Error: Windy: invalid API key
Churchtownweather
Post by Churchtownweather »
HI anyone
having problems with windy upload
Thanks in advance
Platokidd
Re: Error: Windy: invalid API key
Post by Platokidd »
Yes I am too. Started after updating to 6.0.
Valdrin
Post by Valdrin »
I have the same problem with the Windy API since May 16th, and now I see that CWOP is also having issues.
Platokidd
Post by Platokidd »
Wondering if this also was related to some far-out wacky numbers on the MIN/MAX.
Posted here viewtopic.php?t=18023
Since removing Windy the MIN/MAX numbers seem to be normal, fingers crossed. That said, there is a whole lot of bad numbers in the min/max.
Years worth all corrupted.
Churchtownweather wrote: Thu May 30, 2024 12:39 am HI anyone
Thanks in advance
I didn't touch Windy upload code for a long time. Can you please give me remote access? Please send credentials to "info(at)smartbedded.com".
Churchtownweather
Will do many thanks
Thanks, I was able to login. Your uploads to Windy sometime work, sometimes Meteobridge receives a HTTP Error 400. Looks like network routing or timing issues to me:
2024-05-31 10:49:03 Success: 2024-05-31 10:48:53
2024-05-31 10:44:03 Success: 2024-05-31 10:43:53
2024-05-31 10:39:02 Success: 2024-05-31 10:38:53
2024-05-31 10:36:05 Error: 2024-05-31 10:33:52  https://stations.windy.com/pws/update/xxx?station=0&ts=1717148032&temp=14.7&wind=2.7&winddir=300&gust=4.3&rh=70&dewpoint=9.3&mbar=1019.6&precip=0.0&uv=3.6: 2024-05-31 10:36:05 ERROR 400: Bad Request.  (no more tries)
2024-05-31 10:29:02 Success: 2024-05-31 10:28:52
2024-05-31 10:24:04 Error: 2024-05-31 10:23:52  https://stations.windy.com/pws/update/xxx?station=0&ts=1717147432&temp=14.7&wind=2.9&winddir=302&gust=5.2&rh=70&dewpoint=9.3&mbar=1019.5&precip=0.0&uv=2.3: 2024-05-31 10:24:04 ERROR 400: Bad Request.  (no more tries)
2024-05-31 10:19:04 Success: 2024-05-31 10:18:52
2024-05-31 10:14:01 Success: 2024-05-31 10:13:52
2024-05-31 10:09:02 Error: 2024-05-31 10:08:52  https://stations.windy.com/pws/update/xxx?station=0&ts=1717146532&temp=14.5&wind=1.9&winddir=0&gust=4.7&rh=70&dewpoint=9.1&mbar=1019.5&precip=0.0&uv=2.2: 2024-05-31 10:09:02 ERROR 400: Bad Request.  (no more tries)
2024-05-31 10:04:01 Error: 2024-05-31 10:03:52  https://stations.windy.com/pws/update/xxx?station=0&ts=1717146232&temp=14.3&wind=1.8&winddir=331&gust=3.3&rh=71&dewpoint=9.1&mbar=1019.5&precip=0.0&uv=3.2: 2024-05-31 10:04:01 ERROR 400: Bad Request.  (no more tries)
2024-05-31 10:01:07 Success: 2024-05-31 09:58:52
2024-05-31 09:56:05 Error: 2024-05-31 09:53:51  https://stations.windy.com/pws/update/xxx?station=0&ts=1717145631&temp=14.2&wind=1.9&winddir=319&gust=4.3&rh=71&dewpoint=9.0&mbar=1019.4&precip=0.0&uv=2.7: 2024-05-31 09:56:05 ERROR 400: Bad Request.  (no more tries)
2024-05-31 09:51:06 Success: 2024-05-31 09:48:51
Similar but less often with AWEKAS:
2024-05-31 09:37:55 Success: 2024-05-31 09:37:51
2024-05-31 09:32:53 Success: 2024-05-31 09:32:51
2024-05-31 09:27:53 Success: 2024-05-31 09:27:51
2024-05-31 09:23:06 Error: 2024-05-31 09:22:51 Read error (Connection timed out) in headers.  (no more tries)
2024-05-31 09:17:53 Success: 2024-05-31 09:17:51
2024-05-31 09:12:52 Success: 2024-05-31 09:12:50
2024-05-31 09:07:52 Success: 2024-05-31 09:07:50
2024-05-31 09:02:54 Success: 2024-05-31 09:02:50
2024-05-31 08:57:53 Success: 2024-05-31 08:57:50
2024-05-31 08:52:54 Success: 2024-05-31 08:52:50
2024-05-31 08:47:52 Success: 2024-05-31 08:47:50
2024-05-31 08:42:52 Success: 2024-05-31 08:42:50
2024-05-31 08:37:52 Success: 2024-05-31 08:37:50
2024-05-31 08:32:52 Success: 2024-05-31 08:32:49
2024-05-31 08:27:52 Success: 2024-05-31 08:27:49
2024-05-31 08:22:51 Success: 2024-05-31 08:22:49
2024-05-31 08:17:50 Success: 2024-05-31 08:17:49
2024-05-31 08:12:50 Success: 2024-05-31 08:12:49
2024-05-31 08:07:51 Success: 2024-05-31 08:07:49
2024-05-31 08:03:04 Error: 2024-05-31 08:02:49 Read error (Connection timed out) in headers.  (no more tries)
2024-05-31 07:57:50 Success: 2024-05-31 07:57:49
2024-05-31 07:52:49 Success: 2024-05-31 07:52:48
2024-05-31 07:47:50 Success: 2024-05-31 07:47:48
2024-05-31 07:42:50 Success: 2024-05-31 07:42:48
2024-05-31 07:37:50 Success: 2024-05-31 07:37:48
2024-05-31 07:32:49 Success: 2024-05-31 07:32:48
... and CWOP:
2024-05-31 10:53:58 Success: 2024-05-31 10:53:53
2024-05-31 10:48:59 Success: 2024-05-31 10:48:53
2024-05-31 10:43:59 Success: 2024-05-31 10:43:53
2024-05-31 10:38:57 Success: 2024-05-31 10:38:52
2024-05-31 10:36:01 Error: 2024-05-31 10:33:52 connection failed (no more tries)
2024-05-31 10:28:57 Success: 2024-05-31 10:28:52
2024-05-31 10:23:59 Success: 2024-05-31 10:23:52
2024-05-31 10:19:00 Success: 2024-05-31 10:18:52
2024-05-31 10:13:57 Success: 2024-05-31 10:13:52
2024-05-31 10:08:57 Success: 2024-05-31 10:08:52
2024-05-31 10:03:57 Success: 2024-05-31 10:03:52
2024-05-31 10:01:02 Error: 2024-05-31 09:58:52 connection failed (no more tries)
2024-05-31 09:56:01 Error: 2024-05-31 09:53:51 connection failed (no more tries)
2024-05-31 09:51:02 Error: 2024-05-31 09:48:51 connection failed (no more tries)
2024-05-31 09:43:56 Success: 2024-05-31 09:43:51
2024-05-31 09:41:01 Error: 2024-05-31 09:38:51 connection failed (no more tries)
2024-05-31 09:33:57 Success: 2024-05-31 09:33:51
2024-05-31 09:28:56 Success: 2024-05-31 09:28:51
2024-05-31 09:23:56 Success: 2024-05-31 09:23:51
2024-05-31 09:21:02 Error: 2024-05-31 09:18:51 connection failed (no more tries)
2024-05-31 09:13:56 Success: 2024-05-31 09:13:50
2024-05-31 09:10:59 Error: 2024-05-31 09:08:50 connection failed (no more tries)
2024-05-31 09:03:57 Success: 2024-05-31 09:03:50
2024-05-31 09:00:59 Error: 2024-05-31 08:58:50 connection failed (no more tries)
2024-05-31 08:53:55 Success: 2024-05-31 08:53:50
2024-05-31 08:51:00 Error: 2024-05-31 08:48:50 connection failed (no more tries)
2024-05-31 08:43:56 Success: 2024-05-31 08:43:50
I did a bit more research, windy has a minimum sent interval of 5 minutes. As you sent every 5 minutes, this might conflict here and there.
"update":{"update":{"stations":[],"observations":[{"si":0,"time":"2024-05-31T10:23:15.000Z","temp":12.2,"wind":1.5,"wind_dir":312,"wind_gust":4.7,"rh":80,"dew_point":8.9,"pressure":101670,"precip":0,"uv":0}]},"errors":{"observations":[],"stations":[]}},"result":{"0":{"stations":[],"observations":[{"success":false,"value":{"si":0,"time":"2024-05-31T10:23:15.000Z","temp":12.2,"wind":1.5,"wind_dir":312,"wind_gust":4.7,"rh":80,"dew_point":8.9,"pressure":101670,"precip":0,"uv":0},"error":"Measurement sent too soon, update interval is 5 minutes"}]}}}
When you set send interval to 10 min in Meteobridge, all will be fine. As an alternative, you can ask Windy to make it a bit more tolerant on there side.
Platokidd
Post by Platokidd »
Platokidd wrote: Thu May 30, 2024 9:40 pm Wondering if this also was related to some far-out wacky numbers on the MIN/MAX.
Rolling back to 5.8. Too many issues with 6.0 Corrupt MIN /MAX data. Tried to erase all and start over. Nojoy,
Windy still has issue even set at 10 minutes.
This error even occurs on your system when update interval set to 10 mins. Only explanation I have is that you have another PC reporting with same credentials to windy and this causes the rejections.
Churchtownweather
Many thanks that did the trick
zakos52
Post by zakos52 »
Same problem with meteobridge version 5.9!
Platokidd
Post by Platokidd »
admin wrote: Fri May 31, 2024 11:15 pm This error even occurs on your system when update interval set to 10 mins. Only explanation I have is that you have another PC reporting with same credentials to windy and this causes the rejections.
The meteobridge is the only source that I send data to Windy. Been sending data to Windy for a few years without issue. Just noticed this recently. I know CWOP sends my data to Windy.
Your Meteobridge is uploading partly fine to Windy. I have given you my analysis. Windy is rejecting packets with "you send too often" message. Please contact windy to get it fixed on their side.
