: EXT3-fs: recovery complete.
May 14 17:34:07 (none) user.info kernel: Adding 131064k swap on /dev/sda2. Priority:-1 extents:1 across:131064k
May 14 17:34:08 (none) user.info kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
May 14 17:34:08 (none) user.debug kernel: Link of eth0 is full-duplex
May 14 17:34:10 (none) user.warn kernel: IXP4xx Watchdog Timer: heartbeat 60 sec
May 14 17:34:11 (none) user.info kernel: usbcore: registered new interface driver usbserial
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
May 14 17:34:11 (none) user.info kernel: usbcore: registered new interface driver usbserial_generic
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial Driver core
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for pl2303
May 14 17:34:11 (none) user.info kernel: usbcore: registered new interface driver pl2303
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for cp2101
May 14 17:34:11 (none) user.info kernel: usbcore: registered new interface driver cp2101
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/cp2101.c: Silicon Labs CP2101/CP2102 RS232 serial adaptor driver v0.07
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
May 14 17:34:11 (none) user.info kernel: usbcore: registered new interface driver ftdi_sio
May 14 17:34:11 (none) user.info kernel: drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
May 14 17:34:12 (none) user.notice root: restart with recomputation of data (spontaneous reboot, reboot after shutdown, reboot after update).
May 14 17:34:12 (none) daemon.info init: Entering runlevel: 3
May 14 17:34:13 (none) auth.info sshd[1013]: Server listening on 0.0.0.0 port 22.
May 14 17:34:18 (none) daemon.crit thttpd[1087]: socket :: - Address family not supported by protocol
May 14 17:34:18 (none) daemon.notice thttpd[1087]: thttpd/2.25b 29dec2003 starting on port 80
May 14 17:34:18 (none) daemon.warn thttpd[1087]: started as root without requesting chroot(), warning only
May 14 17:34:18 (none) daemon.crit thttpdbackup[1093]: socket :: - Address family not supported by protocol
May 14 17:34:18 (none) daemon.notice thttpdbackup[1093]: thttpd/2.25b 29dec2003 starting on port 7777
May 14 17:34:18 (none) daemon.warn thttpdbackup[1093]: started as root without requesting chroot(), warning only
May 14 17:34:19 (none) user.info kernel: sd 0:0:0:0: SCSI error: return code = 0x08000002
May 14 17:34:19 (none) user.info kernel: sda: Current: sense key=0x7
May 14 17:34:19 (none) user.info kernel: ASC=0x27 ASCQ=0x0
May 14 17:34:19 (none) user.warn kernel: end_request: I/O error, dev sda, sector 1904872
May 14 17:34:19 (none) user.err kernel: Buffer I/O error on device sda3, logical block 98845
May 14 17:34:19 (none) user.warn kernel: lost page write due to I/O error on sda3
May 14 17:34:19 (none) user.info kernel: sd 0:0:0:0: Device not ready: <6>: Current: sense key=0x2
May 14 17:34:19 (none) user.info kernel: ASC=0x3a ASCQ=0x0
May 14 17:34:19 (none) user.warn kernel: end_request: I/O error, dev sda, sector 1936280
May 14 17:34:19 (none) user.err kernel: Buffer I/O error on device sda3, logical block 102771
May 14 17:34:19 (none) user.err kernel: Aborting journal on device sda3.
May 14 17:34:19 (none) user.warn kernel: __journal_remove_journal_head: freeing b_committed_data
May 14 17:34:19 (none) daemon.notice ntpd[1105]: ntpd 4.2.2p3@1.1577 Sat Feb 9 23:00:06 UTC 2008 (1)
May 14 17:34:19 (none) daemon.info ntpd[1106]: precision = 13.000 usec
May 14 17:34:19 (none) daemon.debug ntpd[1106]: ntp_io: estimated max descriptors: 1024, initial socket boundary: 16
May 14 17:34:19 (none) daemon.info ntpd[1106]: Listening on interface wildcard, 0.0.0.0#123 Disabled
May 14 17:34:19 (none) daemon.info ntpd[1106]: Listening on interface lo, 127.0.0.1#123 Enabled
May 14 17:34:19 (none) daemon.info ntpd[1106]: Listening on interface eth0, 192.168.1.78#123 Enabled
May 14 17:34:19 (none) daemon.info ntpd[1106]: Listening on interface eth0:0, 192.168.1.77#123 Enabled
May 14 17:34:20 (none) daemon.info ntpd[1106]: kernel time sync status 0040
May 14 17:34:20 (none) user.crit kernel: ext3_abort called.
May 14 17:34:20 (none) user.crit kernel: Remounting filesystem read-only
May 14 17:34:20 (none) cron.info /usr/sbin/cron[1121]: (CRON) STARTUP (fork ok)
May 14 17:34:20 (none) cron.info /usr/sbin/cron[1121]: (root.new) ORPHAN (no passwd entry)
May 14 17:34:20 (none) cron.info /usr/sbin/cron[1121]: (root.boot) ORPHAN (no passwd entry)
May 14 17:34:30 (none) user.info kernel: sd 0:0:0:0: Device not ready: <6>: Current: sense key=0x2
May 14 17:34:30 (none) user.info kernel: ASC=0x3a ASCQ=0x0
May 14 17:34:30 (none) user.warn kernel: end_request: I/O error, dev sda, sector 1900560
May 14 17:34:30 (none) user.err kernel: Buffer I/O error on device sda3, logical block 98306
May 14 17:34:30 (none) user.warn kernel: lost page write due to I/O error on sda3
May 14 17:34:30 (none) user.err kernel: Buffer I/O error on device sda3, logical block 98307
May 14 17:34:30 (none) user.err kernel: Buffer I/O error on device sda3, logical block 98308
May 14 17:34:30 (none) user.warn kernel: end_request: I/O error, dev sda, sector 2113536
May 14 17:34:30 (none) user.err kernel: Buffer I/O error on device sda3, logical block 124928
May 14 17:35:00 (none) cron.info /USR/SBIN/CRON[1155]: (root) CMD (/home/meteohub/wmr928fullevalwrapper >/dev/null 2>>/data/log/messages)
May 14 17:35:00 (none) cron.info /USR/SBIN/CRON[1157]: (root) CMD (/bin/pidof histeval1 || /usr/bin/nice /home/meteohub/histeval1)
May 14 17:35:00 (none) cron.info /USR/SBIN/CRON[1159]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
May 14 17:35:00 (none) cron.info CRON[1154]: (root) MAIL (mailed 65 bytes of output but got status 0x0001 )
May 14 17:36:00 (none) daemon.info thttpd[1087]: spawned CGI process 1210 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:00 (none) cron.info /USR/SBIN/CRON[1235]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
May 14 17:36:00 (none) cron.info /USR/SBIN/CRON[1234]: (root) CMD (/bin/pidof wswinimport || /usr/bin/nice /home/meteohub/wswinimport 2>>/data/log/messages)
May 14 17:36:13 (none) daemon.info thttpd[1087]: spawned CGI process 1249 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:18 (none) daemon.info thttpd[1087]: spawned CGI process 1270 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:38 (none) daemon.info thttpd[1087]: spawned CGI process 1296 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:53 (none) daemon.info thttpd[1087]: spawned CGI process 1331 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:55 (none) daemon.info thttpd[1087]: spawned CGI process 1351 for file 'cgi-bin/meteohub.cgi'
May 14 17:36:55 (none) daemon.info thttpd[1087]: spawned CGI process 1371 for file 'cgi-bin/meteohub.cgi'
May 14 17:37:00 (none) cron.info /USR/SBIN/CRON[1392]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
May 14 17:38:00 (none) cron.info /USR/SBIN/CRON[1397]: (root) CMD (/usr/bin/nice /home/meteohub/wmr928eval -x -c min1 -t -3600 -w /data/weather/ -s /home/meteohub/wmr928eval.conf -e /home/meteohub/wswin.conf -E /home/meteohub/wd.conf)
May 14 17:38:00 (none) cron.info /USR/SBIN/CRON[1399]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
May 14 17:38:10 (none) daemon.info thttpd[1087]: spawned CGI process 1403 for file 'cgi-bin/meteohub.cgi'
May 14 17:38:14 (none) daemon.info thttpd[1087]: spawned CGI process 1426 for file 'cgi-bin/meteohub.cgi'
May 14 17:38:17 (none) daemon.info thttpd[1087]: spawned CGI process 1448 for file 'cgi-bin/meteohub.cgi'
May 14 17:38:21 (none) daemon.info thttpd[1087]: spawned CGI process 1470 for file 'cgi-bin/meteohub.cgi'
May 14 17:39:24 (none) daemon.info thttpd[1087]: spawned CGI process 1493 for file 'cgi-bin/meteohub.cgi'
May 14 17:39:26 (none) daemon.info thttpd[1087]: spawned CGI process 1515 for file 'cgi-bin/meteohub.cgi'
METOHUB LOG
empty
ALARM LOG
empty
SMB SERVER LOG
[2009/05/14 17:34:16, 0] smbd/server.c:main(881)
standard input is not a socket, assuming -D option
[2009/05/14 17:34:18, 1] lib/account_pol.c:account_policy_get(329)
account_policy_get: tdb_fetch_uint32 failed for field 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 10 (refuse machine password change), returning 0
YJB
Post by YJB »
Not sure why you have USB HID selected. My NSLU2 is using USB Serial, might be worth a try. (But then, I might be wrong).
If this doesn't work, I think that Boris wants to see the dmesg output since it shows the available interfaces as well
Post by skyewright »
YJB wrote:Not sure why you have USB HID selected. My NSLU2 is using USB Serial, might be worth a try.
That sort of thing is not a matter of user choice.
I think that maybe I recall that you have a WMR928 / WMR968?
The WMR928 is a USB serial, but the WMR200 is a USB HID device.
PS. It can be very handy if you make use of the "Personal Text" feature in the Forum Profile to mention what equipment you have. If you do that, the text appears next to each of your Forum messages.
YJB
Post by YJB »
Oops, I stand corrected.
USB stick reports storage errors:
I would recommend to change the stick.
junkycosmos
Sorry to bump an older thread there but I wanted to provide the conclusion/resolution and a follow-up question to this. Received a new 2Gig memory stick and indeed it worked fine.
to recap
1. Was running fine for 9 months on v2.8.
2. On upgrading to v4.2 via web interface NSLU Meteohub would not restart.
3. Removed memory stick; reflashed via DD (no errors); restarted NSLU and Meteo launched fine hub; would let me assign a station (WRM-200) but on sensor page it noted “error connect socket 127.0.0.1:5555”
4. Recycled station, reset station, recycled NSLU/Metohub no change
5. Reflashed Memory stick using “2 card method and NSLU” (took 2hrs but completed)
5b. Posted here; Boris noted stick errors in log and suggested back stick
6. Contacted support (Ed) from Ambient Weather who suggested I mail in NSLU and memory stick
7. Ed reflashed NSLU and memory stick, tested both devices and mailed back.
8. When I retried them I had same symptom as in step2
8b. Boris re-evaluated logs and saw memory stick errors
9. Ordered new 2G memory stick;
10. Started up with new memory stick (2G v4.2 image); all configured and worked perfect
10. Formatted and ran h2testw.exe (from Tools download section on this site) on old 2gig memory stick and this tool indeed consistently finds an error on my old stick.
Error writing file 'E:\\1.h2w', offset 0x2ce00000.
It is still possible to verify the test data written up to this point.
(The media is write protected. Code 19)
Writing speed: 6.26 MByte/s
H2testw v1.4
Warning: Only 718 of 1918 MByte tested.
The media is likely to be defective.
717 MByte OK (1468416 sectors)
1 MByte DATA LOST (2048 sectors)
Details:512 KByte overwritten (1024 sectors)
0 KByte slightly changed (< 8 bit/sector, 0 sectors)
512 KByte corrupted (1024 sectors)
512 KByte aliased memory (1024 sectors)
First error at offset: 0x0000000020c33000
Expected: 0x0000000020c33000
Found: 0xffffffffffffffff
H2testw version 1.3
Reading speed: 23.5 MByte/s
H2testw v1.4
Outstanding Qs:
Could updating to v4.2 cause a memory stick to go bad or did it expose an existing error that was not seen under older versions ?
How could we be able to flash this bad memory stick and not receive any error
How could the two stick copy method still work if stick has error ?
BTW Thank you to Ed at Ambient Weather and Boris here for supporting this.
Updating Meteohub versions and running a complete data recomputation can make problems with USB sticks visible, that already have been there, but have not been detected so far.
junkycosmos
That does actually make perfect sense. Interesting to me that the DD tool did not error out when I imaged the defective memory stick.
Also interesting that Ed did not encounter an error when he tested the unit before shipping it back. Notably I called Ed and mentioned changing the way he retests and the memory stick test tool from your site here.
Thanks again for the reply and the awesome software Boris:keep up the great work!
Cheers,
Jeff
