Mine is wired to Ethernet, and it’s not possible to ping it after it crashes.dwhitemv wrote: Fri Jun 26, 2026 3:40 pm Random thought, is something spiking memory use and the OOM killer is killing everything?
If the MB was connected via wired Ethernet then ping would likely still work, and that would be a useful diagnostic. (If ping were to fail then that would indicate that the unit is hitting a kernel oops or something like that which leans more toward hardware failure.)
MB Pro Red hanging about once amonth
Re: MB Pro Red hanging about once amonth
My MBP red cap CPU (grey) spikes to 153% every hour as wellWS Heinenoord wrote: Fri Jun 26, 2026 7:22 am I'm glad to see my MB is not a sole case, but regret you have similar issues. It's very annoying because data isn't captured and uploads fail. Boris had a look, logged on to my MB and the only unusual he noted was that the MB CPU-% spikes every full hour to 200+ values. To see that for your MB, go to the "generate graph-tab" and select "MBPRO-health" graph. The cause is unclear. Switching of all events, all uploads and even disabling internet access did not change the pattern.
- MBP-health.png (125.05 KiB) Viewed 992 times
yamahabest
- Fresh Boarder
I see spikes every full hour close to or over 100%. The one indicated by 14(:00) was 137%.WS Heinenoord wrote: Fri Jun 26, 2026 7:22 am I'm glad to see my MB is not a sole case, but regret you have similar issues. It's very annoying because data isn't captured and uploads fail. Boris had a look, logged on to my MB and the only unusual he noted was that the MB CPU-% spikes every full hour to 200+ values. To see that for your MB, go to the "generate graph-tab" and select "MBPRO-health" graph. The cause is unclear. Switching of all events, all uploads and even disabling internet access did not change the pattern.
At 17:00 (not in the screenshot) there was a spike of 154%.
yamahabest
- Fresh Boarder
This seems also strange. I have a gap where nothing is shown on the graphs.
It is between June 25th, 13:04 and June 26th, 08:51.
But while this occurred, WOW was fed data without issues:
What can also be seen is that somehow the RF already stopped at around 11:04 (on the 25th), and resumed at around 13:05.
It might be worth setting up remote syslog so if its starts to complain before dying, the complaints can be recorded somewhere.
Can you also show the corresponding Processes & Ram usage
yamahabest
- Fresh Boarder
This is the current view:
yamahabest
- Fresh Boarder
System seems unstable to me.
On the WOW system I also see gaps of 20-30 minutes, with no data, around these timestamps.
There are also some CPU spikes (above 100%) around these timestamps:
logger (28.06.2026 04:26:09): station 0 (RF Vantage), debug off
logger (28.06.2026 04:26:09): station 0 (RF Vantage), verbose off
logger (28.06.2026 04:26:09): station 0 (RF Vantage), output raw
logger (28.06.2026 04:26:09): station 0 (RF Vantage), output raw (10 bytes)
logger (28.06.2026 04:26:09): station 0 (RF Vantage), filter on
logger (28.06.2026 04:26:09): station 0 (RF Vantage), rx threshold set to -90db
logger (28.06.2026 04:26:09): station 0 (RF Vantage), listening to tx 5
logger (28.06.2026 04:26:09): station 0 (RF Vantage), bandwidth narrow
logger (28.06.2026 04:26:10): station 0 (RF Vantage), chip auth ok: 14
logger (28.06.2026 04:26:10): station 0 (RF Vantage), frequency band 868MHz (EU)
logger (28.06.2026 04:26:11): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (28.06.2026 04:26:11): services paused.
dbase (28.06.2026 04:26:51): database sync done (50 tables, 85/3332 writes).
logger (28.06.2026 04:28:08): give up waiting for sensors after 120 secs.
logger (28.06.2026 04:28:08): services activated.
system (28.06.2026 02:30:23): Disconnected from WLAN or Internet, reconnect issued.
logger (28.06.2026 04:33:51): station 0 (RF Vantage), unexpected 0 bytes.
logger (28.06.2026 04:33:51): station 0 (RF Vantage), can't set attributes of device /dev/ttyMH113 to former values: Input/output error
logger (28.06.2026 04:33:51): disconnect station 0 (RF Vantage): response without data
logger (28.06.2026 04:34:21): connect station 0 (RF Vantage via USB serial).
logger (28.06.2026 04:34:23): station 0 (RF Vantage), transmitter 5 registered as ISS
system (28.06.2026 04:35:09): stop of logging process initiated.
logger (28.06.2026 04:35:09): parent process received termination signal (15).
logger (28.06.2026 04:35:09): child process received termination signal (15).
logger (28.06.2026 04:35:09): disconnect station 0 (RF Vantage): exit
logger (28.06.2026 04:35:09): disconnect station 9 (System Data): exit
dbase (28.06.2026 04:35:10): process terminated normally.
test5m (28.06.2026 02:35:12): USB storage remounted: /dev/sdc
dbase (28.06.2026 04:35:12): process started.
system (28.06.2026 04:35:12): start of logging process initiated.
logger (28.06.2026 04:35:13): databases connected. Update interval 3600 seconds.
logger (28.06.2026 04:35:13): data logger started.
logger (28.06.2026 04:35:15): connect station 0 (RF Vantage via USB serial).
logger (28.06.2026 04:35:15): connect station 9 (System Data via Plug-in).
logger (28.06.2026 04:35:15): station 0 (RF Vantage), transmitter 5 registered as ISS
logger (28.06.2026 04:35:15): station 0 (RF Vantage), Meteostick Version 3.4
logger (28.06.2026 04:35:15): station 0 (RF Vantage), debug off
logger (28.06.2026 04:35:15): station 0 (RF Vantage), verbose off
logger (28.06.2026 04:35:15): station 0 (RF Vantage), output raw
logger (28.06.2026 04:35:15): station 0 (RF Vantage), output raw (10 bytes)
logger (28.06.2026 04:35:15): station 0 (RF Vantage), filter on
logger (28.06.2026 04:35:15): station 0 (RF Vantage), rx threshold set to -90db
logger (28.06.2026 04:35:15): station 0 (RF Vantage), listening to tx 5
logger (28.06.2026 04:35:15): station 0 (RF Vantage), bandwidth narrow
logger (28.06.2026 04:35:15): station 0 (RF Vantage), chip auth ok: 14
logger (28.06.2026 04:35:15): station 0 (RF Vantage), frequency band 868MHz (EU)
logger (28.06.2026 04:35:16): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (28.06.2026 04:35:16): services paused.
dbase (28.06.2026 04:35:54): database sync done (50 tables, 54/3332 writes).
logger (28.06.2026 04:36:22): sensors are now providing data.
logger (28.06.2026 04:36:22): services started.
system (28.06.2026 02:40:33): Disconnected from WLAN or Internet, reconnect issued.
system (28.06.2026 02:45:46): Disconnected from WLAN or Internet, reconnect issued.
logger (28.06.2026 04:51:03): station 0 (RF Vantage), unexpected 0 bytes.
logger (28.06.2026 04:51:03): station 0 (RF Vantage), can't set attributes of device /dev/ttyMH113 to former values: Input/output error
logger (28.06.2026 04:51:03): disconnect station 0 (RF Vantage): response without data
logger (28.06.2026 04:51:33): connect station 0 (RF Vantage via USB serial).
logger (28.06.2026 04:51:35): station 0 (RF Vantage), transmitter 5 registered as ISS
system (28.06.2026 04:51:45): stop of logging process initiated.
logger (28.06.2026 04:51:45): parent process received termination signal (15).
logger (28.06.2026 04:51:45): child process received termination signal (15).
logger (28.06.2026 04:51:45): disconnect station 0 (RF Vantage): exit
logger (28.06.2026 04:51:45): disconnect station 9 (System Data): exit
dbase (28.06.2026 04:51:46): process terminated normally.
test5m (28.06.2026 02:51:48): USB storage remounted: /dev/sdb
dbase (28.06.2026 04:51:48): process started.
system (28.06.2026 04:51:48): start of logging process initiated.
logger (28.06.2026 04:51:49): databases connected. Update interval 3600 seconds.
logger (28.06.2026 04:51:49): data logger started.
logger (28.06.2026 04:51:52): connect station 0 (RF Vantage via USB serial).
logger (28.06.2026 04:51:52): connect station 9 (System Data via Plug-in).
logger (28.06.2026 04:51:52): station 0 (RF Vantage), transmitter 5 registered as ISS
logger (28.06.2026 04:51:52): station 0 (RF Vantage), Meteostick Version 3.4
logger (28.06.2026 04:51:52): station 0 (RF Vantage), debug off
logger (28.06.2026 04:51:52): station 0 (RF Vantage), verbose off
logger (28.06.2026 04:51:52): station 0 (RF Vantage), output raw
logger (28.06.2026 04:51:52): station 0 (RF Vantage), output raw (10 bytes)
logger (28.06.2026 04:51:52): station 0 (RF Vantage), filter on
logger (28.06.2026 04:51:52): station 0 (RF Vantage), rx threshold set to -90db
logger (28.06.2026 04:51:52): station 0 (RF Vantage), listening to tx 5
logger (28.06.2026 04:51:52): station 0 (RF Vantage), bandwidth narrow
logger (28.06.2026 04:51:53): station 0 (RF Vantage), chip auth ok: 14
logger (28.06.2026 04:51:53): station 0 (RF Vantage), frequency band 868MHz (EU)
logger (28.06.2026 04:51:54): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (28.06.2026 04:51:54): services paused.
dbase (28.06.2026 04:52:35): database sync done (50 tables, 64/3332 writes).
logger (28.06.2026 04:52:59): sensors are now providing data.
logger (28.06.2026 04:52:59): services started.
logger (28.06.2026 04:57:05): station 0 (RF Vantage), unexpected 0 bytes.
logger (28.06.2026 04:57:05): station 0 (RF Vantage), can't set attributes of device /dev/ttyMH113 to former values: Input/output error
logger (28.06.2026 04:57:05): disconnect station 0 (RF Vantage): response without data
logger (28.06.2026 04:57:35): connect station 0 (RF Vantage via USB serial).
logger (28.06.2026 04:57:37): station 0 (RF Vantage), transmitter 5 registered as ISS
dbase (28.06.2026 05:00:01): cannot insert into 'data10num_hour' (after 0 tries in 1ms): attempt to write a readonly database (8)
dbase (28.06.2026 05:00:01): rollback on update forced (min): data10num
system (28.06.2026 05:00:47): stop of logging process initiated.
logger (28.06.2026 05:00:47): parent process received termination signal (15).
logger (28.06.2026 05:00:47): child process received termination signal (15).
logger (28.06.2026 05:00:47): disconnect station 0 (RF Vantage): exit
logger (28.06.2026 05:00:47): disconnect station 9 (System Data): exit
test5m (28.06.2026 03:00:49): USB storage remounted: /dev/sdc
dbase (28.06.2026 05:00:49): process started.
system (28.06.2026 05:00:49): start of logging process initiated.
logger (28.06.2026 05:00:50): databases connected. Update interval 3600 seconds.
system (28.06.2026 03:00:50): Disconnected from WLAN or Internet, reconnect issued.
logger (28.06.2026 05:00:50): data logger started.
logger (28.06.2026 05:00:52): connect station 0 (RF Vantage via USB serial).
logger (28.06.2026 05:00:52): connect station 9 (System Data via Plug-in).
logger (28.06.2026 05:00:53): station 0 (RF Vantage), transmitter 5 registered as ISS
logger (28.06.2026 05:00:53): station 0 (RF Vantage), Meteostick Version 3.4
logger (28.06.2026 05:00:53): station 0 (RF Vantage), debug off
logger (28.06.2026 05:00:53): station 0 (RF Vantage), verbose off
logger (28.06.2026 05:00:53): station 0 (RF Vantage), output raw
logger (28.06.2026 05:00:53): station 0 (RF Vantage), output raw (10 bytes)
logger (28.06.2026 05:00:53): station 0 (RF Vantage), filter on
logger (28.06.2026 05:00:53): station 0 (RF Vantage), rx threshold set to -90db
logger (28.06.2026 05:00:53): station 0 (RF Vantage), listening to tx 5
logger (28.06.2026 05:00:53): station 0 (RF Vantage), bandwidth narrow
logger (28.06.2026 05:00:53): station 0 (RF Vantage), chip auth ok: 14
logger (28.06.2026 05:00:53): station 0 (RF Vantage), frequency band 868MHz (EU)
logger (28.06.2026 05:00:54): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (28.06.2026 05:00:54): services paused.
dbase (28.06.2026 05:01:49): database sync done (50 tables, 173/3374 writes).
logger (28.06.2026 05:02:50): give up waiting for sensors after 120 secs.
logger (28.06.2026 05:02:50): services activated.
system (28.06.2026 03:05:15): Disconnected from WLAN or Internet, reconnect issued.
system (28.06.2026 03:10:26): Disconnected from WLAN or Internet, reconnect issued.
system (28.06.2026 03:15:21): Disconnected from WLAN or Internet, reconnect issued.
logger (28.06.2026 05:23:14): station 0 (RF Vantage), unexpected 0 bytes.
logger (28.06.2026 05:23:14): station 0 (RF Vantage), can't set attributes of device /dev/ttyMH113 to former values: Input/output error
logger (28.06.2026 05:23:14): disconnect station 0 (RF Vantage): response without data
logger (28.06.2026 05:23:44): connect station 0 (RF Vantage via USB serial).
logger (28.06.2026 05:23:46): station 0 (RF Vantage), transmitter 5 registered as ISS
system (28.06.2026 05:26:20): stop of logging process initiated.
logger (28.06.2026 05:26:20): parent process received termination signal (15).
logger (28.06.2026 05:26:20): child process received termination signal (15).
logger (28.06.2026 05:26:20): disconnect station 0 (RF Vantage): exit
logger (28.06.2026 05:26:20): disconnect station 9 (System Data): exit
dbase (28.06.2026 05:26:21): process terminated normally.
test5m (28.06.2026 03:26:23): USB storage remounted: /dev/sdb
dbase (28.06.2026 05:26:23): process started.
system (28.06.2026 05:26:23): start of logging process initiated.
logger (28.06.2026 05:26:23): databases connected. Update interval 3600 seconds.
logger (28.06.2026 05:26:24): data logger started.
system (28.06.2026 03:26:24): Disconnected from WLAN or Internet, reconnect issued.
logger (28.06.2026 05:26:27): connect station 0 (RF Vantage via USB serial).
logger (28.06.2026 05:26:27): connect station 9 (System Data via Plug-in).
logger (28.06.2026 05:26:28): station 0 (RF Vantage), transmitter 5 registered as ISS
logger (28.06.2026 05:26:28): station 0 (RF Vantage), Meteostick Version 3.4
logger (28.06.2026 05:26:28): station 0 (RF Vantage), debug off
logger (28.06.2026 05:26:28): station 0 (RF Vantage), verbose off
logger (28.06.2026 05:26:28): station 0 (RF Vantage), output raw
logger (28.06.2026 05:26:28): station 0 (RF Vantage), output raw (10 bytes)
logger (28.06.2026 05:26:28): station 0 (RF Vantage), filter on
logger (28.06.2026 05:26:28): station 0 (RF Vantage), rx threshold set to -90db
logger (28.06.2026 05:26:28): station 0 (RF Vantage), listening to tx 5
logger (28.06.2026 05:26:28): station 0 (RF Vantage), bandwidth narrow
logger (28.06.2026 05:26:28): station 0 (RF Vantage), chip auth ok: 14
logger (28.06.2026 05:26:28): station 0 (RF Vantage), frequency band 868MHz (EU)
logger (28.06.2026 05:26:30): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (28.06.2026 05:26:30): services paused.
dbase (28.06.2026 05:27:19): database sync done (50 tables, 100/3416 writes).
logger (28.06.2026 05:27:34): sensors are now providing data.
logger (28.06.2026 05:27:34): services started.
logger (28.06.2026 05:33:43): station 0 (RF Vantage), unexpected 0 bytes.
logger (28.06.2026 05:33:43): station 0 (RF Vantage), can't set attributes of device /dev/ttyMH113 to former values: Input/output error
logger (28.06.2026 05:33:43): disconnect station 0 (RF Vantage): response without data
logger (28.06.2026 05:34:13): connect station 0 (RF Vantage via USB serial).
logger (28.06.2026 05:34:15): station 0 (RF Vantage), transmitter 5 registered as ISS
system (28.06.2026 05:36:15): stop of logging process initiated.
logger (28.06.2026 05:36:15): parent process received termination signal (15).
logger (28.06.2026 05:36:15): child process received termination signal (15).
logger (28.06.2026 05:36:15): disconnect station 0 (RF Vantage): exit
logger (28.06.2026 05:36:15): disconnect station 9 (System Data): exit
dbase (28.06.2026 05:36:17): process terminated normally.
test5m (28.06.2026 03:36:18): USB storage remounted: /dev/sdc
dbase (28.06.2026 05:36:18): process started.
system (28.06.2026 05:36:19): start of logging process initiated.
logger (28.06.2026 05:36:19): databases connected. Update interval 3600 seconds.
logger (28.06.2026 05:36:19): data logger started.
logger (28.06.2026 05:36:21): connect station 0 (RF Vantage via USB serial).
logger (28.06.2026 05:36:21): connect station 9 (System Data via Plug-in).
logger (28.06.2026 05:36:22): station 0 (RF Vantage), transmitter 5 registered as ISS
logger (28.06.2026 05:36:22): station 0 (RF Vantage), Meteostick Version 3.4
logger (28.06.2026 05:36:22): station 0 (RF Vantage), debug off
logger (28.06.2026 05:36:22): station 0 (RF Vantage), verbose off
logger (28.06.2026 05:36:22): station 0 (RF Vantage), output raw
logger (28.06.2026 05:36:22): station 0 (RF Vantage), output raw (10 bytes)
logger (28.06.2026 05:36:22): station 0 (RF Vantage), filter on
logger (28.06.2026 05:36:22): station 0 (RF Vantage), rx threshold set to -90db
logger (28.06.2026 05:36:22): station 0 (RF Vantage), listening to tx 5
logger (28.06.2026 05:36:22): station 0 (RF Vantage), bandwidth narrow
logger (28.06.2026 05:36:22): station 0 (RF Vantage), chip auth ok: 14
logger (28.06.2026 05:36:22): station 0 (RF Vantage), frequency band 868MHz (EU)
logger (28.06.2026 05:36:23): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (28.06.2026 05:36:23): services paused.
dbase (28.06.2026 05:37:03): database sync done (50 tables, 55/3416 writes).
logger (28.06.2026 05:37:28): sensors are now providing data.
logger (28.06.2026 05:37:28): services started.
system (28.06.2026 03:51:26): Disconnected from WLAN or Internet, reconnect issued.
So mine just crashed again... Hour before CPU was peaking at 169%.
So as I understand CPU should not have hour peaks like this?
- crash.png (140.95 KiB) Viewed 906 times
yamahabest
- Fresh Boarder
The system is once again not receiving data.
After reboot system starts to work immediately again.
logger (29.06.2026 17:32:11): give up waiting for sensors after 120 secs.
logger (29.06.2026 17:32:11): services activated.
logger (29.06.2026 17:40:40): child process received timeout signal (14).
logger (29.06.2026 17:40:40): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 17:40:40): disconnect station 9 (System Data): exit
logger (29.06.2026 17:40:42): data logger stopped.
logger (29.06.2026 17:40:42): databases disconnected.
logger (29.06.2026 17:40:42): parent process to be terminated.
logger (29.06.2026 17:40:42): databases connected. Update interval 3600 seconds.
logger (29.06.2026 17:40:42): data logger started.
logger (29.06.2026 17:40:43): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 17:40:43): connect station 9 (System Data via Plug-in).
logger (29.06.2026 17:40:46): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 17:40:46): services paused.
logger (29.06.2026 17:42:43): give up waiting for sensors after 120 secs.
logger (29.06.2026 17:42:43): services activated.
logger (29.06.2026 17:51:13): child process received timeout signal (14).
logger (29.06.2026 17:51:13): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 17:51:13): disconnect station 9 (System Data): exit
logger (29.06.2026 17:51:14): data logger stopped.
logger (29.06.2026 17:51:15): databases disconnected.
logger (29.06.2026 17:51:15): parent process to be terminated.
logger (29.06.2026 17:51:15): databases connected. Update interval 3600 seconds.
logger (29.06.2026 17:51:15): data logger started.
logger (29.06.2026 17:51:16): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 17:51:16): connect station 9 (System Data via Plug-in).
logger (29.06.2026 17:51:19): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 17:51:19): services paused.
logger (29.06.2026 17:53:16): give up waiting for sensors after 120 secs.
logger (29.06.2026 17:53:16): services activated.
logger (29.06.2026 18:01:46): child process received timeout signal (14).
logger (29.06.2026 18:01:46): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 18:01:46): disconnect station 9 (System Data): exit
logger (29.06.2026 18:01:47): data logger stopped.
logger (29.06.2026 18:01:47): databases disconnected.
logger (29.06.2026 18:01:47): parent process to be terminated.
logger (29.06.2026 18:01:47): databases connected. Update interval 3600 seconds.
logger (29.06.2026 18:01:47): data logger started.
logger (29.06.2026 18:01:48): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 18:01:48): connect station 9 (System Data via Plug-in).
logger (29.06.2026 18:01:52): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 18:01:52): services paused.
logger (29.06.2026 18:03:49): give up waiting for sensors after 120 secs.
logger (29.06.2026 18:03:49): services activated.
logger (29.06.2026 18:12:18): child process received timeout signal (14).
logger (29.06.2026 18:12:18): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 18:12:18): disconnect station 9 (System Data): exit
logger (29.06.2026 18:12:20): data logger stopped.
logger (29.06.2026 18:12:20): databases disconnected.
logger (29.06.2026 18:12:20): parent process to be terminated.
logger (29.06.2026 18:12:20): databases connected. Update interval 3600 seconds.
logger (29.06.2026 18:12:20): data logger started.
logger (29.06.2026 18:12:21): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 18:12:21): connect station 9 (System Data via Plug-in).
logger (29.06.2026 18:12:24): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 18:12:24): services paused.
logger (29.06.2026 18:14:21): give up waiting for sensors after 120 secs.
logger (29.06.2026 18:14:21): services activated.
logger (29.06.2026 18:22:51): child process received timeout signal (14).
logger (29.06.2026 18:22:51): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 18:22:51): disconnect station 9 (System Data): exit
logger (29.06.2026 18:22:52): data logger stopped.
logger (29.06.2026 18:22:52): databases disconnected.
logger (29.06.2026 18:22:52): parent process to be terminated.
logger (29.06.2026 18:22:53): databases connected. Update interval 3600 seconds.
logger (29.06.2026 18:22:53): data logger started.
logger (29.06.2026 18:22:54): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 18:22:54): connect station 9 (System Data via Plug-in).
logger (29.06.2026 18:22:57): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 18:22:57): services paused.
logger (29.06.2026 18:24:54): give up waiting for sensors after 120 secs.
logger (29.06.2026 18:24:54): services activated.
logger (29.06.2026 18:33:24): child process received timeout signal (14).
logger (29.06.2026 18:33:24): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 18:33:24): disconnect station 9 (System Data): exit
logger (29.06.2026 18:33:25): data logger stopped.
logger (29.06.2026 18:33:25): databases disconnected.
logger (29.06.2026 18:33:25): parent process to be terminated.
logger (29.06.2026 18:33:25): databases connected. Update interval 3600 seconds.
logger (29.06.2026 18:33:25): data logger started.
logger (29.06.2026 18:33:26): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 18:33:26): connect station 9 (System Data via Plug-in).
logger (29.06.2026 18:33:30): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 18:33:30): services paused.
logger (29.06.2026 18:35:27): give up waiting for sensors after 120 secs.
logger (29.06.2026 18:35:27): services activated.
logger (29.06.2026 18:43:56): child process received timeout signal (14).
logger (29.06.2026 18:43:56): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 18:43:56): disconnect station 9 (System Data): exit
logger (29.06.2026 18:43:58): data logger stopped.
logger (29.06.2026 18:43:58): databases disconnected.
logger (29.06.2026 18:43:58): parent process to be terminated.
logger (29.06.2026 18:43:58): databases connected. Update interval 3600 seconds.
logger (29.06.2026 18:43:58): data logger started.
logger (29.06.2026 18:43:59): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 18:43:59): connect station 9 (System Data via Plug-in).
logger (29.06.2026 18:44:01): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 18:44:01): services paused.
logger (29.06.2026 18:45:59): give up waiting for sensors after 120 secs.
logger (29.06.2026 18:45:59): services activated.
logger (29.06.2026 18:54:29): child process received timeout signal (14).
logger (29.06.2026 18:54:29): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 18:54:29): disconnect station 9 (System Data): exit
logger (29.06.2026 18:54:30): data logger stopped.
logger (29.06.2026 18:54:31): databases disconnected.
logger (29.06.2026 18:54:31): parent process to be terminated.
logger (29.06.2026 18:54:31): databases connected. Update interval 3600 seconds.
logger (29.06.2026 18:54:31): data logger started.
logger (29.06.2026 18:54:32): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 18:54:32): connect station 9 (System Data via Plug-in).
logger (29.06.2026 18:54:35): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 18:54:35): services paused.
logger (29.06.2026 18:56:32): give up waiting for sensors after 120 secs.
logger (29.06.2026 18:56:32): services activated.
logger (29.06.2026 19:05:02): child process received timeout signal (14).
logger (29.06.2026 19:05:02): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 19:05:02): disconnect station 9 (System Data): exit
logger (29.06.2026 19:05:03): data logger stopped.
logger (29.06.2026 19:05:03): databases disconnected.
logger (29.06.2026 19:05:03): parent process to be terminated.
logger (29.06.2026 19:05:03): databases connected. Update interval 3600 seconds.
logger (29.06.2026 19:05:03): data logger started.
logger (29.06.2026 19:05:05): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 19:05:05): connect station 9 (System Data via Plug-in).
logger (29.06.2026 19:05:08): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 19:05:08): services paused.
logger (29.06.2026 19:07:05): give up waiting for sensors after 120 secs.
logger (29.06.2026 19:07:05): services activated.
logger (29.06.2026 19:15:35): child process received timeout signal (14).
logger (29.06.2026 19:15:35): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 19:15:35): disconnect station 9 (System Data): exit
logger (29.06.2026 19:15:36): data logger stopped.
logger (29.06.2026 19:15:36): databases disconnected.
logger (29.06.2026 19:15:36): parent process to be terminated.
logger (29.06.2026 19:15:37): databases connected. Update interval 3600 seconds.
logger (29.06.2026 19:15:37): data logger started.
logger (29.06.2026 19:15:38): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 19:15:38): connect station 9 (System Data via Plug-in).
logger (29.06.2026 19:15:41): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 19:15:41): services paused.
system (29.06.2026 17:16:40): Disconnected from WLAN or Internet, reconnect issued.
logger (29.06.2026 19:17:38): give up waiting for sensors after 120 secs.
logger (29.06.2026 19:17:38): services activated.
logger (29.06.2026 19:26:08): child process received timeout signal (14).
logger (29.06.2026 19:26:08): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 19:26:08): disconnect station 9 (System Data): exit
logger (29.06.2026 19:26:09): data logger stopped.
logger (29.06.2026 19:26:09): databases disconnected.
logger (29.06.2026 19:26:09): parent process to be terminated.
logger (29.06.2026 19:26:09): databases connected. Update interval 3600 seconds.
logger (29.06.2026 19:26:09): data logger started.
logger (29.06.2026 19:26:10): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 19:26:10): connect station 9 (System Data via Plug-in).
logger (29.06.2026 19:26:14): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 19:26:14): services paused.
logger (29.06.2026 19:28:11): give up waiting for sensors after 120 secs.
logger (29.06.2026 19:28:11): services activated.
logger (29.06.2026 19:36:40): child process received timeout signal (14).
logger (29.06.2026 19:36:40): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 19:36:40): disconnect station 9 (System Data): exit
logger (29.06.2026 19:36:42): data logger stopped.
logger (29.06.2026 19:36:42): databases disconnected.
logger (29.06.2026 19:36:42): parent process to be terminated.
logger (29.06.2026 19:36:42): databases connected. Update interval 3600 seconds.
logger (29.06.2026 19:36:42): data logger started.
logger (29.06.2026 19:36:43): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 19:36:43): connect station 9 (System Data via Plug-in).
logger (29.06.2026 19:36:46): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 19:36:46): services paused.
logger (29.06.2026 19:38:43): give up waiting for sensors after 120 secs.
logger (29.06.2026 19:38:43): services activated.
system (29.06.2026 17:40:19): Disconnected from WLAN or Internet, reconnect issued.
logger (29.06.2026 19:47:13): child process received timeout signal (14).
logger (29.06.2026 19:47:13): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 19:47:13): disconnect station 9 (System Data): exit
logger (29.06.2026 19:47:14): data logger stopped.
logger (29.06.2026 19:47:15): databases disconnected.
logger (29.06.2026 19:47:15): parent process to be terminated.
logger (29.06.2026 19:47:15): databases connected. Update interval 3600 seconds.
logger (29.06.2026 19:47:15): data logger started.
logger (29.06.2026 19:47:16): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 19:47:16): connect station 9 (System Data via Plug-in).
logger (29.06.2026 19:47:19): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 19:47:19): services paused.
logger (29.06.2026 19:49:16): give up waiting for sensors after 120 secs.
logger (29.06.2026 19:49:16): services activated.
logger (29.06.2026 19:57:46): child process received timeout signal (14).
logger (29.06.2026 19:57:46): disconnect station 0 (RF Vantage): exit
logger (29.06.2026 19:57:46): disconnect station 9 (System Data): exit
logger (29.06.2026 19:57:47): data logger stopped.
logger (29.06.2026 19:57:47): databases disconnected.
logger (29.06.2026 19:57:47): parent process to be terminated.
logger (29.06.2026 19:57:47): databases connected. Update interval 3600 seconds.
logger (29.06.2026 19:57:47): data logger started.
logger (29.06.2026 19:57:48): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 19:57:48): connect station 9 (System Data via Plug-in).
logger (29.06.2026 19:57:52): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 19:57:52): services paused.
logger (29.06.2026 19:59:49): give up waiting for sensors after 120 secs.
logger (29.06.2026 19:59:49): services activated.
oled (26.06.2026 06:48:13): process started.
setup (29.06.2026 20:08:31): use UTC stamp 2026-06-29 18:08:31 (1 tries)
dbase (29.06.2026 20:08:38): process started.
dbase (29.06.2026 20:08:40): Content of RAM database restored.
wnetd (29.06.2026 20:08:41): process started.
system (29.06.2026 20:08:42): start of logging process initiated.
wnetd (29.06.2026 20:08:42): send data thread started (pid:2368 tid:2370)
logger (29.06.2026 20:08:42): databases connected. Update interval 3600 seconds.
logger (29.06.2026 20:08:42): data logger started.
logger (29.06.2026 20:08:45): connect station 0 (RF Vantage via USB serial).
logger (29.06.2026 20:08:45): connect station 9 (System Data via Plug-in).
logger (29.06.2026 20:08:47): station 0 (RF Vantage), transmitter 5 registered as ISS
logger (29.06.2026 20:08:47): station 0 (RF Vantage), Meteostick Version 3.4
logger (29.06.2026 20:08:47): station 0 (RF Vantage), debug off
logger (29.06.2026 20:08:47): station 0 (RF Vantage), verbose off
logger (29.06.2026 20:08:47): station 0 (RF Vantage), output raw
logger (29.06.2026 20:08:47): station 0 (RF Vantage), output raw (10 bytes)
logger (29.06.2026 20:08:47): station 0 (RF Vantage), filter on
logger (29.06.2026 20:08:47): station 0 (RF Vantage), rx threshold set to -90db
logger (29.06.2026 20:08:47): station 0 (RF Vantage), listening to tx 5
logger (29.06.2026 20:08:47): station 0 (RF Vantage), bandwidth narrow
logger (29.06.2026 20:08:47): station 0 (RF Vantage), chip auth ok: 14
logger (29.06.2026 20:08:47): station 0 (RF Vantage), frequency band 868MHz (EU)
logger (29.06.2026 20:08:48): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.06.2026 20:08:48): services paused.
dbase (29.06.2026 20:09:18): database sync done (50 tables, 33/3308 writes).
logger (29.06.2026 20:09:53): sensors are now providing data.
logger (29.06.2026 20:09:53): services started.
yamahabest
- Fresh Boarder
I had another hangup.
Video of what the MB Pro is showing:
https://youtube.com/shorts/u5RvaMgcOs0
Screenshot from router:
There is nothing in the graph (anymore, whilst it goes back to midnight at June 30th):
No data for more than a day:
Mine did also hang last evening, but the unit managed to recover by itself in the morning. The health graphs were empty all night. However the RF reception from my Davis station didn’t recover before I restarted it.
yamahabest
- Fresh Boarder
Mine went already down again last night.
I will have to do a power cycle again, once I am on the location where it is installed.
OOM killer would explain what is going on. The PRO is very tight on RAM. Disabling SMB can help to get more headroom.
yamahabest
- Fresh Boarder
How to disable SMB? --> I think I already found it: System > Administration > Security > SMB disabled
But... why is this suddenly an issue?
