I don't have any solar sensors on my Davis Pro2 Wireless but the meteostick is transmitting/populating data? I don't have any virtual sensor designated either.
¿How can I remove this false data?
Solar radiation posted with no sensors?
- IMG_0454.jpeg (196.47 KiB) Viewed 503 times
- IMG_0453.jpeg (190.61 KiB) Viewed 503 times
- IMG_0452.jpeg (176.8 KiB) Viewed 503 times
Dave
Really! I am too busy to ranch.
Rei_Studio
- Fresh Boarder
Re: Solar radiation posted with no sensors?
Which software is processing the Meteostick data in your setup, Meteohub, Meteobridge or something else? Where are you seeing the false solar readings: in that software's live data or in data uploaded to a weather service?
2BZ2Ranch, not sure I'd blame the Meteostick itself... to be fair, the Davis ISS sends a solar field in every packet whether there's a sensor or not, so it's just junk or a "no sensor" value that the software then tries to read. Mine did something similar years ago and I reckon it was the software end that needed sorting, not the stick. I'd have a look at the sensor settings in whatever you're running and untick or disable solar and UV there, rather than hunting for a way to stop the stick sending it. Could be wrong mate, but that's what worked for me, and I definately didnt need to touch the hardware.
From the screen dumps I just see that there is a default mapping for a potential solar radiation sensor. These mapping rules are not adapted to the sensors you currently have.
Does "Monitoring - Live Data" show any solar data? If not, you simply misunderstood the mapping tab.
