My Meteobridge has no outdoor sensor data. **solved**
captgadget
- Expert Boarder
showing up. Indoor but no outdoor. Any suggestions. I'm using the Davis Weather Link Live
Re: My Meteobridge has no outdoor sensor data
Did you check if the IP-address is valid
Is the correct transmitter selected from the dropdown
It would be helpfull if you posted a screenshot of the Meteobridge tab were you setup the WLL as your primary station.
You should also check if the WLL is correctly functioning using this command in your browser
http://192.168.0.128/v1/current_conditions
Replace 192.168.0.128 with the IP-address of your WLL.
The data returned should contain texts such as
Succes, Wim
"temp": 50.6,"hum":86.2,"dew_point": 46.6,
"wind_speed_last":0.00,"wind_dir_last":0,"wind_speed_avg_last_1_min":0.00,Succes, Wim
- wll.jpeg (108.63 KiB) Viewed 2271 times
captgadget
- Expert Boarder
I used your functioning link with my info and everything comes back in good order. What I find strange is that when I select WLL to upload to WU all the info shows but if I check my devices it shows the station offline. https://www.wunderground.com/dashboard/ ... wx_pwsdash So WLL is sending to WU but I'm guessing since my station is offline that's why it doesn't work in the Meteobridge. Appreciate your insight.
"temp": 88.9,"hum":61.5,"dew_point": 74.0,"wet_bulb": 76.9,"heat_index": 98.1,
captgadget
- Expert Boarder
Here's what I'm referring to when I say there is outdoor sensor just indoors
In that screenshot you did not specify which sensor sets you have.captgadget wrote: Sat Oct 23, 2021 10:32 pm I used your functioning link with my info and everything comes back in good order. What I find strange is that when I select WLL to upload to WU all the info shows but if I check my devices it shows the station offline. https://www.wunderground.com/dashboard/ ... wx_pwsdash So WLL is sending to WU but I'm guessing since my station is offline that's why it doesn't work in the Meteobridge. Appreciate your insight.
Now only WLL integrated sensors are processed, that are inside temp/hum/pressure a.s.o.
Normally, transmitter nr 1 is the ISS (outside sensensuite). That ISS has all normal outside sensors temp, hum, wind a.s.o.
You have to add that in the second part, see attached screenshot.
You have to setup that before the Meteobridge knows were to look,
- copy.png (117.9 KiB) Viewed 2257 times
captgadget
- Expert Boarder
Bingo!!!!!! Thank you thank you don't know how to say it in your native language but thanks a million!
